07-16-2012, 09:19 AM
#2551 |
Oddometer: 225
I've been thinking of picking up a set of the model 60s to mount on a light bar on my V-Strom, along with a dimmer with high-beam bypass. One concern I have though is that since there's no cut-off, the lights will be blinding to oncoming traffic when it's dusk and darker out, even if they're dimmed down. If I dim them down to 10%, that might take care of it, but if they're that dim, I'm not sure I'll be throwing any real additional light onto the road. I did do an HID conversion, that works great. Has anyone run a setup like this and actually looked at the dimmed lights themselves when it's dark out?
Kicking ass seems to be THE ONLY solution to life's problems. Kicking ass is the first, second and third option. Plan B and C are also kicking ass. |
07-16-2012, 12:31 PM
#2552 | |
AKA Invisible Dave
Oddometer: 2,464
. There really is no solution as the lights have no reflector to control the light pattern.Dave
Why are we stopping? We don't have time for that! http://share.findmespot.com/shared/f...8pP8skl622N3ri |
07-18-2012, 03:02 AM
#2553 | |
Purveyor of Light
Oddometer: 3,661
A pair of 60s on the strom and you won't realize you have other lights
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
07-18-2012, 02:18 PM
#2554 |
De Oppresso Liber
Oddometer: 30,360
I am very interested in one of the headlights to augment (in this case blow it away) my stock WIMPY headlight on my 1973 CB340 Four Honda. I want the LED for it's low power consumption and high output. WHat model shout I get and where will it mount? Please PM me the details.
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
07-18-2012, 02:46 PM
#2555 |
Oddometer: 1,097
can I get a model 60 in amber?
07-18-2012, 04:39 PM
#2556 |
Boxer Addict
Oddometer: 419
Awesome! Just ordered 2 pairs of the Model 60's with dimmers. A buddy ordered a set yesterday for his KTM...looking forward to getting them on there. I'll actually be looking forward to riding at night, then.
Ben Carufel - Motorsport Photography - http://www.bencarufel.com '11 BMW F800ST - '02 BMW R1150GSA - '72 BMW R60/5 Other bikes to appear above shortly, rest assured... |
07-19-2012, 04:12 AM
#2557 | |
Purveyor of Light
Oddometer: 3,661
Post a pic of your bike. You could remove the reflectors on the upper fork (if they are bolt on) and mount there or possibly the bolts holding the headlight bucket (but they may block the blinkers). Here ya go. Thanks for the business!
07-20-2012, 12:47 AM
#2558 |
Oddometer: 299
So after buying a generic Fleabay "1125" Lumen LED spotlight, and finding it actually produces less light than my LED headtorch, I'm looking at some of these model 30's for my 950 Adv.
I just switched to 55w HIDs on my conventional low and high beam, and I'm looking at just getting one model 30, and mounting it to my high fender under the chin of the bike, so I have a directional headlight. So I was wondering:
Jdeks screwed with this post 07-20-2012 at 07:27 AM |
07-22-2012, 08:11 PM
#2559 |
Past Tense
Oddometer: 3,015
Any thoughts on running one spot and one wide beam (in addition to my stock headlamps) ? I'm thinking one LED lamp on each side of my bike, currently I have some PIAA mounted on my crash bars just below the gas tank on my Tiger, I'd be replacing the PIAAs with these instead. This way I'd get a good wide pattern up close and a good spot out front.
![]() FYI the Tiger headlamps suck on high beam (useless really) but provide a fair amount of light closer in, but still kinda sucky.
Tommy, what you ridin' there? Uh... Roll top desk! Do I look like a man with a plan? |
07-23-2012, 03:15 AM
#2560 |
Asshole
Oddometer: 159
OK, so its been a few weeks since i got the new ST switch and just wanted to report back really quick
ALL IS WELL and i think that maybe i just got one of "those bad ones" that sneak by on occasion. as soon as i had 20 minutes to throw this one back on (that long only because of the way i have it mounted, i have to pull the whole headlight off, which is only 2 bolts.) i did and havent had an issue yet. at this point, my only niggle is the buttons are hard to locate with gloves on, and ive taken to riding with one off when i know ill need to hit the switch. other than that, i cant wait to see a model 60 spot....then ill be set!!!
Give a man fire, and he's warm for a night. Set a man on fire, and he's warm for the rest of his life. |
07-23-2012, 09:51 AM
#2561 |
Oddometer: 11
I got it working finally. I didn't realize that I am litterally the only person here that had to make a completely custom installation of this light on my bike. So I had to learn a ton of stuff to make it work. First off my bike didn't have a lighting coil, so I bought one, but they don't tell you it will need to be modified to work for my bike, it has only one power wire comming out, so I had to "float the ground" they call it. That means cutting the ground wire loop off and soldering another wire to it so that I can have 2 wires come out of the coil. Sounds easy right? It isn't, soldering to a coil wire is near impossible, they coat the wire with something that won't burn off and just won't allow solder to stick, so I had to take it to a radio repair guy who was able to solder it for me. Ok, now that I have 2 wires, I needed a REGULATOR/RECTIFYER, again I didn't know that and had originally purchased a REGULATOR only, which will not work because it doesn't turn the electricity into dc voltage. I then had to get technical info from folks like ricky stator and trail tech to help me discover that I was also going to need a battery and a wireing scematic to show me how to hook it all up. And it can be wired several ways depending on how you want to run it. I got it running last night and it is super bright and killer looking. I mounted the light on the handle bars, the switch is mounted into the side fairing for easy reaching and it is the only button there so it is not confusing in the dark. I mounted the regulator/rectifyer and also the battery into my air box using wide size heavy duty velcro! And to tie it all together I soldered and shrink tubed all connections, which reminds me, that waterproof connector from ADVmonster was no good for me, bad design that takes tiny hands and an hour of time to use, I tossed it and soldered the wires together. ![]()
TRed screwed with this post 07-23-2012 at 09:57 AM |
07-24-2012, 12:07 AM
#2562 | |
ED RN Adventurer
![]() Flood on the right (I have "Yellow filter" covering the bottom half of the light) and spot on the left. Spot to come on with brights and fogs on a AS7 Autoswitch to turn signal cancel button (F800GS)
Tracy E / Photos4Aidan.com / dacrazyrn.dpcprints.com / Can you SPOT me? “When you do things RIGHT, people won’t be sure you’ve done anything at all.” God in Godfellas-Futurama Life is Risk Management '09 BMW F800GS-Fate Honeyed GSabelle |
07-24-2012, 04:15 AM
#2563 | ||||
Purveyor of Light
Oddometer: 3,661
You should be ok with the high beam circuit. Although you should check the fuse size just to verify. Quote:
After spending a bunch of time adjusting my 02 Tiger 955 headlight, they work reasonably well, you might check out tigertriple for recommended adjustments. Congrats, lets see some single track action with the light ![]() Quote:
I have a functioning protoype for dirt bikes that uses ac power and I'm always looking for a guinea pig Quote:
07-24-2012, 10:02 AM
#2564 |
Past Tense
Oddometer: 3,015
Any eta on the model 60? I see it's on backorder.
07-24-2012, 11:49 AM
#2565 |
Purveyor of Light
Oddometer: 3,661
Later this week.
