Old 08-24-2012, 09:44 PM   #2656
Rev
Asshole
Rev's Avatar
Oddometer: 238
my theory on 4 is that ill have 2 on the fairing facing always forward, and possibly 2 lower so i can have light while i turn, which is (for me) a needed thing, and the 2 lower would be facing a little out toward the sides of the road instead of just straight ahead. im not ever going to have heated gear or other random things aside from the GPS plug
Give a man fire, and he's warm for a night.
Set a man on fire, and he's warm for the rest of his life.
Rev is offline   Reply With Quote
Old 08-25-2012, 06:01 AM   #2657
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
After riding my Husky with our soon to be introduced drop in light (I have one model 60 in it) I am shocked. Can't imagine what 4 M60s would look like
Old 08-25-2012, 11:28 AM   #2658
nashopolis
nashopolis's Avatar
Oddometer: 716
So perhaps this has been answered a millions times - but this thread is looooong!
I have a dr250 I'd like to add some lights tor visibility and better night time riding when I get away from the city and need some light on dark country roads.
I'm new to trying to wire lights up On a bike- is there a tutorial on installing these lights?
What am I going to need besides buying 2 lights, a switch and some mounts?
pm me if you need my email
nashopolis is offline   Reply With Quote
Old 08-25-2012, 01:03 PM   #2659
m5guy
Oddometer: 32
Originally Posted by Jazz62 View Post
Yup, I've taken the thing apart when I installed my HID lowbeam set up. Pain in the ass but if I can do it, anyone can. Was just hoping to avoid it in the case of getting the highbeam bypass feature of this dimmer hooked up/
Jazz62, you probably figured this out already, but using the horn wiring to trigger the full bright setting is not going to work. The high beam trigger wire needs a consistent 12V hot current to keep your Advmonster holding in the full bright setting. If you use the horn wire, your Adv lights will only go into the full bright for as long as you hold down the horn button. Not very convenient.
m5guy is offline   Reply With Quote
Old 08-25-2012, 01:19 PM   #2660
Entrepre-neer
Ultimate Tight A$$
Entrepre-neer's Avatar
Oddometer: 424
KTM Stock fairing mod
Two 30W quad XM-L
Stock 5W halogen city light
Both 30W modules on
55W Halogen for comparison
Entrepre-neer is offline   Reply With Quote
Old 08-25-2012, 01:43 PM   #2661
Jazz62
Jazz62's Avatar
Oddometer: 1,011
Oh that would special, wouldn't it? Thanks for the response. I did not bother trying it. I found that after removing my windshield and the silver gauge cover I could get just enough pressure from above and below to remove the highbeam rear cap. What I'm struggling with now is how to route the wire itself. It is very thin making it really tough to thread it through a piece of shrink tube of adequate length. It definitely needs some protection though as I'm going from my left handguard following an existing harness to the headstock and then need to route it forward to the back of the higheam housing. I'll figure it out just want to be careful it's not rubbing too much when I turn the bars.
Jazz62 is offline   Reply With Quote
Old 08-26-2012, 05:13 AM   #2662
RoundOz
Plenty of seasoning
Oddometer: 1,004
Use some thin stiff wire like electric fence wire or baling wire as a pull through. When running new wires through the body of the bike where I am afraid it will rub I use a cable like 2 or 3 core instead, assuming I will use the other core/s for something else later.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 08-26-2012, 12:23 PM   #2663
Jazz62
Jazz62's Avatar
Oddometer: 1,011
That is a good idea. I ended up using a shorter length of heatshrink tube where the wire runs along an existing harness. That got me to the point where I had to route the wire around the front of the upper frame, near where the horn is. I needed more flexibility here than the shrink tube would allow but I still wanted to protect the wire from any possible chafing so I wrapped this section in electrical tape, a total of about 6".
Old 08-27-2012, 07:20 AM   #2664
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
If you are riding much in the city, I would recomend one of our LED controls with high beam bypass. Let's you set a dimmed setting to be seen, while having full power at a flip of your high beam switch. With a DRZ250 it will also reduce electrical consumption (at the dimmed setting). This important as your bike does not have a lot of watts available. If a LED Controller (high beam bypass models) is purchased with lights, it will come as a plug n play setup at no additional cost.
You'll need connection to the power, preferrably fused.
Mounts are included with the lights. PM your email address or contact me sandjoh@gmail.com if you have any questions
Old 08-27-2012, 11:25 AM   #2665
SV_Dwayne
SV_Dwayne's Avatar
Oddometer: 302
If I read the new KTM offering correctly, it has a high beam bypass option, right? In the pictures it also looks like you're using your ST dimmer... but on the ST dimmer webpage, I don't see anything about a high beam bypass. Does the ST dimmer have this feature? I only see two input and two output wires on the ST dimmer pictures, so I was assuming it doesn't do the bypass.
Kicking ass seems to be THE ONLY solution to life's problems. Kicking ass is the first, second and third option. Plan B and C are also kicking ass.
SV_Dwayne is offline   Reply With Quote
Old 08-27-2012, 11:50 AM   #2666
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
The ST dimmer does not have a high beam bypass. The new drop in light offerings are using the ST dimmer for low beam with an external relay for high beam. These are buried in the headlight mask so limited access, only to set the low beam output.
Old 08-27-2012, 12:12 PM   #2667
SV_Dwayne
SV_Dwayne's Avatar
Oddometer: 302
Thanks for clarifying! I'm very happy with the M1 so far, works great for the 6am commute. I'll have to get some nice shots when I have time and write a short review. I'm looking forward to upgrading the halogens on the strom to some LEDs. Any new products in the pipeline, something bigger than the 60 perhaps? Yeh, overkill maybe, but go big or go home, right?
Old 08-27-2012, 05:19 PM   #2668
OneZero
TGT of Opportunity
OneZero's Avatar
Oddometer: 287
I ordered my Model 30 lights on Friday night and received them today (Monday)!! Now that is FAST! I can't wait to get them installed. Thanks John!
Eric
There is no greater honor in this world than leading U.S. Soldiers at home and abroad. 'nuff said.
OneZero is offline   Reply With Quote
Old 08-27-2012, 07:28 PM   #2669
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,498
I got my model 30's a couple weeks ago, and have had them on awhile now. Last night was the first "deep, dark creepy ass - deer filled" evening I had to ride home. I really got the model 30's as I wanted basic daytime running lights, no dimmers, no multiple intensity, just on and off.
I was very pleased as a rode 110 miles home last night in the dank dark wee hours. The model 30's threw a big white ball of light about 45 yards out, give or take. I apparently had them just a bit cross eyed, which you dont really see in the daytime. At night, the "crossed beams" met in the middle and really came through. My pale yellow ass stock headlamp just a flicker in comparison.
Guess I am saying I am pleased with the model 30 units .
I'm bad at long goodbyes too...)
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 08-28-2012, 05:33 PM   #2670
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
Originally Posted by Unstable Rider;19459986[FONT=Century Gothic
Guess I am saying I am pleased with the model 30 units . [/FONT]
Great! Keep an eye for them critters
Times are GMT -7.   It's 06:01 AM.
