08-31-2012, 04:02 PM
#2686 |
Oddometer: 1,668
I'm thinking the bracket is resting against the fork leg, so it cannot rotate back.
09-01-2012, 04:33 PM
#2687 |
Life is good
Oddometer: 68
M60 just ordered!
Will post images after installation
Thanks for the advrider discount!! ![]() best Diego |
09-02-2012, 02:57 AM
#2688 | |
Purveyor of Light
Oddometer: 3,661
Let me know if you have any questions on the install. Have a great Labor Day.
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
09-02-2012, 03:42 AM
#2689 |
Soyez sans que peur
Oddometer: 276
I like the rotary dimmer, handy having the adjustment knob and off option right on the dash.
bokrijder
KTM450EXC KLR650 BMW R50/2 |
09-03-2012, 11:07 AM
#2690 |
73 2U
Oddometer: 10
THAT was quick !
I placed my order Wednesday evening and the postman delivered my lights Saturday, just in time for me to play with them over the Labor Day weekend.
I also bought the LED flashlight, which is very cool -- |
09-03-2012, 05:44 PM
#2691 |
IBA #49986
Oddometer: 211
Just got my second order, quickly and efficiently. Great lights.
Sent from my Galaxy Nexus using Tapatalk 2 |
09-03-2012, 10:41 PM
#2692 |
Asshole
Oddometer: 159
any ideas on mounting a pair to the forks of the 08 KLR?
could i beg a rotary switch that could handle 4 60's ? even better if the knob could come off so i could put the box behind my dash plate
Give a man fire, and he's warm for a night. Set a man on fire, and he's warm for the rest of his life. Rev screwed with this post 09-03-2012 at 10:50 PM |
09-04-2012, 04:44 AM
#2693 | ||
Purveyor of Light
Oddometer: 3,661
![]() You can mount them on the lower fork leg by removing the stock side reflectors. Or pick up a set of turn signal relocators for a 41mm fork. As much as I would like to sell you 4 model 60s, you just don't need 4! Unless you are wearing your welding helmet. Please try a pair and if find you need more light we can talk.
09-04-2012, 05:40 PM
#2694 |
Oddometer: 11
Email sent
Hi Sanjoh.. looking forward to hearing back from you!! Can't wait to try out my mount ideas...... just need to find out if the total throw for the 60 model 'flood' is longer than the 30 model 'spot'. I was thinking one of each (1 mounted as spot on top fairing of my KLRto give maximum distance, the other where my orig fender was mounted so it will turn with bars) ..BUT if the total throw of the 60 flood is just as far..then I will spring for 2 of those with a rotary dimmer.
Thanks :) |
09-04-2012, 05:44 PM
#2695 |
Rides a dirty bike
Oddometer: 1,420
I have a question about the available mounts:
You offer a Heavy Duty bracket: ![]() And a crash bar mount ![]() Do you need both to use the crashbar mount? I know the light comes with the "standard" bracket, but do you need a bracket and a mount? Thanks. PS: I wish the rotary dimmer knob came off too. A panel mount would be very nice.
Two roads diverged in a wood, and / I took the one less traveled by, / And now where the hell am I? 'Being an adult is so much better when you forget that you're supposed to be boring' (D.Corsetto, 9/7/12) |
09-04-2012, 06:26 PM
#2696 | ||
Purveyor of Light
Oddometer: 3,661
The model 60 has more throw due to having over twice the lumen output as the model 40. Quote:
09-06-2012, 09:13 AM
#2697 |
Purveyor of Light
Oddometer: 3,661
Another happy customer
![]() Model 60s ![]() ![]() Rotary dimmer
09-06-2012, 05:45 PM
#2698 |
Oddometer: 59
Yes-very happy
Those are my pictures above.
I just returned from my first night ride- HID's 55W low and high and 2- M60's to fill in the other areas. I wired it so in low beam the M60's adjust and in highbeam they max blast. John did a great job of immediately getting back to me with any questions I had. Definitely recommend! |
09-06-2012, 10:01 PM
#2699 |
IBA #49986
Oddometer: 211
Just came back from an impromptu saddle sore ride and the 60s are the bomb. A grounding issue took them out for a spell and even with dual hid low beams it was dark. These lights are not to be missed.
09-07-2012, 03:14 AM
#2700 | |
Curmudgeon At Large
Oddometer: 700
Now if you want to talk about tightening the pivot screw on the light bracket........ ![]()
Bob Weis 04 K12RS - Hannigan Hack You rarely see a motorcycle parked outside a psychiatrist's office. Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/ www.earplugco.com |
