Old 10-20-2012, 12:00 PM   #2806
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,846
Winter is coming, I will take him out one of these rainy days
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 10-20-2012, 01:43 PM   #2807
OzRider64
Friggen slow Adventurer.
OzRider64's Avatar
Oddometer: 90
Question Voltage spike with model 44's.
G'day John,
Have read your post where you said my lights had traces of burning on the circuit boards, possibly from cheap HID lights.
I am running a DDM 35W system on my main headlight only, probably not the best quality HID on the market, but others on this site seem to be running them with your lights with no problems.
The model 44's are connected through a PC8 fuse block with a relay and a Cyclenutz mini switch to turn the lights on and off.
How is this voltage spike occurring. Does it happen on start up, because the lights are only turned on after this bike has been running a couple of minutes or does it happen during the running cycle of the bike.
I had a chat to a mate of mine who is a auto electrician and told him my problem and he said to me that my 44's are running through a separate fuse block and relay and I should have no problems.
Both of us are scratching our heads on this one.
Worse comes to worse I will install a HID50 unit into my bike which I have had taken off my previous beast, all I have to do is change the globe to a H7 and I will see how that goes.
I wont re-install these model 44's on my bike till I get this sorted, I don't want to damage them again.
I hope you can clear this up for me.
Simon.
Tassie, where two heads are better than one.
2010 R1200GS
OzRider64 is offline   Reply With Quote
Old 10-20-2012, 01:57 PM   #2808
mastergunnera8
Oddometer: 3
Hello,
Looking to see if someone can help me piece something together for a 2010 Harley Road Glide? These lights look AWESOME!!
Thanks!!!
mastergunnera8 is offline   Reply With Quote
Old 10-20-2012, 09:04 PM   #2809
DirtRider....
Wandering Turtle
DirtRider....'s Avatar
Oddometer: 282
Originally Posted by sanjoh View Post
Looks very similar to the ADVmonster product. The major difference is ours is WATERPROOF. After testing prototypes in the rain and water, they would stop working so I worked with the manufacturer to develop an improved gasket/seal.
What battery does that light run on and what is the connection on the battery (deans or other)?
DirtRider.... is offline   Reply With Quote
Old 10-21-2012, 06:01 AM   #2810
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Originally Posted by OzRider64 View Post
G'day John,
Simon.
Hi Simon,
HID lights use AC downstream of the booster box. In some units it can be as high as 35,000 volts. The voltage can leak from connectors and/or through deterioration of the wiring insulation.
After troubleshooting an HID setup I had a few years back, I took them off the bike. Unfortunately the noise took out the OEM clock and fuel level sensor.
Some folks have had no issues, I have seen several LED lights that have been cooked by aftermarket HIDs, which is why our warranty does not cover installs with HID lights.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 10-21-2012, 06:02 AM   #2811
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Originally Posted by mastergunnera8 View Post
Hello,
Thanks!!!
Give me a call or email
John
sandjoh@gmail.com
954 993 5581
Old 10-21-2012, 06:07 AM   #2812
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Uses a lithium ion which is also waterproof. It can run off your motorcycle as well. Here is one side of the connector:
Connector is waterproof but designed to come apart so wiring is not damaged.
Old 10-21-2012, 10:05 AM   #2813
spagthorpe
spagthorpe's Avatar
Oddometer: 14,749
Hi Simon,
Shouldn't a large zener diode (plus resister) in line with the LED voltage solve this?
spagthorpe is offline   Reply With Quote
Old 10-22-2012, 05:46 AM   #2814
FishinBIG
Oddometer: 12
Order placed for 2 model 60's and rotary dimmer.
FishinBIG is offline   Reply With Quote
Old 10-22-2012, 10:27 PM   #2815
farrington300
No wait....What?
farrington300's Avatar
Oddometer: 527
Anyone using the headlight replacement kit? I am thinking of adding one to my husky.
Also, Sanjon, can you sell the headlight replacement kit without holes drilled in it? I think I can get two lights in there. Or can you make a custom one for me?
TE610
WR250R
farrington300 is offline   Reply With Quote
Old 10-23-2012, 10:05 AM   #2816
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Thanks for your business.
Get one, you will be amazed. Every customer thus far has been extremely pleased with the drop in and shocked by the light output. Everytime I turn on the high beam I laugh
Two lights will not fit in the stock husky setup. I do have the KTM drop in which will fit most 4" square headlight masks, and it will take 2 lights!
If you ship me a mask, I'll make a drop in that handles 2 lights as long as there is adequate space.
Old 10-23-2012, 01:32 PM   #2817
SpeedyK
Lone Rider
SpeedyK's Avatar
Oddometer: 333
I'm thinking of putting a set of your lights on my fairing, want to use them as DRL as well as night enhancement. Does it make sense to put a 30 spot on the outside and a flood on the traffic side? Or could I do two 30's? I want visibility in day and distance at night. Someone probably asked this 100 pages ago, sorry if I don't feel like digging, working on wiring now so I'll be ready for whatever I buy.
Plan is for them to come on with HB, and also have an override switch for DRL use, I'm assembling the relay setup now to test with cheapo WM lights. In my particular case it's easier to integrate it to the headlight relay upgrade I just did.
Thanks for suggestions on which ones.
Quate, Crepa, Rota
SpeedyK is online now   Reply With Quote
Old 10-23-2012, 04:28 PM   #2818
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Model 30s will work fine for you. You should consider one of our LED controllers. Let's you set a dimmed setting for being seen (you will need to dim them at night in traffic) and gives you full power with a flick of your high beam switch. We also offer a free PnP harness when you buy a set of lights with a controller.
Old 10-23-2012, 10:40 PM   #2819
640 Armageddon
-oo-
Oddometer: 2,846
John,
I would like to kindly ask if the internals of the lights will be ok in the long run or if it would be better to open the light and put some silicone over the cicuit. Is there any possibility that the cicuit is damaged due to vibrations when you are racing the bike over very hard terrain ?
640 Armageddon screwed with this post 10-24-2012 at 01:38 AM
Old 10-24-2012, 08:52 AM   #2820
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Originally Posted by 640 Armageddon View Post
John,
I would not hesitate to run the lights over any terrain. All interior components are secured. Many customers are running the drop in lights as their primary light, failure is not an option.
I've run the SE a couple of thousand miles in the last month thru everything from single track to the slab, without issue (except the fuel milage sucks).
Times are GMT -7.   It's 07:58 PM.
