Old 01-05-2013, 09:49 AM   #2971
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,269
Originally Posted by RoundOz View Post
Anyone put one of these units inside a headlight shell? Would enclosing it shorten its life? What about with the extra heat of a headlight bulb or projector light all in the same small space?
There has been a couple of installs in headlight shells. The lights do need some air flow for thermal management.
We do offer a bulkhead mount that let's you mount through a flat surface.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 01-05-2013, 12:07 PM   #2972
WindSailor
WindSailor's Avatar
Oddometer: 744
Pinging for an update - how are you coming on your new set of lights etc.?
WindSailor is offline   Reply With Quote
Old 01-06-2013, 05:22 AM   #2973
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,350
+1
I have a new to me R1150R that needs some lights. This will make 3 1/2 sets of your LED's for me!
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is online now   Reply With Quote
Old 01-06-2013, 07:15 AM   #2974
RoundOz
Plenty of seasoning
Oddometer: 1,016
Sanjoh
Any problem with just unscrewing the back off one of my 44's and replacing the mounting bracket with a thin aluminum plate (with heat sink compound) which will be both an extra large heat sink outside the headlight shell, as well as a custom-shaped mounting bracket bent roughly to the shape of the headlight shell (very little room behind the headlight) ?
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 01-06-2013, 07:28 PM   #2975
lvscrvs
lvscrvs's Avatar
Oddometer: 671
I'd like to mount 2 LEDs on the engine guards on my Tiger ( so they would be somewhat protected in case of a fall). As you can see from the pic below they would be about 26-27" off the deck (bike is on the sidestand in the pic) if mounted on the horizontal flat piece. I would like to have the lights on whenever the bike is running for daytime conspicuity, and at night, so I have better viewing down the road when I have my low beams on ( the low beam on the Tiger is pretty weak, so this is really important). What lights would you recommend?
Thanks,
Brian
Ginormous Beasts go to the Eastside
Tiger 955i / Yamaha WR250R < Tiger 955i / DRZ400S / R1150GS < FJR1300 < DL1000 < BMW R1100RS < Ducati ST4 < DL650 zzzzz 30+ years zzzzz 125 Honda Elsinore < Suzuki TM250 < Yamaha 90 Enduro < Taco
lvscrvs is offline   Reply With Quote
Old 01-06-2013, 07:38 PM   #2976
Downs
KK6RBI
Downs's Avatar
Oddometer: 1,270
Mounted on my F800ST
This is WAY better than the stock headlight could ever do.
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
Downs is offline   Reply With Quote
Old 01-07-2013, 05:38 AM   #2977
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,269
Looking good for ~1/21/13
More info and beam pics coming
Originally Posted by Bobmws View Post
+1
Thanks for being a great customer
Sanjoh
Sounds like it should work ok.
Old 01-07-2013, 05:52 AM   #2978
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,269
Thanks,
Brian
A pair of Model 30s would work great. Look at the F800 pictures on this page, looks like you have a similar height for mounting.
One of our LED controllers with the high beam bypass will give you the DRL and full power options you are looking for. Set it and forget it, the lights come on with the bike in DRL mode, full power at a flick of your high beam switch.
Having put a few thousands mile on the same vintage tiger, most of the stock headlights are way out of adjustment. The adjustment procedure is a bit intimidating but made a huge improvement in my stock headlight. Check out the folks at tiger triple for more info.
A few years ago. Lands End Rd on the Grand Mesa, western CO.
Old 01-07-2013, 11:31 AM   #2979
lvscrvs
lvscrvs's Avatar
Oddometer: 671
Thanks for the tip on the Tiger headlight adjustment, I will check that.
I think the Model 30s would work well for me. I believe I had those on my FJR and they worked great. When I did the FJR install, 2 years ago, I believe I used your Waterproof Switch - no others available at that time - and I was able to cycle the lights through 3 different settings plus off. I just left them at the middle setting and they worked well. Can I still use that switch in that way?
I guess I don't quite understand how I would use the DRL rotary switch... DRL, CCW and PWM are greek to me, but if it means I can run the leds on a dimmer when on low beam, and I will get full led power when on high beam, that seems like a good option.
Thanks again.
Old 01-07-2013, 05:05 PM   #2980
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,269
Nope, the dimming is now external to the light. You get almost unlimited adjustablity of the light output.
Thanks again.
That's it, works just like you described.
Old 01-08-2013, 07:20 PM   #2981
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,870
Just ordered a set of 30's. Looking forward to it!
Jim
Old 01-09-2013, 12:52 PM   #2982
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,440
I've been looking for a home for my original 44/30 combo since I replaced em on the big KTM with 60's...
Just placed the order for another 44 and a few bits and pieces....for my tractor! With the other 44 I will be SET.
Tractor gets here Saturday, the snow moving lights will be the first thing to go on.
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 01-09-2013, 04:56 PM   #2983
Downs
KK6RBI
Downs's Avatar
Oddometer: 1,270
Steve
If you still have that model 30 layin around I'd take it off your hands. I need to add a little more lighting oomph to my DR350.
1978 GS 1000
Old 01-10-2013, 03:18 AM   #2984
Russentreiber
Free-Biker
Russentreiber's Avatar
Oddometer: 15
Wicked Need these un my URAL RANGER :)
Hi everybody ! :)
I found the thread about these Led lights while I was looking for the best way to upgrade my Ural Ranger (it's a Sidecar Rig) and eventually my Yamaha Virago.
From what I read and see it's a pretty impressive kit and fairly priced.
I need to start with the Ural as this is what I use most right now.
What type of lights would you suggest considering that I will begin with placing them on the sidecar nose and the main use for those lights will be on road (maybe adding more after I receive and install the russian windshield ).
I consider the installation both for daytime visibility improvement to other vehicles and night driving. The stock light is pretty poor and I need more uniform illumination of the road.
Russentreiber is offline   Reply With Quote
Old 01-10-2013, 07:50 AM   #2985
Alleycatdad
Oddometer: 1,440
Thanks for that; it's going on the tractor too though. Funny thing about tractors, you gotta have lights on the back, too...
S
Times are GMT -7.   It's 05:38 AM.
