Old 01-21-2013, 01:44 PM   #3016
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,296
Originally Posted by WindSailor View Post
Pinging for an update - how are you coming on your new set of lights etc.?
Originally Posted by Bobmws View Post
+1
I have a new to me R1150R that needs some lights. This will make 3 1/2 sets of your LED's for me!
Originally Posted by sanjoh View Post
Looking good for ~1/21/13
More info and beam pics coming
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 01-21-2013, 07:29 PM   #3017
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,942
What is your intial impression of the lights?
Good quality for the pricepoint, and very good light output. They are small, but nicely plated, and mount easily. Even the wires coming out of them is good quality.
I'll let you know as I get more miles on them, but so far they are great!
Jim
JimVonBaden is online now   Reply With Quote
Old 01-22-2013, 08:37 AM   #3018
michigan400
Oddometer: 94
Update on new lights????
How about a sneak peek at these bad boys huh?
How about some pics
It uses Cree XML T6 leds and a great reflector design. Due to the length of the reflector/optics, we will not use our current form factor / housing. The multiple led lights are larger than our current lights. More to come......
michigan400 is offline   Reply With Quote
Old 01-23-2013, 04:05 AM   #3019
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Jim
Great!
Old 01-23-2013, 06:14 PM   #3020
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Here ya go. Availabe NOW at www.ADVmonster.com
Model 61, single XML T6 LED $40
Model 62, two XML T6 LEDs
Model 64, Beam Me Up
Old 01-23-2013, 07:53 PM   #3021
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
[/QUOTE]
Do you have any mounting point details?
How does this light compare in size to the model 60 (side by side comparison)?
tallguy-09 is offline   Reply With Quote
Old 01-24-2013, 12:49 AM   #3022
paulvandenbogaard
Oddometer: 16
Sanjoh,
the picture of "tree in spotlight" also shows lots of lightning in the area just in front of the bike/setup. Understanding the new models are spot lights I guess this "front lightning" is from another source. Could you explain which ones these are?
To help understand my question please note that I was hoping for a 3600lmn spot but similar in size as the 60 (and other) models. If you have a another picture of "a 60 and the same setup with tree" that would be a nice way to guestimate the difference in light output. Now if that other source would be "only a single 60" we have a fine way to compare
Paul
paulvandenbogaard is offline   Reply With Quote
Old 01-24-2013, 12:58 AM   #3023
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,296
How does this light compare in size to the model 60 (side by side comparison)?[/QUOTE]
More pics & dimensions are on his website.
The new lights look great John, but the 44's with a dimmer suit my need better, order placed.
www.earplugco.com
Bobmws screwed with this post 01-24-2013 at 02:37 AM
Old 01-24-2013, 04:36 AM   #3024
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
The Model 60 is roughly half the size of the M64.
The M64 mounts using a single M8 bolt (included) on pivoting bracket. Here is a picture of the mount.
No front lighting or addtional lighting. The lights have no cutoff. If you look closely at the picture, those are stars in the sky! This is a long exposure (~5 sec) picture to capture all the light output (and it still does not do it justice).
With current led technology a 3600lm spot in the size (55mm diameter) of a model 60 is not possible. Here is the same shot of a model 60.
M64
Thanks for your business Bob.
Old 01-24-2013, 05:38 AM   #3025
Russentreiber
Free-Biker
Russentreiber's Avatar
Oddometer: 15
New models
Here ya go. Availabe NOW at www.ADVmonster.com]
HA !
That's what I call perfect timing on my side !
Oh well... The lights arrived in customs yesterday, hope to receive them soon...
I'll let ya now how it goes!
Russentreiber is offline   Reply With Quote
Old 01-24-2013, 05:53 AM   #3026
michigan400
Oddometer: 94
The single is only 2" x 2" square overall size? So reflector is 1.5 - 1.75" diameter, somewhere in there? That's a perfect size for aux. light IMO.
Those look really, REALLY good, sanjoh!! Then I see $40 for a single unit and my cheap ass almost has a heart attack!!
Old 01-24-2013, 06:14 AM   #3027
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
2" (50mm) square frontal area, length: 3" (79mm), 3" (76mm) from mount to top of light.
1.6" or 41mm
Old 01-24-2013, 07:34 AM   #3028
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
[QUOTE=sanjoh;20563007]The Model 60 is roughly half the size of the M64.
Thank you. I was looking for a side by side picture, both the model 60 and 64 from the front.
Mount seems substantial, the U-bracket is very compact, I guess you can still swivel the light up and down, curious to see more pictures of the light mounted to bikes.
Old 01-24-2013, 07:37 AM   #3029
michigan400
Oddometer: 94
Well I just ordered 2 of the M61's and 2 waterproof connectors. Also just noticed these only pull .6 amps!! Great for me because my trail tech stator puts out only about 110W max. I prefer a H4 headlight for my main light so 60W is gone right away minimum. But,,,, now I can run 2 of these and a 70/65 osram bulb. Perfect!! I really dig the bigger reflector and the fact they are still very small. Can't wait,,, I love new toys!!!
I'll post pics as soon as I can but we are elbow deep in snow now so it'll probably be a while.
Sanjoh, is the model 30 beam approx 15 degrees as well?
Old 01-24-2013, 08:42 AM   #3030
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Let me get a pic. The M64 is much larger and heavier than a M60, due in part to cast aluminum housing on the M64 and the depth of the reflector.
The light will swivel up down on the mount bracket. It will swivel up to 90degrees to mount on a vertical surface.
Times are GMT -7.   It's 07:07 PM.
