Old 01-24-2013, 08:42 AM   #3031
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,665
Originally Posted by tallguy-09 View Post
Thank you. I was looking for a side by side picture, both the model 60 and 64 from the front.
Let me get a pic. The M64 is much larger and heavier than a M60, due in part to cast aluminum housing on the M64 and the depth of the reflector.
Mount seems substantial, the U-bracket is very compact, I guess you can still swivel the light up and down, curious to see more pictures of the light mounted to bikes.
The light will swivel up down on the mount bracket. It will swivel up to 90degrees to mount on a vertical surface.
Old 01-24-2013, 08:43 AM   #3032
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,665
Originally Posted by michigan400 View Post
Well I just ordered 2 of the M61's and 2 waterproof connectors. Also just noticed these only pull .6 amps!! Great for me because my trail tech stator puts out only about 110W max. I prefer a H4 headlight for my main light so 60W is gone right away minimum. But,,,, now I can run 2 of these and a 70/65 osram bulb. Perfect!! I really dig the bigger reflector and the fact they are still very small. Can't wait,,, I love new toys!!!
Thanks for your business.
Sanjoh, is the model 30 beam approx 15 degrees as well?
Yes
Old 01-24-2013, 09:57 AM   #3033
battlecattle
Oddometer: 92
Is there a way to get a static camera shot that shows every light you offer? You did it with the new ones 61, 62, 64 but the 30, 44, 60 have no comparison.
-Josh
http://www.batlecatle.com/
2011 f800GS
battlecattle is online now   Reply With Quote
Old 01-24-2013, 12:28 PM   #3034
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,665
The 30, 44 and 60 all use the same housing and mount system, the internals are the only difference.
Old 01-24-2013, 04:41 PM   #3035
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 782
looks like those square units would be great headlight replacements
2004 Suzuki DL650 Weestrom/2007 BMW F800ST
1998 Suzuki DR350SE
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 01-24-2013, 05:39 PM   #3036
battlecattle
Oddometer: 92
I meant light output.. in the same field as the new ones. Sorry for being unclear.
-Josh
2011 f800GS
Old 01-25-2013, 07:54 AM   #3037
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,665
Great idea!
Coming soon.
Old 01-26-2013, 08:16 AM   #3038
knightbiker63
JK
Oddometer: 1
Question Decision time
Ok...I have read all 203 threads and am now convinced these are the lights I have been looking for. My question for anyone out there is this... I drive my Vstrom 650 65 miles back and forth to work on interstate highway from Rhode Island to Boston, Mass. (mostly highway...some backroads when time permits or traffic is too heavy.), I am torn between two Model 44 or two Model 60 lights...I want to run them day AND night but not blind other drivers. Your dimmable on low-beam and full power on high beam is just what I am looking for also. I do plan some fun rides in VT / NH this summer. Either would improve my drive home at night but I have always felt you can never have too much light when there are deer/coyotes/moose ready to dart in front of you. My off-road use is limited. I guess I am asking for opinions from previous buyers in the same situation. Thanks in advance for all input.
knightbiker63 is offline   Reply With Quote
Old 01-26-2013, 09:07 AM   #3039
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 723
Dont worry, you'll wonder why you waited so long after you see what you have not seen. Just look through this thread and see how many folks are unhappy with these lights.......very few complaints compared to of a whole bunch of "hell yes these are great lights" comments....
pfdskipper is offline   Reply With Quote
Old 01-26-2013, 05:51 PM   #3040
Ned Kelly
Oddometer: 17
Good idea. Would it be possible to put some object in the pictures as well? .... such as a human, motorcycle, or something common so viewers have an object for reference for judging the beams of the various lights? It would help us determine which lights would fit our needs.
Ned Kelly is offline   Reply With Quote
Old 01-27-2013, 02:33 AM   #3041
dljocky
Oddometer: 642
I'm not mechanical at all, but I know I need some AUX lights for my DR650. I'm confused as to how they hook up? Is there a way that I can hook them up so that the AUX lights, when turned on, stay on whether or not I'm running low or high beams? Does one need the "dimmer" switch? Does this dimmer work like the dimmer switch in a car, or is there something else to it, ie, like a dimmer switch a person migh put on their wall switch for a dinning room light?
I was thinking of the getting the Model 30, but since the M61 has come out, I'm now thinking about this. I wonder if I would need a dimmer with the M61's as they put out less light? I'm trying to keep the cost down, while just increasing my night time safety. When I'm riding with my DR650 lights on bright, I almost have sufficient light, so I'm thinking just a bit more and I would be good. Thanks all.
dljocky is offline   Reply With Quote
Old 01-27-2013, 06:46 AM   #3042
michigan400
Oddometer: 22
You can hook them up to work any way you prefer. You would only need a off/on switch of some kind if you want them seperate from main headlight. The dimmer would simply reduce power to the lights,, dimming them in increments. You would pick a setting for dim, and then you switch to high beam they go to full power.
I have a set of m61's coming now and also a model 30 that I've had for a while. I know the 30 is 1500 raw lumen and the 61 is only 900 but due to the much larger single reflector I expect the single 61 will be equal to or greater than a single 30 in terms of useable light. Maybe sanjoh can comment on that better than me. Just my 2 cents.
michigan400 is offline   Reply With Quote
Old 01-27-2013, 08:33 AM   #3043
rollinrob
rollinrob's Avatar
Oddometer: 1,222
Want to put some model 30's or model 44's on my Bandit 1250, probably mount on the holes that the fork mounted reflectors use, like the picture of a model 30 on the web page..
My question is can the light be rotated/clocked in the housing to keep the proper top/bottom orientation of the light beam/spread? Are there any pictures of a light with the yellow Xpel protection?
rollinrob is online now   Reply With Quote
Old 01-27-2013, 08:45 AM   #3044
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,015
Send a message via Skype™ to Low594
Yes the light housing can be clocked in relationship to the mounting bracket, but the beam is round with no top/bottom/side, so it only affects how the face looks when its off and you are looking into it!
'99 KTM 640 Adventure R
East Bay Weekly Coffee
Support your local creep! CREEPS MC
Low594 is offline   Reply With Quote
Old 01-27-2013, 10:59 AM   #3045
SiBC
Oddometer: 3
I am really looking forward to seeing more pictures and reading more info. Really interested in some comments on the effective range of the three new lights. Also, are the new lights compatible with the crash bar mounts, and are there any lens protection for the new light in the works.
I have read the whole thread and waited patiently for the new sets of lights. I am in need of a set of aux lights to help out my poor stock light throughout the range (low-high), and can't decide what's the best setup. Maybe a combo of one Model 60 and one Model 64? Maximum light output is what I want, as far as possible down the road, but also right infront of me.
SiBC is offline   Reply With Quote
Times are GMT -7.   It's 12:25 PM.
