Old 02-26-2013, 08:53 AM   #3151
scooterGdawg
Oddometer: 532
nah, thats a 400......
I'll have to look at the 650 closer, and see how i can mount them...
was hoping someone had already figured it out for me..
thanks
http://myscootlife.blogspot.com
scooterGdawg is offline   Reply With Quote
Old 02-26-2013, 10:56 AM   #3152
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
thanks
Are looking to be seen or primarily to see?
The bolt holding the front fender (in front of the fork) is an easy spot to mount lights.
Thats a big scoot.
Old 02-26-2013, 11:30 AM   #3153
scooterGdawg
Oddometer: 532
mostly to be seen..... that is a recessed bolt tho..
Old 02-26-2013, 11:41 AM   #3154
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Yes it is.
Remove said bolt.
Measure the depth of hole from edge of hole to bottom. Or just get a toothpick and mark the depth onit
Go to the local hardware store and find a bushing that the bolt fits into but the outside is smalller than the fender hole. Choose the bushing length that is longer than the recessed fender hole is deep.
The base of the light mount will use the bushing as a mounting surface.
Lowe's has a great selection of nylon bushings in all kinds of interesting sizes.
Old 02-26-2013, 02:37 PM   #3155
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,321
Originally Posted by sanjoh View Post
Yes it is.
Remove said bolt.
Ace Hardware has some really nice chrome bushings, pricey, but you only need 2, they also have nylon. Be sure to pick up a couple of longer metric bolts while you're there, Ace has stainless bolts with socket cap or button heads.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 02-26-2013, 04:06 PM   #3156
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,411
Or a shoulder bolt from McMaster....
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 02-26-2013, 09:15 PM   #3157
RTinNC
RT to GS in NC
RTinNC's Avatar
Oddometer: 1,035
Model 30 light on Sale 25% off
Normally $60.00 each now $45.00
Don't forget the "inmate" discount. ~$80 for a Quality set (that's a pair) of Lights.
  • Spot Beam
  • 1500 lumens
  • .85amp@12v
  • 3 LEDs
  • aluminum housing
  • Length: 70mm , Diameter 55mm
  • black durable coating
  • o-ring sealed housing
  • one meter wire lead
  • includes flat mount (stainless) mounting bracket
  • glass shatter resistant lens
  • Sold individually
OK .... this put me over the edge and I ordered! At $45 with "inmate" discount I could resist no longer. Hope to mount them up similar to the suggestion on that Burgman using Caliper bolt with a bushing and longer bolt on my GSA. Also opted for the amber or yellow lens guards only because I believe the amber lights are more noticable in the daytime.
Hope they are as good as everyone says!! Thanks!!
Ed Apelian
All it takes is an open road and an open mind!
2006 R1200RT - Granite Gray
2012 R1200GSA - Magma Red!
RTinNC is offline   Reply With Quote
Old 02-27-2013, 03:46 AM   #3158
JayD
JayD's Avatar
Oddometer: 416
Model 30 light on Sale 25% off[/URL][/COLOR][/SIZE][/B]
[/SIZE]
Sanjoh,
I went to your site to order a set of 30s but didn't see the box to enter the discount code to reduce the price from
45.00 down to 40.00 each for inmates
Did I not go far enough thru the process?
JayD is offline   Reply With Quote
Old 02-27-2013, 03:51 AM   #3159
RTinNC
RT to GS in NC
RTinNC's Avatar
Oddometer: 1,035
Originally Posted by JayD View Post
[/B]
Sanjoh,
Exactly ... the coupon code box in about step #3 in check out. You will see it and it worked fine for me. Just follow the check out steps on the site. Simple to use site too.
Ed Apelian
Old 02-27-2013, 04:58 AM   #3160
scooterGdawg
Oddometer: 532
awesome....just the answer i was looking for.......
Old 02-27-2013, 09:21 AM   #3161
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Does anyone know the width of the mount between the ears/tabs of the light?
Old 02-27-2013, 10:19 AM   #3162
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Yellow line
Old 02-27-2013, 10:27 AM   #3163
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Yellow line
You want to offer a compatible LED?
I'm pretty sure it's the same width as for the GSA accessory fog lights.
- Silver bracket width?
tallguy-09 is offline   Reply With Quote
Old 02-27-2013, 04:08 PM   #3164
duffs
I have a beard
duffs's Avatar
Oddometer: 1,207
Originally Posted by tallguy-09 View Post
Hella makes them, 14W. OEM for BMW 63 17 7721320 and now it seems for KTM.
They are more Fog lights than anything else, the only thing I like is the lens which makes them on-road compatible I suppose.
Thanks for getting back and for the detailed pic - much appreciated!
Ride reports: Europe 2014 | Alps 2013 | Fryslân 2012
2012 F 800 GS Trophy 2014 R 1200 GS TE
Blog: Gelände Straßetastic! Facebook Tumblr
Ride reports, photos, tips, experiences, general twaddle
duffs is offline   Reply With Quote
Old 02-28-2013, 05:13 AM   #3165
Shoganai
Let's do some livin'
Shoganai's Avatar
Oddometer: 1,761
Quick question...if everything seems to be connected correctly, why would a dimmer not work?
With the fob, it will turn on/off but will not dim.
Nana korobi ya oki
"Be who you are and say what you feel because those who matter don't mind and those who mind don't matter "- Dr Seuss
Shoganai is offline   Reply With Quote
Times are GMT -7.   It's 01:22 PM.
