Old 02-28-2013, 06:28 AM   #3166
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Originally Posted by Shoganai View Post
Quick question...if everything seems to be connected correctly, why would a dimmer not work?
With the fob, it will turn on/off but will not dim.
Most common reason is the dimmer output to the lights is connected to common ground (ie bike ground), this is a no no. Lights can only be connected to the dimmer on the output side, both positive and negative.
Does the light flash on the fob when adjusting up/down?
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 02-28-2013, 02:38 PM   #3167
Shoganai
Let's do some livin'
Shoganai's Avatar
Oddometer: 1,761
Thank you.
I'll see what I can do to fix it.
Nana korobi ya oki
"Be who you are and say what you feel because those who matter don't mind and those who mind don't matter "- Dr Seuss
Shoganai is offline   Reply With Quote
Old 03-01-2013, 06:25 AM   #3168
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Thank you.
Give me a call or email if you need help.
Old 03-01-2013, 08:03 AM   #3169
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Model 30 light on Sale 25% off
Normally $60.00 each now $45.00
Don't forget the "inmate" discount. ~$80 for a Quality set (that's a pair) of Lights.
  • Spot Beam
  • 1500 lumens
  • .85amp@12v
  • 3 LEDs
  • aluminum housing
  • Length: 70mm , Diameter 55mm
  • black durable coating
  • o-ring sealed housing
  • one meter wire lead
  • includes flat mount (stainless) mounting bracket
  • glass shatter resistant lens
  • Sold individually
Old 03-01-2013, 08:55 AM   #3170
Jnich77
Jnich77's Avatar
Oddometer: 817
Ordered my two model 30's midday on Wednesday, they arrived Thursday morning, were on by noon :-)
Jnich77 is offline   Reply With Quote
Old 03-01-2013, 01:56 PM   #3171
WindSailor
WindSailor's Avatar
Oddometer: 757
Finally got my M64's mounted. I disconnected the original aux lights and used that wiring to power these through a controller. Everything seems to work so I must have wired them right. No canbus issues or warnings - not even sure if that circuit is monitored by the canbus. I used the low beam as a switched power source so the M64's wont come on until the bike is running - and - the aux light switch is on. I may change that later, first configurations are always... trial and error.
I haven't used them at night yet - but they look like they will have enough light to suit my needs.
Looks like a night time aiming procedure should be next. These look like they're aimed a little high... Foggy day on the beach this afternoon.
Mounting the lights forward of the radiator like in the previous photo gave off a lot of turbulence going into the radiator when you get up to speed.
Made a different set of mounts to bolt up to the original OEM aux lights. This works A LOT better. And looks better too. I'm going to keep this setup in the picture below.
WindSailor screwed with this post 03-08-2013 at 01:52 PM
WindSailor is offline   Reply With Quote
Old 03-01-2013, 04:14 PM   #3172
Ned Kelly
Oddometer: 27
WindSailer, be sure to post some night pics please!
Ned Kelly is offline   Reply With Quote
Old 03-01-2013, 06:36 PM   #3173
JayD
JayD's Avatar
Oddometer: 417
Originally Posted by RTinNC View Post
Exactly ... the coupon code box in about step #3 in check out. You will see it and it worked fine .
Ordered some, Thanks Ed
JayD screwed with this post 03-01-2013 at 06:45 PM
JayD is offline   Reply With Quote
Old 03-01-2013, 08:03 PM   #3174
snorty
no-diggety
snorty's Avatar
Oddometer: 156
That's a deal! I just ordered a set to replace some IPV halogens that work great but are hard on the battery.
Pixel pusher and cat herder | Cary NC
snorty is offline   Reply With Quote
Old 03-01-2013, 08:40 PM   #3175
WindSailor
WindSailor's Avatar
Oddometer: 757
Here is a few quick pics with an Instamatic . It's hard to get good pics on the right road and right distance to show how they truly are.
Low beams on (HID on both low and high).
High beams on with the M64's on at 100%.
They look like they will reach out to 300 ft, just what I wanted. I didn't have time to measure just how far that pole was because there was too much traffic, besides I was next to someones house and it was late at night. Didn't want mr. shotgun coming outside.
Interesting note; I had more people 'bright' me running the M64's at 10% at night than during the day time. Makes sense now that I think about it (people are more sensitive to a spot LED at night than during the daytime) - didn't foresee that one though. This may be an instance where the rotary dimmer would be handy.
WindSailor screwed with this post 03-01-2013 at 09:52 PM
Old 03-01-2013, 08:44 PM   #3176
GordonFreeman
Gamer
GordonFreeman's Avatar
Oddometer: 1,652
Do you still stock the headlight replacement for KTM 530 2010? I really liked the looks of getting a model 60 in the headlight but didn't order one last year when I first saw them. Your site only lists the kit for the older KTMs and the Husky. Thanks!
GordonFreeman is offline   Reply With Quote
Old 03-02-2013, 01:21 AM   #3177
Jazz62
Jazz62's Avatar
Oddometer: 1,061
I highly recommend the rotary dimmer. It's hard to tell exactly from the pics but if you have the M64's aimed at the same angle you show in your first pic then that's why you are getting flashed by oncoming drivers. I think a couple of a degrees forward of 90 degrees and you'll be good.
Jazz62 screwed with this post 03-02-2013 at 01:29 AM
Jazz62 is online now   Reply With Quote
Old 03-03-2013, 04:38 AM   #3178
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
  • Spot Beam
  • 1500 lumens
  • .85amp@12v
  • 3 LEDs
  • aluminum housing
  • Sold individually
Old 03-03-2013, 05:03 AM   #3179
Unstable Rider
Moto Fotografist
Unstable Rider's Avatar
Oddometer: 2,669
Dang, sweet deal!
First the Earth cooled. Next came rats, cockroaches and KLR's... and life was good.
Unstable Rider is offline   Reply With Quote
Old 03-03-2013, 07:36 AM   #3180
hatfirst
Oddometer: 31
got mine
Got mine in the mail yesterday 3 day's after order placed. Thats quick work thanks.
hatfirst is offline   Reply With Quote
Times are GMT -7.   It's 01:02 PM.
