Old 03-03-2013, 06:33 PM   #3181
Boris4ka
Oddometer: 5
Any plans of making a projector lens for these lights so there's a cutoff like with HID's?
Boris4ka is offline   Reply With Quote
Old 03-04-2013, 03:53 AM   #3182
SiBC
Oddometer: 19
After much thinking and jumping from one model to another in the decision process I finally settled. Just placed an order for two M62 with crash bar mounts and rotary dimmer :)
Sent from my iPad using Tapatalk HD
SiBC is offline   Reply With Quote
Old 03-04-2013, 11:08 AM   #3183
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Not at the moment.
Thanks for your business.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 03-04-2013, 11:41 AM   #3184
WildmanSam
WildmanSam's Avatar
Oddometer: 98
man... they went on sale a couple days after i got mine at full price... and there's an inmate discount??
think you can hook up a deal if i buy some model 60's?
WildmanSam is offline   Reply With Quote
Old 03-04-2013, 11:45 AM   #3185
Craneguy
British Hooligan
Craneguy's Avatar
Oddometer: 1,040
Ordered a pair of Model 30 Spots. Great service, great price and incredibly prompt shipping.
Thanks John!
Young enough to think I can. Old enough to know I shouldn't. Stupid enough to do it anyway
'13 Duc Multi GT, '10 Vstrom 1k, '10 705cc KLR
Craneguy is offline   Reply With Quote
Old 03-05-2013, 05:22 PM   #3186
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Certainly
Thanks John!
Thank you
Old 03-05-2013, 08:28 PM   #3187
Downs
KK6RBI
Downs's Avatar
Oddometer: 1,271
I'm thinkin of ordering a model 60 or 44 and replacing one of my model 30 spots so I have one model 30 spot beam and one flood beam
Sent from my iPhone
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
Downs is offline   Reply With Quote
Old 03-05-2013, 08:32 PM   #3188
Boris4ka
Oddometer: 5
I can't decide which light or combo of lights to buy. It's for a DRZ400 SM and the lights will mostly be used on the freeway and highway. I'd like a combo of spot and flood, but my bike can't support much, and I don't want to spend too much money. I bought a Model 30 two years ago but the bike it was on got stolen.
Ideally I'd like it to illuminate the sides as well, so if the bike's leaning I can see into the turn. Should I get an M61 for each side, and an M62 for the front? Or do you think a single M64 would work? At that point the M64 would be significantly cheaper and put out the same amount of light as the three light combo. Or should I do some combo of Model 30s? So many choices!
Old 03-05-2013, 10:07 PM   #3189
RTinNC
RT to GS in NC
RTinNC's Avatar
Oddometer: 1,075
Caliper Mount Question
Anyone have pictures of Caliper mounts for the 30's? Got a set for my '12 GSA and having difficulty getting them mounted to the calipers since the GS does not have fender bolts that work. I am planning on making some "L" brackets and then getting longer M8 caliper bolts with a spacer or bushing but looks like most of that I'd need fabricate so wondering if anyone has done this type mount before. Thanks in advance.
Oh ... and I ordered the HD brackets but when installed I see they create a somewhat ugly gap in the light housing ... I thought of using an O-ring to fill the gap. Has anyone else dealt with this issue. Yes ... I am pretty anal about how stuff looks and the gap in the housing just detracts for the look of the lights.
Ed Apelian
All it takes is an open road and an open mind!
2006 R1200RT - Granite Gray
2012 R1200GSA - Magma Red!
RTinNC is online now   Reply With Quote
Old 03-06-2013, 04:51 AM   #3190
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
A flood light will help light up the sides of the road.
The DRZ puts out 180watts stock. I'd recommend a model 30 and 44 for a total of 30 additional watts on full power. I think the M62 and M64 are a bit large for a bike the size of a DRZ.
Oring should work to fill the gap.
Old 03-07-2013, 06:41 AM   #3191
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Another happy customer
Old 03-08-2013, 01:14 PM   #3192
WindSailor
WindSailor's Avatar
Oddometer: 744
Relocated my lights to use the original OEM aux light mounts (had to fabricate a piece to bolt to the original mount). This works tons better and looks better too.
WindSailor is offline   Reply With Quote
Old 03-08-2013, 01:19 PM   #3193
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
I like it better now, however, you still need to crank up the engine hp a bit to overcome the wind resistance, personally it's a bit too much for me. I went from no lights to way too many lights (lights everywhere), back to only a set of 60s and that's it for me.
tallguy-09 is offline   Reply With Quote
Old 03-08-2013, 02:46 PM   #3194
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Sanjoh, do you have wide beam lenses or prismatic lenses available for the 61 or 62? Id like to use them for close cornering lights.
Danjal is offline   Reply With Quote
Old 03-08-2013, 03:41 PM   #3195
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,272
Model 30 light on Sale 25% off
Normally $60.00 each now $45.00
Don't forget the "inmate" discount. ~$80 for a Quality set (that's a pair) of Lights.
  • Spot Beam
  • 1500 lumens
  • .85amp@12v
  • 3 LEDs
  • aluminum housing
  • Length: 70mm , Diameter 55mm
  • black durable coating
  • o-ring sealed housing
  • one meter wire lead
  • includes flat mount (stainless) mounting bracket
  • glass shatter resistant lens
  • Sold individually
The Model 44 or Model 60 will give you a wide beam.
Times are GMT -7.   It's 07:11 PM.
