Old 03-12-2013, 02:03 PM   #3211
Dusty_Bottoms
Adventurer Ordinaire
Dusty_Bottoms's Avatar
Oddometer: 843
Excellent.
Incomiiiiiing!
COHVCO #7369
Dusty_Bottoms is offline   Reply With Quote
Old 03-12-2013, 08:39 PM   #3212
ewagman
Oddometer: 31
Originally Posted by sanjoh View Post
Model 60 and 30 compliment each other very well, although most customers have found a pair of 60s to be awesome. Lots of lighting to the sides and plenty of distance.
Which would have the greater distance reach, a pair of 60's or a 60 with a 30?
ewagman is offline   Reply With Quote
Old 03-13-2013, 06:00 AM   #3213
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 03-14-2013, 05:41 AM   #3214
patrick1
patrick1's Avatar
Oddometer: 48
Crash Bar Light Mount
Does anyone have pics of lights mounted with the "Crash Bar Light Mount" Im trying to work out where i can mount my set of Model 60's on my sv1000.
Already broken a set of the heavy duty mounts (different bike) so thought I might give the crash bar mount a go.
This is the one im taking about
http://stores.advmonster.com/-strse-...unt/Detail.bok
patrick1 is offline   Reply With Quote
Old 03-14-2013, 04:16 PM   #3215
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Here's a beautiful GS with the crashbar light mounts.
Old 03-15-2013, 12:13 AM   #3216
patrick1
patrick1's Avatar
Oddometer: 48
thanks, so would i need a set of standard or HD mounts to mount the light to the the crashbar mount? Can't quite tell
Old 03-15-2013, 03:51 AM   #3217
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Either mount will work fine. The HD mount is a much thicker version of the standard mount, otherwise the geometry is the same.
Old 03-15-2013, 07:48 PM   #3218
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
What year is your SV?
Perhaps under the mirrors?
Old 03-15-2013, 08:48 PM   #3219
TonyfromOR
TonyfromOR's Avatar
Oddometer: 65
Question
[SIZE=2]Don't forget the [SIZE=2]"inmate" discount. ~$80 for a Quality s[SIZE=2]et (that's a pair) of Lights.
OK, so what do I enter in the coupon code to get the "inmate" discount?
TonyfromOR is offline   Reply With Quote
Old 03-16-2013, 03:53 AM   #3220
SiBC
Oddometer: 19
You enter "inmate". Doesn't know if it is supposed to be capital i or not, but you will figure that out.
Sent from my iPad using Tapatalk HD
SiBC is offline   Reply With Quote
Old 03-16-2013, 04:59 AM   #3221
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
What's inside the quotes
Put it in during checkout in the promotion code box, typically on the left side of the screen. Discount should show up.
Old 03-16-2013, 05:10 AM   #3222
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,739
I just ordered the lights you have on special. Thanks too for the ADV discount. They will be going on an '06 Tiger. Will the supplied flat mount work for me, or will I have to break out the MIG and build something myself? Thanks again.
There's something kinda sad about, the way that things have come to be. Desensitized to everything, what became of subtlety?
fyrfytr is online now   Reply With Quote
Old 03-16-2013, 09:17 AM   #3223
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Model 30 light on Sale 25% off
Normally $60.00 each now $45.00
Don't forget the "inmate" discount. ~$80 for a Quality set (that's a pair) of Lights.
  • Spot Beam
  • 1500 lumens
  • .85amp@12v
  • 3 LEDs
  • aluminum housing
  • Length: 70mm , Diameter 55mm
  • black durable coating
  • o-ring sealed housing
  • one meter wire lead
  • includes flat mount (stainless) mounting bracket
  • glass shatter resistant lens
  • Sold individually
Old 03-16-2013, 09:19 AM   #3224
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Thanks for your business!
The included mount will mount to a 6mm stud or flat surface 25mmx25mm with a bolt.
Old 03-16-2013, 09:33 AM   #3225
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,739
You're welcome, just got the e-mail that they shipped. That's awesome!
I think I might be able to do something with the mount. There's lots of bolts on the front fender.
Times are GMT -7.   It's 05:58 PM.
