Old 04-29-2013, 02:05 PM   #3346
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Originally Posted by Oddfellow View Post
I have been fighting the HID lamps in this headlight ever since I bought my XR650R (it came with it on):
I see lamps to replace the top two in the image above, do you have a wider angle I could use for the 4" SC4? Inquiring minds want to know!
We don't offer a 4" light. Do you have a pic of the rear of the light? Might be able to easily adapt a third light in that position.
Old 04-29-2013, 06:53 PM   #3347
Oddfellow
Beasty Rider
Oddfellow's Avatar
Oddometer: 492
I'll try and get some pics of the housing opened up this weekend. There is room to spare for typical MR16 Halogens in the upper two spaces. Overall the housing is maybe 2.5 inches deep.
Oddfellow
'06 Suzuki DR200SE
'05 Honda XR650R
'14 KTM 690 Enduro R
Oddfellow is offline   Reply With Quote
Old 05-03-2013, 08:20 AM   #3348
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Depth should be fine.
Pics of the back?
Old 05-06-2013, 11:22 PM   #3349
Goofy Footer
Oddometer: 564
Originally Posted by Wattner View Post
AdvMonster Pr0n
I'll mount them up when I get back home.... I have a set of 60's on the Bars, but it will certainly be overkill. May just leave them on for a few rides of ridiculous???
Kudos AdvMonster!!! AWESOME:
I need a tiny AdvMonster sticker to replace the Cyclops sticker...
More pic's to follow after they are mounted
Woa I Really like this, great job! I have a BD 8" La Paz Halogen light and I love the 8" racelight look but want LED efficiency. I'll be following this thread for more info on such conversions.
Also, can one order those flush mount adapters for your lights?
For instance, I have a TW200 with a 4x6 halogen headlight. I think one could make a replacement light with a lexan or other plastic (metal even) lense bolted into the stock mounting points. The key would be the flush mount kits. A model 30 for driving spot (possibly on dimmer) and 44 for flood on high beam could fit in the 4x6 and look good (imo).
Goofy Footer is offline   Reply With Quote
Old 05-07-2013, 10:22 AM   #3350
HiHOSilverGS
overthehilldirtbiker
Oddometer: 10
Shipping fee at ADVMonster
After doing some research for driving lights and reading the posts here on ADVRider,
I just started to buy some lights on ADVMONSTER and had to stop shopping after I saw the ridiculously high shipping costs.
HiHOSilverGS is offline   Reply With Quote
Old 05-07-2013, 11:43 AM   #3351
ewagman
Oddometer: 31
Have you paid to ship something yourself since the last price hike? I was amazed the last time I mailed a package how much the post office hiked rates. UPS is also expensive now too, no way around it, it seems.
I haven't bought lamps from ADVMonster in almost a year, kinda po'd at myself for missing the very recent sale price on the 30's.
ewagman is offline   Reply With Quote
Old 05-07-2013, 12:30 PM   #3352
thetable
thetable's Avatar
Oddometer: 1,458
Did you try putting in your Zip code? Shipping is quite reasonable.
thetable is offline   Reply With Quote
Old 05-07-2013, 12:40 PM   #3353
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
We use USPS Priority or First Class mail.
You likely did not move through the checkout process far enough to get an estimate of shipping. Typical cost to ship a pair of lights to anywhere in the US is 7-12 usd.
Old 05-07-2013, 02:05 PM   #3354
dsc522758
dsc522758's Avatar
Oddometer: 20
12v fused source
Any other 12v fused source not mentioned in the documentation? That 12v wire coming from the rotary is a bit short to get anywhere. You mentioned the horn circuit. The horn switch won't work will it?
2009 Kawasaki KLR 650
dsc522758 is offline   Reply With Quote
Old 05-07-2013, 03:35 PM   #3355
dsc522758
dsc522758's Avatar
Oddometer: 20
Since I am trying to wire with highbeam bypass do I need to go by some wire at Radio Shack and some type of spade connectors and run a hot to a relay of some sort from the battery hot and then run from relay to 12v marked on the rotary switch? I guess ground works the same. Bike is in pieces in the garage until I get this figured out.
Old 05-07-2013, 03:53 PM   #3356
dsc522758
dsc522758's Avatar
Oddometer: 20
Relay also? 44 divided by 12.5 = 3.52 x 1.25=4.4 10A inline fuse I guess?
Old 05-07-2013, 05:25 PM   #3357
Mike Honcho
Got Beaver?
Mike Honcho's Avatar
Oddometer: 2,411
QFT..... Sanjoh sells a great product. I got in the last 30 sale and man are those things bright. I'm running no dimmer with the lights down on the fork. I leave home in the dark and these lights are soooooo much better to ride with.
Sanjoh's a stand up man. I've met him and he stands behind his product.
I'll be back for another set once the funds are available.
Mike Honcho is offline   Reply With Quote
Old 05-08-2013, 06:04 AM   #3358
scooterGdawg
Oddometer: 532
i don't know much about wiring and such, so i hope someone can help me here.
I have bought a pair of ADV 60's and have them installed already,
I have a set of adv 30's to add as well....
the questions is, can i run all 4 lights on the same power wires that run to the fuze block? i used 18ga wire and would like to just tap into the same wires.
http://myscootlife.blogspot.com
scooterGdawg is offline   Reply With Quote
Old 05-08-2013, 06:32 AM   #3359
jeepinbanditrider
KK6RBI
jeepinbanditrider's Avatar
Oddometer: 1,262
You should be good with the 18 gauge for that load. It's only around 50 or 60 watts for all four lights IIRC. Someone will be along to correct me if I'm wrong soon though
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 05-08-2013, 07:00 AM   #3360
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
No problem with 18g and all four lights. 76 watts at max power. Here is a good reference.
Times are GMT -7.   It's 03:57 PM.
