Old 05-10-2013, 04:41 PM   #3376
Bengt Phorks
Oddometer: 247
Originally Posted by bill1960 View Post
Going by your recommendations, it seems two lamps as per the dualsport fairing is optimum.
If I don't run the fairing, what other mounting options would you suggest for two lamps on the KTM 500xcw
and
What configuration of two lamps would give the best light pattern, ie, one spot and and one flood etc....?
I have a single model 60 mounted in the headlight shell on my KTM 500 EXC and it is more than adequate for street or dirt. You will not out run this light. Put two on only if you need to see into the next county.
Bengt Phorks is offline   Reply With Quote
Old 05-10-2013, 05:11 PM   #3377
Goofy Footer
Oddometer: 560
Sweet, thanks for the info. Are you running a dimmer for the 60 on street?
I'm considering doing a similar thing by replacing my stock halogen with an led. Sanjoh or anybody else, how would one 60 compare to a 30 & 44 combo as the sole light source for a dirtbike that is also run on street?
Thanks in advance!
Goofy Footer is offline   Reply With Quote
Old 05-10-2013, 05:57 PM   #3378
bill1960
Oddometer: 365
Yeah, I discussed various options with Sanjoh and on his advice ordered the single 60 led for my 500xcw.
He doesnt make the mounting panels for the 500 anymore so I ordered the lexan sheet and hardware from him to make it myself.
Have you got pictures of your install ?
I'd be interested to see the position and angle that the 60 led was mounted in the 500 oem headlight mask.
bill1960 is online now   Reply With Quote
Old 05-10-2013, 09:14 PM   #3379
Bengt Phorks
Oddometer: 247
Goofy Footer, Yes I am running the adjustable dimmer for the low beam and using the stock KTM headlight switch.
Bill, I will try to post some pictures in the next few days as soon as I take them. I made up my own mount by modifying the stock headlight assembly. The end result is that it looks OEM.
Old 05-10-2013, 11:55 PM   #3380
bill1960
Oddometer: 365
Sounds good. Look fwd to the pics.
Old 05-11-2013, 04:35 PM   #3381
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,650
I used a Model 60 HERE
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 05-13-2013, 03:14 PM   #3382
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Old 05-15-2013, 09:26 PM   #3383
Bengt Phorks
Oddometer: 247
KTM 500 EXC with ADVmonster Model 60 light
Here is my KTM headlight modified for a Model 60 Light. It has a low beam with the dimmer control. This was a test prototype to see if it would work and how durable it would be. I used the stock mounting points and headlight aiming mount. It has survived 6 months of riding, racing and crashes.
The pictures are worth a thousand words....
Finished product.
Back side.
Ground off mounting lugs and enlarged center hole.
Light assembly.
Light mount made from Delrin plastic. Snug fit on headlight ring to keep it in position and keep out water and dust. An alternative would be to use a flat aluminum or plastic plate as in post# 3385.
Mount details. It's over built for what it has to hold.
Headlight Assembly.
Old 05-15-2013, 10:10 PM   #3384
bill1960
Oddometer: 365
Finished product.
BP
Very well thought out and looks great.
I like how the oem lens assembly provides protection for the LED, and aims/mounts it at the correct angle.
I'd be interested in what Sanjoh thinks about the lack of airflow to the Led and any possible overheating problems in the long term.
I do note however that you've been using it for 6 months like that.
Thanks for the post/pics, explains the install very well
Old 05-16-2013, 06:09 AM   #3385
Goofy Footer
Oddometer: 560
Excellent work guys! These are great setups! I love that they keep the stock look (and wattage pull) while putting out way more light. Thank you especially for the fabrication pictures they are a huge help!
Old 05-18-2013, 04:25 AM   #3386
sp9997
sp9997's Avatar
Oddometer: 18
regarding heavy duty brackets.
Hey Sanjoh,
I ordered Model 30 when they were on sale with the heavy duty brackets. You were out of stock on the brackets and shipped the lights with regular brackets. Have you got the brackets back in stock... I tried to email you twice, PM you once ...gee even tried to call the number on your website... No replies on any front !!!
Please let me know what is the ETA for the heavy duty brackets... whey would they be in mail??
Regards,
SP
sp9997 is offline   Reply With Quote
Old 05-20-2013, 06:04 AM   #3387
univibe88
Slidell4Life
univibe88's Avatar
Oddometer: 2,341
Has anyone posted a schematic for the Rotary LED Dimmer with High Beam Bypass? Or at least a picture of the whole kit. The website pictures don't show all the wires.
Is this a full wiring harness with a relay? I already have my lights hooked up with a standard wiring harness (tap into 12V power which hits a relay to draw power back from the battery.)
Does this dimmer somehow splice into my existing wiring harness? Or does it replace it?
Also, why does the description say "replaceable battery"? I am hoping that is a typo. Would would a wired switch need a battery?
List of my old bikes that no one cares about
Current bikes go here to make others jealous
"I like my ride plans like my women...loosely put together with a chance of getting wet."
univibe88 is offline   Reply With Quote
Old 05-20-2013, 06:49 AM   #3388
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Originally Posted by sp9997 View Post
Hey Sanjoh,
Regards,
SP
A guys gotta ride!
HD brackets should be in the mail late this week or early next. We will send an email when they ship.
Old 05-20-2013, 10:15 AM   #3389
sp9997
sp9997's Avatar
Oddometer: 18
thanks
Originally Posted by sanjoh View Post
A guys gotta ride!
Couldn't agree more ... We are on accelerated riding schedule here in chi-town... Thanks for the reply...
Old 05-20-2013, 12:21 PM   #3390
bill1960
Oddometer: 365
Originally Posted by Goofy Footer View Post
Would mounting the 60 LED flood inside an OEM lens, as per the pics, focus the light into a narrower area ?
Times are GMT -7.   It's 06:12 AM.
