Old 07-07-2013, 03:03 PM   #3436
SoilSampleDave
Oddometer: 1,993
I want to order a replacement headlight style "drop-in" LED light for my '13 KTM 350EXC, but I only see it for the older KTM's on your web site. I thought you had the same for the newer bikes? Please let me know so I can get it on order.
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is online now   Reply With Quote
Old 07-08-2013, 02:51 PM   #3437
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Nice to talk with you earlier. We are redesigning the headlight replacement for later model KTMs, expected to be available mid August.
Old 07-09-2013, 05:26 AM   #3438
zeeede
Oddometer: 1,007
After riding through the back roads of New Hampshire at night, and expecting to do a little more night riding this season, I decided to upgrade the lighting on my Vstrom. Just ordered two model 44's, the dimmer switch, a couple of crash bar mounts, and a couple of waterproof connectors. Can't wait to get 'em all wired up.
You should stock and sell relays on your website as well... save me a trip to the parts store!
zeeede is offline   Reply With Quote
Old 07-09-2013, 09:45 AM   #3439
trapperj
Oddometer: 495
Relays?
I've installed 2sets of model 60s 1 set of 40s on three separate bikes...I didn't use a relay on any. Do you need a relay? Mine work great without...15 k on the GS...even more on the KLR and nearly 6k on the Husquvarna TR..it has the rotary dimmer the GS has the key fob.
trapperj is offline   Reply With Quote
Old 07-09-2013, 09:48 AM   #3440
zeeede
Oddometer: 1,007
Need? Probably not. Especially not with the draw from LEDs. I've just gotten into dinking around with electrical stuff lately, and I've got room under the seat on the big Vee for things like relays. Plus it's a trendy thing on ADV these days, having relays...
Old 07-09-2013, 09:52 AM   #3441
michigan400
Oddometer: 94
Use a relay if your amp draw will exceed the rating for the switch you are using. 1 or 2 LED lights, even model 60's, would be fine without one on their own separate circuit. But, if you have them wired to come on with a halogen or HID high beam for example, then you will probably want one. Even the cheapest bar mount switches will handle 5-7 amps.
michigan400 is offline   Reply With Quote
Old 07-09-2013, 11:32 AM   #3442
SoilSampleDave
Oddometer: 1,993
Then the KLR guys would complain they are 30 cents higher than at AutoZone
'14 690R
Old 07-10-2013, 04:46 AM   #3443
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Thanks for your business!
I am just finishing installing lights on my new to me Vstrom. Let me know if you have any questions.
Old 07-10-2013, 05:32 AM   #3444
zeeede
Oddometer: 1,007
Yeah...where'd you mount 'em? I'm trying to find a place to put 'em that won't cause any damage when my Vstrom takes naps. I ordered the crash bar mounts... I don't think there's enough room to mount them inside the crash bars, but I'm thinking if I hang them off the front of the bars maybe they'll be protected and also not damage the fairing?
Old 07-10-2013, 05:38 AM   #3445
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Mounted em on the front fender bolt. Routed wire up the brake line.
Other mounting options: Reflector bracket on lower fork, twisted throttle light mount under the fairing
Old 07-10-2013, 06:37 AM   #3446
kbuckey
Oddometer: 846
I love the 60's as headlights on the DR with the Dual Sport Fairing. Thinking of the 44's for the FJR as aux lights. Have to figure where to mount them, and the switch.
kbuckey is offline   Reply With Quote
Old 07-10-2013, 06:57 AM   #3447
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 1,238
Make a plate that sandwiches between the mirror and fairing. Gets them nice and high and able to really throw the light down the road.
Sent from my iPhone
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 07-10-2013, 09:32 AM   #3448
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Some customer pics FJR1300
Old 07-11-2013, 05:35 AM   #3449
zeeede
Oddometer: 1,007
I like the location of the fender bolt, but I worry that's a spot that'll hit the ground when my Vee gets sleepy. The Twisted Throttle bracket is probably the most protected, but I don't like that the lights are so close to the headlights.
My lights got delivered this morning according to the tracking (woohoo - wicked fast service!) so I'll play around with the crash bar mounting and see if I can come up with something tonight.
Old 07-11-2013, 01:40 PM   #3450
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
In general, the closer to the centerline of the bike, the more protection lights will have. I don't think the fender mounted lights are in jeopardy.
The twisted throttle mount is reasonably priced steel. It mounts to the fairing subframe so it has some rigidity.
Times are GMT -7.   It's 11:27 PM.
