Old 09-09-2013, 07:00 PM   #3526
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Originally Posted by JustinP View Post
Is that a remote dimmer, or rotary dimmer? I'll be ordering a pair of m64's to add to my model 60's. The m64's will be replacing my model 30's. Would be interested in testing the new dimmer, since the one I have can't handle 4x 2.4 amps.
Also - what is the weight of the M64 versus the model 30 format?
And, if you order a set of the m64's wit ha dimmer, do they come "plug and play"?
M64s are heavy, don't have the weight handy, will post up tomorrow. Yes on the plug n play, will need an approximate length lead you will need as the light come with a 10" lead standard.
Old 09-09-2013, 07:01 PM   #3527
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Originally Posted by Ceemack View Post
I've suddenly got an issue with my rotary dimmer. I'm fine on low-beam, but when I hit the high-beam switch the LED lights go out.
Any suggestions?
Check connections first. Do the lights go to full power when rotary knob is put on full ouput?
Old 09-09-2013, 09:58 PM   #3528
Ceemack
Oddometer: 76
Yes, on low-beam they'll go from full brightness to nothing, depending on how the knob is turned. They've worked perfectly until this weekend.
I haven't had a chance to test the wire I've got spliced into high-beam circuit, which in turn is connected to the purple wire on the dimmer. I'm a little puzzled as to why they'd go out completely once the high-beam circuit was activated.
Ceemack is offline   Reply With Quote
Old 09-12-2013, 10:26 AM   #3529
JustinP
JustinP's Avatar
Oddometer: 1,721
Decided on the M62 lights to replace the model 30's. Looks like it will be a decent upgrade for the spots. As usual, put more order in and it was shipped within an hour.
FAST: 2004 non-ABS "Silver Bullet" FJR - FASTER: 2008 Touring/Endurance Hayabusa - SLOW: 1997 R1100GS
Quality LED Lighting - ADV Discount inside:) - LEDRider LED motorcycle lights
JustinP is online now   Reply With Quote
Old 09-13-2013, 09:38 AM   #3530
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Thanks for your business
Old 09-15-2013, 06:35 AM   #3531
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Great to hear you sorted the issue.
On many dirt oriented bikes, the low beam circuit turns off when the high beam is activated. A diode between the high and low beam positive wires will make for constant power to the lights.
Old 09-15-2013, 04:14 PM   #3532
George 99
George 99's Avatar
Oddometer: 776
I'm gonna need to add a diode to keep the 44 lit when the hi-beam 60 is on as my low-beam dimmer doesn't have the bypass.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 09-15-2013, 07:20 PM   #3533
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Take a look at the power connector/harness for the dimmer, I think we included it in your setup.
Old 09-16-2013, 06:03 AM   #3534
daveburton
Oddometer: 179
Just bought the model 60s
Thanks all for the feedback I have been able to benefit from. Just bought 3 x 60s (one spare) with brackets and dimmers etc.
I hope to have them fitted to my GSA for a ride from Montevideo to Iguassu falls on the border with Argentina. I'll let you know how it works out.
One question, with this setup would a set of spots be a significant improvement for distance. If so what are the options for spots.
cheers dave
daveburton is offline   Reply With Quote
Old 09-16-2013, 09:53 AM   #3535
JustinP
JustinP's Avatar
Oddometer: 1,721
I run a set of Model 60's and a set of M62 spots. The spots make a huge difference for long distance light.
Old 09-16-2013, 03:14 PM   #3536
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
cheers dave
Thanks for your business!
Extra xpel for the 3rd light included for free
Old 09-16-2013, 05:20 PM   #3537
daveburton
Oddometer: 179
62s and 60s
Thanks for the feedback Justin, which bike are they on and do you have any photos I could have a look at.
I might buy the spots and replace my std GSA aux lights with the 62s.
cheers dave
Old 09-16-2013, 09:42 PM   #3538
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,024
I want to mount a 60 to my helmet.
Got any helmet mount brackets available ?
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 09-17-2013, 01:02 PM   #3539
Number6
mad as hell
Number6's Avatar
Oddometer: 30
I was originally interested in the 24W dimmable floods, but kept reading through the few thousand posts here and now suspect they are unavailable. I do a lot of street riding so I want something I can run into oncoming traffic on the low beam and then light up the night on high beam. WOuld 44s and a dimmer be the solution?
06 DR-Z400s
95 KLR650- Sold
75 CB550K1- Too far away to ride
76 850T-3- Sold
Number6 screwed with this post 09-17-2013 at 01:23 PM
Number6 is offline   Reply With Quote
Old 09-17-2013, 01:29 PM   #3540
JustinP
JustinP's Avatar
Oddometer: 1,721
cheers dave
Dave - I have them mounted on my FJR, crappy picture below. Yeah, the M62 spots are big and ugly, but that's due to the fact you need a bigger reflector to get a true spot beam from the larger cree chips. I previously ran a set of the model 30's and upgraded to these. I like the M62's better - not only do they have longer range, they throw bright light out farther; less glare in close, more bright light thrown downrange.
JustinP screwed with this post 09-17-2013 at 04:06 PM
Times are GMT -7.   It's 12:42 AM.
