Old 09-19-2013, 06:51 PM   #3556
SoilSampleDave
Oddometer: 2,160
Originally Posted by sanjoh View Post
Well in that case, go for it. I thought you were purchasing the guard.
I find the front end a bit heavy on the Z, I ride mine in the sand often. The front end tends to push, unlike other bikes that I have.
Keep a fresh knobby on the front and a worn one on the back...should balance the push out.
"Comparison is the thief of joy" - TR (the good Roosevelt)
'08 530EXC
SoilSampleDave is offline   Reply With Quote
Old 09-19-2013, 07:16 PM   #3557
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,284
Usually just ride the 300 2t, it doesn't care what surface it is on
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 09-19-2013, 08:30 PM   #3558
Number6
mad as hell
Number6's Avatar
Oddometer: 30
Or you could put a 4.50 x 18 rear wheel on the front and back like the PO of my DRZ. Not sure how it performs in sand though, as I am properly landlocked. I was surprised at how well it handled in rutted dirt. But back to the thread at hand:
Are there pics of the Yamaha replacement of original headlight? I think even better than a 62, I might be able to mount a 60 and a 61 in the stock headlight space in place of the original headlamp.
And then they'd be behind the guard for all the roost I will be getting.
06 DR-Z400s
95 KLR650- Sold
75 CB550K1- Too far away to ride
76 850T-3- Sold
Number6 screwed with this post 09-19-2013 at 11:58 PM Reason: to better explainiate myself
Number6 is offline   Reply With Quote
Old 09-20-2013, 06:00 AM   #3559
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,284
Drilled hole in plastic headlight lens.
Opened up the rear of the stock light housing using a dremel to fit the threaded section of the light through. The curvature of the stock headlight reflector did not allow LED light to sit flat, so only a few threads reached the rear of the headlight. I added some quiksteel to the bed the light on the interior of the headlight reflector, used a bit different heatsink than standard.
The stock headlight housing is tiny, just over 2" tall, I didn't think the light would fit so I'm happy with the outcome. Especially after riding in the dark last night
Old 09-20-2013, 02:59 PM   #3560
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,553
I just bought a model 60 to go with my two model 30s. The model 30s aren't on a relay and are controlled with a separate switch.
For the single model 60, I'd like to wire it so that it only comes on when the high beams are on. I don't want a separate switch for it. Basically, I want that to become part of the high beams. When the highs are flicked on, I want this on, when they're flicked off, I want this off. I didn't buy the dimmer switch with hi beam bypass because I don't want/need that feature.
Can I just splice into the high beam wires?
Or would I need some sort of relay?
Could anyone draw up a wiring diagram for me? All of the diagrams I've come across aren't for my situation. Thanks.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Old 09-20-2013, 10:39 PM   #3561
George 99
George 99's Avatar
Oddometer: 787
Max, If it were me, I'd take the power from your high beam switch to toggle a 30 amp relay then feed the output to power both your headlight high beam and John's W60. Use 14 ga. wire from your battery thru a separate 30 amp fuse into the relay and 16 or 18 ga. to each of the lights. Easy enuff to wire up.
Keep us posted.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 09-20-2013, 10:44 PM   #3562
George 99
George 99's Avatar
Oddometer: 787
(John, on a side note, I wired my 60 direct thru my high beam switch and the 44 thru the dimmer. Each is operated thru a 30 amp relay. I found the cut-off from the dimmer, no diode in that piece of wire.)
George
Old 09-22-2013, 05:38 PM   #3563
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,553
Keep us posted.
I'm pretty ignorant when it comes to 12V wiring that is more complicated than wiring something directly to the battery. I'm pretty sure this isn't a complicated wiring job... But it is for me! Is there any way that you (or anyone) could draw up a schematic? Sorry to be a pain!
Newfoundland 2012
James Bay 2014
Old 09-22-2013, 05:44 PM   #3564
Jnich77
Jnich77's Avatar
Oddometer: 744
Man, that is awesome!!
Jnich77 is offline   Reply With Quote
Old 09-22-2013, 06:47 PM   #3565
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,221
Wiring Schematic
Here is a schematic I just finished for hooking up a couple of LED lights, and integrating switches and LED lights into an HDB Top Clamp.
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO screwed with this post 09-24-2013 at 06:13 AM
SteveO is offline   Reply With Quote
Old 09-23-2013, 10:29 AM   #3566
George 99
George 99's Avatar
Oddometer: 787
SteveO, that's a great diagram. I'm doing similar to my DRZ right now. My diagram is pencil on paper. Did you set up a negative system? (Just kidding. on my diagram, my head lights are on the left. :) )
Your wiring in the next pic looks similar too. Rat's nest! So far, everything works tho.
Max, wiring is just another skill. Either learn how and pay thru the nose. I'm cheap. (Plus, I've worked with low-voltage, house-hold, aircraft and telco wiring since 1965. I don't claim to be a pro at any of it (now retired) but muscle memory seems to get me thru the process.)
SteveO's diagram is good if complex. (Not complicated, there is a big diff.) Just isolate out the part ya need and work from there.
Most relays (which you will want to put in, trigger thru bike wiring and toggle switch; load to the lights direct from a fused lead from the battery) have a diagram right on the side. You'll only use 4 terminals, trigger + and -, load voltage in and out. "Far" side of the lights go direct to ground.
The load requirement on the LED lights is small enuff you could probably get along without a relay, but doing it right the first time is just better.
Hope this helps a little. Keep us posted.
George
Old 09-23-2013, 06:49 PM   #3567
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,553
Originally Posted by SteveO View Post
Here is a schematic I just finished for looking a couple of LED lights, and integrating switches and LED lights into an HDB Top Clamp.
This is just what I needed. A bit complex, as George said, but I think I was able to figure out what I needed from it. Thanks for posting it.
I always learn to work on things instead of paying other people to do them... Because I'd rather spend my money on farkles and fuel! Thanks for the help!
Before I go in and wire it up, I drew up a schematic. How does it look? Particularly, do I have the positive and negative wires from the model 60 in the correct place? Thanks.
I ordered on Friday and my light came in on Monday. FAST! Thanks Sanjoh. I already mounted my model 60 and just hardwired it to the battery to get it aimed. WOW! I thought my model 30s were bright. Holy cow, this thing is great!
Newfoundland 2012
James Bay 2014
Old 09-23-2013, 06:53 PM   #3568
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,284
Looks like you missed something.
Do you have a dimmer or lights only?
Old 09-23-2013, 06:55 PM   #3569
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,553
Lights only. No dimmer. I don't want any switches or dimmers. I want them off when the low beams are on, and I want them at full power when the highs are on. Basically, I want to add this light to my existing high beams.
Newfoundland 2012
James Bay 2014
Old 09-23-2013, 07:08 PM   #3570
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,284
In that case you need 12vdc negative to pin 85 on your relay and it should do just what you want.
The lights are not grounded due to the internal circuitry.
Times are GMT -7.   It's 02:47 PM.
