Old 09-23-2013, 06:53 PM   #3571
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Originally Posted by max384 View Post
Before I go in and wire it up, I drew up a schematic. How does it look? Particularly, do I have the positive and negative wires from the model 60 in the correct place? Thanks.
Looks like you missed something.
Do you have a dimmer or lights only?
Old 09-23-2013, 06:55 PM   #3572
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,430
Lights only. No dimmer. I don't want any switches or dimmers. I want them off when the low beams are on, and I want them at full power when the highs are on. Basically, I want to add this light to my existing high beams.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is online now   Reply With Quote
Old 09-23-2013, 07:08 PM   #3573
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
In that case you need 12vdc negative to pin 85 on your relay and it should do just what you want.
The lights are not grounded due to the internal circuitry.
Old 09-23-2013, 07:28 PM   #3574
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,430
Are you saying that I should keep the wiring the same as in my diagram, but add a negative to pin 85 (in addition to the negative from the model 60)? Or should I ground the negative from the light and then add a negative to pin 85?
Thanks.
Newfoundland 2012
James Bay 2014
Old 09-23-2013, 07:51 PM   #3575
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 778
I always found this relay diagram helpful:
http://www.classictruckshop.com/club...h/foglites.htm
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 09-23-2013, 07:56 PM   #3576
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,430
Okay, I got it figured out now. I grounded the pin 85 and negative wire from the accessory lights. Everything's working just right. Now I just need to tidy up the wiring and make it look good.
Thanks for all the help everyone!
Newfoundland 2012
James Bay 2014
Old 09-23-2013, 08:41 PM   #3577
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
We really need to see the lights mounted up, how about a picture?
Old 09-23-2013, 09:59 PM   #3578
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,430
Sure. I'll take a picture tomorrow.
In case anyone else wants to wire their lights like mine, here's the final schematic of how I did it:
Newfoundland 2012
James Bay 2014
Old 09-24-2013, 06:43 AM   #3579
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,211
Be sure you are using thick enough wire (18AWG and below). You won't want to burn up your wiring. You'll need to consider that when on a dirt bike the heat from the bike will add to the heat that the electrons are producing as they are moving through the wiring.
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 09-24-2013, 07:54 AM   #3580
George 99
George 99's Avatar
Oddometer: 778
Max, your last diagram shows it correctly. All grounds are equal (or should be). You can do an ohms check between your grounding point and the battery ground to make sure yur not dropping tenths of volts. Anyone doing wiring should have a digital multi-meter. I carry a small one with from Radio Shack.
George
Sometimes in Kingman, Arizona
George 99 is offline   Reply With Quote
Old 09-24-2013, 10:28 AM   #3581
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,430
They're all wired with 18ga wire. Thanks.
I wouldn't have been able to do this without a multi-meter. I was pretty sure that I had found the hi beam hot wire, but I needed the multi-meter to check. Then once I had ran all the wires through the bike, I lost track of which one was which, and needed the multi-meter to sort that out.
Newfoundland 2012
James Bay 2014
Old 09-24-2013, 12:26 PM   #3582
George 99
George 99's Avatar
Oddometer: 778
I use 14 gauge off the battery, 16 gauge to split to various devices, and only use 18 gauge for light-weight loads on the final run (like to my Vapor), 16 gauge to all the lights, horn, my aux 12V plug, etc.
I think 18 gauge is just too small for the long run.
One of the standard fixes on the DRZ 400 is to replace the stock wire from the Regulator/Rectifier output with 14 gauge directly to the battery instead of thru a multi pin connector. Losing the light-weight wire and connector can add close to a volt. Volts mean watts, important on the small alternators on these dual sports.
George
Old 09-24-2013, 06:47 PM   #3583
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,430
Here are some crappy pictures of the lights mounted. The model 60 is mounted to the lower windscreen and is tied in with the hi beams. The two fork-mounted lights are the model 30s. They are controlled with a switch independent of any other lights.
Here is how they look sitting in the pilot's seat:
lows:
lows + model 30s:
hi's + model 30s + model 60:
And how they look from about 30 yards away:
lows:
lows + model 30s:
Here are some videos of the lights. Since I don't have a switch that controls just the model 60, I had to remove the fuse to use only the stock hi beams for the demonstration video, so that's why I don't have a video of switching between the hi beams and the hi beams and model 60.
The first video is of the stock hi and lo beams:
The second video is of just the model 30s alternating with the hi and lo beams:
The third video is of the model 30s, the model 60 + hi beams, and the lo beams:
The videos really don't do the lights justice though. Here's a crappy screenshot of just the high beams and the next picture is of hi beams + model 60 + model 30s:
Newfoundland 2012
James Bay 2014
max384 screwed with this post 12-18-2013 at 06:25 PM
Old 09-25-2013, 07:00 PM   #3584
Beast1210
Beast1210's Avatar
Oddometer: 56
anyone know if they discontinued the m62, 2 LED rectangle model. I went to order it and saw it was gone. temporally out.
The Adventures starts here.....
youtube.com/user/beast12101
facebook.com/beast12101
Beast1210 is offline   Reply With Quote
Old 09-25-2013, 07:35 PM   #3585
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,482
Voltmeter mounting solutions
Any mounting solutions for the voltmeter on 1 inch bars?I have a V Star 650 Classic,and I'd like to mount the VM on the bars.I don't like having to look down at my tank mounted dash.It's about useless anyway.The riser area is currently occupied by GPS mount,charging station, and soon to be a tachometer.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Times are GMT -7.   It's 09:04 PM.
