Old 11-19-2013, 08:09 AM   #3706
Jnich77
Jnich77's Avatar
Oddometer: 744
So its me again... as I was adjusting my lights I noticed that my headlight is pretty much worthless. My latest thought is to place the model 60 inside my headlight housing, I have room and making is lo/hi shouldn't be to difficult.
Thoughts?
Jnich77 is offline   Reply With Quote
Old 11-19-2013, 10:16 AM   #3707
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,285
Thoughts?
This is on your 919?
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 11-19-2013, 12:53 PM   #3708
Jnich77
Jnich77's Avatar
Oddometer: 744
Yep :-)
I can't foresee any real problems other than heat, but the bulb that is in there is rated higher than the factory one and it has never melted anything.
Old 11-19-2013, 02:16 PM   #3709
coonass35
coonass35's Avatar
Oddometer: 87
combination
So who has used the combination of one Model 30 paired with one Model 44? I was thinking of doing this on my vstrom. I like the spot, but also like the fog pattern. Hoping this would give me the best of both worlds. Also what is the difference btw the two dimmer's with high bypass other than the obvious cost and remote control. Do they both operate the same? I want the lights to function with the oem lights. I don't want to worry about turning the lights on and off separately from the bikes ignition. Is this as simply as tapping into a power wire that is only hot when the ignition is on? Thanks in advance
coonass35 is offline   Reply With Quote
Old 11-20-2013, 07:08 AM   #3710
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,285
Yep :-)
What benefit are you considering in retrofiting the LED light stock headlight?
I don't think I would do it if it were my bike as it is a street only machine.
Old 11-20-2013, 07:10 AM   #3711
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,285
Both of the dimmers provide the same benefits. No need to switch on or adjust, once you have found the dimmed setting. Connections are highbeam positive and switched (on/off with bike) power.
Old 11-20-2013, 07:45 AM   #3712
Jnich77
Jnich77's Avatar
Oddometer: 744
Well, aside from looks, the stock headlight is about worthless. The reflector design only works with the oem bulb, anything brighter (especially hid) just scatter light.
So here is my thought, mount the 60 series in the oem housing in the same place as the oem bulb. Paint the reflector black ( it would now be useless) and wire it up. Should end up looking like a projector light.
Old 11-20-2013, 09:26 AM   #3713
SV_Dwayne
SV_Dwayne's Avatar
Oddometer: 310
Or do it right and install a proper bi-xenon HID projector instead, theretrofitsource sells them. That would be a great pairing with the LEDs you have now.
Kicking ass seems to be THE ONLY solution to life's problems. Kicking ass is the first, second and third option. Plan B and C are also kicking ass.
SV_Dwayne is offline   Reply With Quote
Old 11-20-2013, 10:00 AM   #3714
ewagman
Oddometer: 31
If you are on the road, you would be emitting a lot a glare to opposing traffic with this lamp. It's a great off road or "no opposing traffic" light, I love mine. If your bike need periodic safety inspections, it likely would not be legal with your proposed set up.
ewagman is offline   Reply With Quote
Old 11-20-2013, 10:08 AM   #3715
Jnich77
Jnich77's Avatar
Oddometer: 744
Nope, no safety checks in Florida...lol. I do see your point in regards to the glare.
Old 11-20-2013, 10:21 AM   #3716
Jnich77
Jnich77's Avatar
Oddometer: 744
I will have to look into those. The only problem with the HID is finding a place for the HID ballast, naked bike = no place to hide it..lol. Definitely a neat idea though, I look into it fo rmy tundra :-)
The funny part is, with the model 30's turned on the headlight doesn't really put off a noticeable amount of light...lol.
I don't know if I'll do it.. just seemed like an option to explore. I might get an extra headlight assembly off E-bay to try it worth just to see.
Old 11-20-2013, 10:23 AM   #3717
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,285
M60 is definitely not DOT approved.
Old 11-20-2013, 10:25 AM   #3718
Jnich77
Jnich77's Avatar
Oddometer: 744
HaHa... I know.
Old 11-20-2013, 11:11 AM   #3719
michigan400
Oddometer: 108
I have. Works good. Not the greatest pics but here you go.
H4 headlight high beam
1 - M44 only
1 - M44 and 1 - M30 only
H4 high beam + M44 + M30 all on.
michigan400 is offline   Reply With Quote
Old 11-20-2013, 12:09 PM   #3720
Bli55
Oddometer: 396
Couldn't see information on all the light on the website - http://stores.homestead.com/hstrial-...Categories.bok
Can you suggest to me the largest by outer diameter light that there is.
Should be around 80-90 mm.
F-ing in Iceland and Faroe Islands, 2013.
Detailed BMW X-Challenge build thread.
Bli55 is online now   Reply With Quote
Times are GMT -7.   It's 12:55 AM.
