Old 11-20-2013, 11:25 AM   #3721
Jnich77
Jnich77's Avatar
Oddometer: 678
Originally Posted by sanjoh View Post
M60 is definitely not DOT approved.
HaHa... I know.
Jnich77 is offline   Reply With Quote
Old 11-20-2013, 12:11 PM   #3722
michigan400
Oddometer: 90
Originally Posted by coonass35 View Post
So who has used the combination of one Model 30 paired with one Model 44? I was thinking of doing this on my vstrom. I like the spot, but also like the fog pattern. Hoping this would give me the best of both worlds. Also what is the difference btw the two dimmer's with high bypass other than the obvious cost and remote control. Do they both operate the same? I want the lights to function with the oem lights. I don't want to worry about turning the lights on and off separately from the bikes ignition. Is this as simply as tapping into a power wire that is only hot when the ignition is on? Thanks in advance
I have. Works good. Not the greatest pics but here you go.
H4 headlight high beam
1 - M44 only
1 - M44 and 1 - M30 only
H4 high beam + M44 + M30 all on.
michigan400 is offline   Reply With Quote
Old 11-20-2013, 01:09 PM   #3723
Bli55
Oddometer: 375
Couldn't see information on all the light on the website - http://stores.homestead.com/hstrial-...Categories.bok
Can you suggest to me the largest by outer diameter light that there is.
Should be around 80-90 mm.
F-ing in Iceland and Faroe Islands, 2013.
Detailed BMW X-Challenge build thread.
Bli55 is offline   Reply With Quote
Old 11-20-2013, 02:15 PM   #3724
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
Largest diameter is the M15 at 60mm.
Old 11-20-2013, 03:09 PM   #3725
coonass35
coonass35's Avatar
Oddometer: 77
1 - M44 only
Wow that is great thanks for the pics. I believe I have my combination.
coonass35 is offline   Reply With Quote
Old 11-20-2013, 03:11 PM   #3726
coonass35
coonass35's Avatar
Oddometer: 77
Both of the dimmers provide the same benefits. No need to switch on or adjust, once you have found the dimmed setting. Connections are highbeam positive and switched (on/off with bike) power.
Thank-you
Old 11-21-2013, 12:59 PM   #3727
Mr. Salty
Pretty quiet. Mostly.
Mr. Salty's Avatar
Location: Dav.Iowa- Wishing I were up in da North Woods...
Oddometer: 101
Question Happy Trail Nerf bar mounting ...
Originally Posted by dsc522758 View Post
Has anyone ever mounted their lights on Happy Trail PD Nerfs for the 2008+ KLR650n that is shown in this picture? Have you used the ADVmonster Crash Bar Light Mount? I would really like to see the install pictures close up. Sanjoh says they will work but then in the description is says it will work with bars 30mm, 27mm, 25mm and 23mm. I don't think those bars are that big.
Could you mount a light to the top bolt on the nerf bars closest to the fender?
-Salty >><>
Tacit?! I thought it said "Take-It"!
Mr. Salty is offline   Reply With Quote
Old 11-21-2013, 03:07 PM   #3728
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
Possibly, but from that angle, it looks like they would be behind the forks.
You could mount them where the reflector is on the fork.
Old 11-22-2013, 06:42 PM   #3729
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,259
are your new amber fog lights getting any closer to market? I am itching to get a pair for the light bar i am making...
" I need to stop talking and start drinking" ...Mom
RedMenace is offline   Reply With Quote
Old 11-22-2013, 06:51 PM   #3730
Mr. Salty
Mr. Salty's Avatar
Oddometer: 101
Thumb just checked...
I just chchecked mine, if you mount them to the HT upper bolt, they will be as far or slightly further out from the forks than if they were mounted to the reflector mount.
-Salty >><>
Old 11-23-2013, 10:40 AM   #3731
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,432
amber fog lights
Yes .... I'm curious as well ..
Honda
GsVs is online now   Reply With Quote
Old 11-24-2013, 04:38 PM   #3732
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
Yes, should be up on the website tomorrow, shipping on Tuesday.
Should work then.
Old 11-24-2013, 10:28 PM   #3733
Camarodude
Oddometer: 278
Ordered a 30 and a 44. Probably will regret not getting 60s....
Camarodude is online now   Reply With Quote
Old 11-26-2013, 07:05 AM   #3734
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
F11 Fog Light now available
We also added an amber replacement lens for our Model 30, 44, 60.
Old 11-26-2013, 10:42 AM   #3735
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,259
Thumb
Great! placed an order today! with a little luck and a little work I might be able to see where I am going this winter!
Times are GMT -7.   It's 08:22 PM.
