Old 11-26-2013, 12:59 PM   #3736
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,753
Originally Posted by sanjoh View Post
Correct.
oh great so that means that I need to order a new spot light from you . Well now anwer me this:
I regret (just a tiny bit!) not getting two M60s because wow they are sure wide and I'm able to see into corners on the one side where I have it. The spotlight not so much... would this cure this "not so much" problem of the spotlight?
Loutre is offline   Reply With Quote
Old 11-26-2013, 01:53 PM   #3737
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,753
The M60s still have the edge on distance. The M50 puts out more than our M44.
meh just saw your post. So the spotlight doesn't go further than the flood light :o(
Old 11-26-2013, 01:57 PM   #3738
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,753
Originally Posted by turbodieseli4i6 View Post
Would the 50's have a longer throw than my 60's? More is better in my world!
Yes, pics are on the way.
ok... now I'll have to see those pics
Old 11-26-2013, 09:11 PM   #3739
jbdesigns
jbdesigns's Avatar
Oddometer: 91
Originally Posted by coonass35 View Post
So who has used the combination of one Model 30 paired with one Model 44? I was thinking of doing this on my vstrom. I like the spot, but also like the fog pattern. Hoping this would give me the best of both worlds. Also what is the difference btw the two dimmer's with high bypass other than the obvious cost and remote control. Do they both operate the same? I want the lights to function with the oem lights. I don't want to worry about turning the lights on and off separately from the bikes ignition. Is this as simply as tapping into a power wire that is only hot when the ignition is on? Thanks in advance
That's what I did on my '04 GSA. Works great. I don't notice one being real different from the other. They work well together.
"Governments first duty is to protect the people, not run their lives" Ronald Reagan
jbdesigns is offline   Reply With Quote
Old 11-26-2013, 09:29 PM   #3740
dsgfh
Oddometer: 9
Thank you kindly
So I've added a set of the Model 60's to my Caponord 1200.
Since I've got no crash bars to mount them on, I've made up some adapters for the forks. Also made up a loom & routed it along the right-hand side of the bike. I spent most of my time getting to the high-beam wiring to tap in. With a fuse tap, the rest of the install is completely reversable. On low beam, you can't make out the difference as I've turned them down low enough to be seen, but not to dazzle oncoming drivers They make quite an impact on high.
I've mounted the dial variable control within hands reach for the moment with some velcro. I still need to seal it in something waterproof though, but wanted it accessible while I find the right settings.
Mounted to the lower fork. While the mud guard only uses 1 bolt at the front, there's a second bolt hole further up, so my bracket uses both. For those in Aus, the 1mm make-a-braket you buy from Bunnings has the holes perfectly spaced for this job (http://www.bunnings.com.au/flat-make...f2022_p3960600). I just bent it into shape & sprayed it black.
Hugs close to the wheel. I've cable-tied the wire on each side to the brake line to keep it clear of the wheel.
Low beam out on the nature strip.
My photo doesn't do it justice. High beam + Full Power on the AUX lights. I can actually see further that you can tell in the pic, but it gives you some idea.
I didn't take a pre-install pic with high-beam only, but the difference is stark. High Beam on the Caponord really just doesn't give me the spread to see the sides of the road. That said, you can already see the spread low-beam alone gives me anyway. Why they insisted on turning the low-beam off when you put the high-beam on is beyond me.
Low beam. I've got the AUX lights turned down so they don't really make an impact to my visibility. Could turn them up, but the beam has no cut-off so it'll dazzle oncoming drivers & attract the police.
Bright enough to fry a possum, or spot a roo at a distance :)
Now to find some country roads after dusk.
dsgfh is offline   Reply With Quote
Old 11-26-2013, 09:58 PM   #3741
dsgfh
Oddometer: 9
Geez Bunnings change their links fast.
If you go anywhere off-road then I'd definitely mount them higher. The wiring is libel to get snagged where they are. If I had crash bars I'd have gone that route, but they just don't make anything aesthetically pleasing for the Caponord 1200 yet.
For the road though they mount up fine on the wheel.
I used the make a bracket http://www.bunnings.com.au/flat-make...f2021_p3975816
Basically I cut 2 sections off 1 end (hidden behind my front fender so only made clean enough that it wasn't going to scratch anything), and bent it at the other end into a right angle 2 sections in. It's only been on for a couple of days, but it seems plenty strong enough.
For the wiring, I used a fuse tap from autobarn, an automotive relay & harness from jaycar, sheathed 2 core 15amp wire (I'm going to attach some more power accessories to the front of the bike at some point, so figured I'd run the power now), and some self-closing braided wire wrap from jaycar to give it some protection http://www.jaycar.com.au/productView.asp?ID=WH5630
Old 11-29-2013, 06:54 AM   #3742
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Nice bike and install!
Old 11-29-2013, 12:22 PM   #3743
tc339
tc339's Avatar
Oddometer: 60
Just bought some F11 Fog lights. Cant wait to get them mounted up and snap some pictures. And thanks for the upgrade to priority shipping!
tc339 is offline   Reply With Quote
Old 12-01-2013, 08:30 AM   #3744
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Thanks for your business!
I'd like to hear what you think of the lights
Old 12-03-2013, 03:46 AM   #3745
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
Check out our F11 Fog lights.
Old 12-03-2013, 08:57 AM   #3746
Vacman
Some call me...Tim?
Vacman's Avatar
Oddometer: 198
Just ordered some lights and a flashlight. I'm a sucker for a new flashlight...
If these work like I expect them to I will be ordering a couple more sets for my other bikes.
'01 plated WR250F | '03 plated KTM 565 | '10 Ducati Multistrada 1200
Vacman is offline   Reply With Quote
Old 12-03-2013, 11:59 AM   #3747
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 2,354
HD mount for Model 60?
Sanjoh - I see on your website, for the Model 60, that you advertise a heavy duty mount. Do you have a picture? I bought a pair of Model 15s (very nice!) and one of them moves around a little bit when pounding down gravel roads. Am scared to tighten it any further to be honest.
My setup - I built a bracket underneath the lower triple clamp to mount the lights to. The M15 in the middle is the one that slowly rotates down... the one on the sidecar stays put. Really like those lights - compact!
Spending my daughter's inheritance one motorcycle at a time.
Bikes currently owned: '91 Honda Gold Wing with sidecar, '92 Kawi KLR650 with Enduro sidecar, '94 KLR650, KL250 Super Sherpa.
GreatWhiteNorth is offline   Reply With Quote
Old 12-03-2013, 12:21 PM   #3748
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,753
They are just thicker.
Well... too soon to ask for pics of the M50? (vs M60 maybe???)
Old 12-03-2013, 01:04 PM   #3749
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
The M12 is amazing, Cree XML-U2, 2x 3000mah Liion batteries, one year warranty
Old 12-03-2013, 01:13 PM   #3750
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,216
The heavy duty bracket is for the M30, 44, 50 and 60 lights, it will not fit the M15.
As your bracket is mounted to the lower triple, I assume it is not moving? The sturdier the submount the better.
I would also be concerned about the fender hitting the light when the suspension is fully compressed.
I would recommend a nyloc nut or some lock tite for the pivot bolt. The pinching action of the pivot bolt should hold the light.
Times are GMT -7.   It's 12:07 AM.
