Old 12-03-2013, 02:13 PM   #3751
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 2,526
Absolutely correct
Originally Posted by sanjoh View Post
The heavy duty bracket is for the M30, 44, 50 and 60 lights, it will not fit the M15. As your bracket is mounted to the lower triple, I assume it is not moving? The sturdier the submount the better. I would also be concerned about the fender hitting the light when the suspension is fully compressed. I would recommend a nyloc nut or some lock tite for the pivot bolt. The pinching action of the pivot bolt should hold the light.
You're right about the clearance issue... although it's never contacted yet, I'm sure it could - must come damn close under heavy braking. It's actually a very sturdy mount setup (uses thick aluminum plate). Am still playing around with mounting ideas, and have also been looking at headlight replacement options - using an M60 as an aux light looks to be cheaper and easier. Thnx for making these great lights available at a reasonable cost.
GreatWhiteNorth is online now   Reply With Quote
Old 12-04-2013, 02:08 PM   #3752
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,364
Thank you!
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 12-04-2013, 09:33 PM   #3753
tc339
tc339's Avatar
Oddometer: 61
Fog lights
Got my new fog lights mounted up and moved my other lights to a new location. These things are sweet!
tc339 is offline   Reply With Quote
Old 12-05-2013, 07:10 AM   #3754
Mr. Salty
Pretty quiet. Mostly.
Mr. Salty's Avatar
Location: Dav.Iowa- Wishing I were up in da North Woods...
Oddometer: 102
Thumb F11
Those do look great!
Do you have any photos of the fog-light light-pattern on your garage wall?
...I wonder why these are in a square housing?
-Salty >><>
Tacit?! I thought it said "Take-It"!
Mr. Salty is offline   Reply With Quote
Old 12-05-2013, 08:00 AM   #3755
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,364
Thanks, they perform great as well!
Not at the moment, will see if I can get the shop dark enough for a photo.
Why not?
Old 12-05-2013, 09:25 AM   #3756
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,364
Tough picture with the high quality paneling
Old 12-05-2013, 09:54 AM   #3757
tc339
tc339's Avatar
Oddometer: 61
half the reason I bought these is because they are in a square housing. Im not really a fan of the round housings, I think these look great!
Old 12-06-2013, 03:59 PM   #3758
Camarodude
Oddometer: 304
Waiting on some parts before I install lights. Can I use 12v battery charger for temp power, and not hurt the lights?
Camarodude is offline   Reply With Quote
Old 12-06-2013, 04:59 PM   #3759
Bli55
Oddometer: 398
Any plans for a new round housing LED of around 85mm diameter?
F-ing in Iceland and Faroe Islands, 2013.
Detailed BMW X-Challenge build thread.
Bli55 is offline   Reply With Quote
Old 12-07-2013, 02:22 PM   #3760
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 651
The little dimmer I got from you guys works a treat and I like the main beam override feature
P1040932b
I GS 1 is offline   Reply With Quote
Old 12-07-2013, 04:03 PM   #3761
Vacman
Some call me...Tim?
Vacman's Avatar
Oddometer: 203
Installed my mm15s on my new GS. Should make good running lights without being obnoxiously bright.
'01 plated WR250F - '07 990 adv
Vacman is online now   Reply With Quote
Old 12-07-2013, 04:42 PM   #3762
kwb377
kwb377's Avatar
Oddometer: 246
Thumb
Got my M30's the other day and mounted to the Ninja. Haven't had a chance to try them out other than in the driveway.
Low beam with dimmer on lowest setting...
High beam...
~ IBA #55309
'13 Husky 650 Terra / '11 Ninja 1K / '04 200 EXC (tagged) / '82 GS650G
kwb377 is offline   Reply With Quote
Old 12-08-2013, 01:45 PM   #3763
EKinOR
Oddometer: 272
Sanjoh, which light would be the best replacement for the crappy stock headlight on a DR200SE? Strictly for off road use, so I don't need a DOT certified light.
- Eric
2002 BMW R1150GS
EKinOR is offline   Reply With Quote
Old 12-09-2013, 10:42 AM   #3764
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,364
I would go with the Model 60 and a rotary dimmer. You will be using less power than the stock headlight.
Old 12-11-2013, 12:49 PM   #3765
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,364
2013 CRF250L
Times are GMT -7.   It's 04:40 PM.
