Old 04-26-2014, 08:34 AM   #3976
tyrsmkkyle
off the ground.
Oddometer: 250
my dual m60s are doing just fine. my plastics however are showing the marks of my riding inability. These lights are holding up well no complaints thus far im glad i sprung for the dimmer, i can turn them down enough to ride in traffic.
tyrsmkkyle is offline   Reply With Quote
Old 04-26-2014, 04:04 PM   #3977
xaman
Oddometer: 554
Wr250r install
Working on install of 2 M30s and a dimmer on my WR250R.
I don't really have a good place to mount the dimmer. For those of you that have been running these, is there any reason to have the dimmer handy? Or is it a set it and forget it kind of thing? I was considering mounting it underneath the seat. Seems like it would be less likely to get bumped and such, and wouldn't have to fabricate any brackets etc... But if I need access to it day in and out, under the seat might wouldn't work.
Opinions?
Also, is the positap meant to connect to the headlight switch wiring?
xaman screwed with this post 04-26-2014 at 04:21 PM
xaman is offline   Reply With Quote
Old 04-26-2014, 04:45 PM   #3978
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 815
Opinions?
Use the posi tap to attach the high beam bypass wire to your high beam wire.
I mounted my switch to the back side of my HDB hand guards. If you're using the high beam by pass though, you really won't need access to the switch again. For me however, it took a bit to figure out how to keep the switch from rotating from the vibes on my thumper. After stuffing the underside of the knob with foam that's not been a problem, and I've not touched it. I have mine set as low as it will go without pulsing, and leave it on day or night.
sdd04 is online now   Reply With Quote
Old 04-26-2014, 07:41 PM   #3979
xaman
Oddometer: 554
Thanks, that was helpful. Got it mounted up, we will see how it fairs. Light is definitely better, just need to do some riding at night and make sure I'm not annoying oncoming traffic.
Old 04-27-2014, 05:17 AM   #3980
sdd04
Oddometer: 815
I think it's all in how you aim them. I followed my wife home from the big city at dusk, and her comment to me was that I could turn them up even more. My in laws and I ended up crossing paths on a 2 lane road during daylight, and they said it wasn't a bother at all. Did say however that the appearance was so distinctive, that they knew it was me before they could identify the bike.
Good luck with the lights. They won't stop everyone from pulling out in front of you, but it will get some to not do it. And as far as night goes, they fill in my low beam nicely, and when you hit the high beam switch, well, I'll just say that amount of light is addictive. Makes it hard to go back to low beam lol.
Old 04-27-2014, 06:52 AM   #3981
JTXR1200
Oddometer: 23
Mornin -
I've got an '09 HD XR1200, any tips on best location?
Thanks,
JT
JTXR1200 is offline   Reply With Quote
Old 04-27-2014, 07:33 AM   #3982
ctowne
ctowne's Avatar
Oddometer: 375
Just ordered a pair of the 30s along with a dimmer for my KLR. I'm sure I'll post some pics when I get them :
ctowne is online now   Reply With Quote
Old 04-28-2014, 04:53 AM   #3983
wmfleet2
Oddometer: 977
thanks John
Thanks again for drop shipping my light to the Hotel ,,,great service
wmfleet2 is online now   Reply With Quote
Old 04-28-2014, 05:10 AM   #3984
frogy
frogy's Avatar
Oddometer: 840
Can anyone give me the measurements of the 60s and 30s ? I cannot find them on the Monster site.
2002 R1150RT, 1985 Naked K100RT
frogy is online now   Reply With Quote
Old 04-28-2014, 06:02 AM   #3985
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
M30, 44, 50, 60 use the same housing.
From our website: Length: 70mm , Diameter 55mm
Old 04-28-2014, 06:03 AM   #3986
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Glad we could help.
Hope you have a nice ride!
Old 04-28-2014, 07:18 AM   #3987
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Originally Posted by JTXR1200 View Post
Mornin -
Thanks,
JT
Perhaps next to the blinkers on the bars? We offer a couple of mounts that may work.
Or on the fork lowers on one of the fender support bolts.
Old 04-28-2014, 07:31 AM   #3988
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Opinions?
Once you have the dimmer set, you will not need to adjust it.
WR install
To the right of brake line, inside the fairing
On the small "tab" that extends back from the mounting screw.
Positap connects to the high beam positive, just behind the headlight.
Old 04-28-2014, 12:02 PM   #3989
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Thanks for you business
Old 04-28-2014, 02:35 PM   #3990
frogy
frogy's Avatar
Oddometer: 840
Yep, saw that. These suckers are just 2inches wide with that kind of candle power? Sorry, just found it hard to believe.
Times are GMT -7.   It's 05:50 AM.
