Old 08-20-2010, 06:47 AM   #61
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 399
Originally Posted by sanjoh
What do you have mounted there now? What bike is it?
11.5 oz is the ready to ship weight so it includes the shipping box, foam, both mounts 3-4' of wiring, male and female electrical connectors.
It is a Honda ST1100. I don't have anything now. I am looking for under the main light, or fork mounted, which I worry about from the road vibrations.
That is why I want to know the actual weight of the light and not the shipping weight.
Thanks,
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 08-20-2010, 07:07 AM   #62
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,663
I would not recommend mounting to the fairing, it will not last, the fairing will split/crack, ask me how I know this. The lights mount in a single bolt so the stresses will be concentrated.
If you added a few layers of fiberglass to the inside of the fairing after grinding off the paint it may work.
If you find the appropriate size tbolt clamp for your forks it will work great.
sanjoh is online now   Reply With Quote
Old 08-20-2010, 07:25 AM   #63
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,428
Got a pic of the bar mount setup? I'm unclear how it attaches to light itself etc... Is it painted or powder, alu, steel,...?
thx
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 08-20-2010, 07:35 AM   #64
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 8,137
Send a message via ICQ to Yossarian™ Send a message via MSN to Yossarian™ Send a message via Yahoo to Yossarian™ Send a message via Skype™ to Yossarian™
Are the flat mounts able to be rotated back to be parallel with the bracket?
In other words, will the flat mounts allow the lights to be correctly positioned if the mount bolt is vertical and parallel to the bike? I am thinking about putting these lights on a set of hand guards.
Old 08-20-2010, 08:16 AM   #65
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,663
Mount pictures
Old 08-20-2010, 09:26 AM   #66
Yossarian™
Yossarian™'s Avatar
Oddometer: 8,137
Thank you for the quick and thorough response!
Old 08-21-2010, 07:21 PM   #67
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 1,722
I've been running these LED Lights on my Dirt Ninja for several thousand miles in all kinds of conditions and have been very pleased with the performance. These lights are extremely bright, you can't look directly at them when on. I don't recommend using them with traffic at night, during the day, people will get out of your way.
Description:
Spot Beam 10watt / .85amp ~450 lumens total from 3 leds, 12v
Flood Beam 24 watt / 2amp ~1500 lumens total from 9leds (3 groups of 3), 12v
Aluminum housing
o-ring sealed
one meter leads
waterproof connectors -male and female
two mounting options - flat mount (stainless) or 7/8s bar mount(aluminum).
plastic lens
available in black or black
What's included:
Flood on right, Spot on left
Please excuse the big pics but you want to see what you are buying.
Cost+ship:
Pair Spot Beam - $90
Pair Spot/Flood - $105
Pair Flood Beam - $115
I will post up some better in use lighting pics after the weekend ride.
Hi, a quick question for you. Do these have the various modes of light intensity?
bikyto is offline   Reply With Quote
Old 08-21-2010, 07:45 PM   #68
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,663
Two modes, on and off.
Old 08-22-2010, 06:46 PM   #69
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,663
All PMs replied to
Old 08-23-2010, 12:17 PM   #70
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,297
Got the lights, Thanks , let you no how they work after 4k miles in south america , i try it inside the shop minutes ago ,Im impress
"Vive tus sueños en vida, no la vida en sueños.
Kampale Moto Ranch
Bed and Breakfast
mototours/uruguay south america
trailtrick is offline   Reply With Quote
Old 08-23-2010, 10:36 PM   #71
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 2,665
Come on, fellas (not you, sanjoh)--let's see some pics mounted and beam shots from happy customers.
WUMPA!
Goot-Z
4XKPN - sold
DRONE is offline   Reply With Quote
Old 08-24-2010, 11:32 AM   #72
Hotmamaandme
Wishing I was riding RTW
Hotmamaandme's Avatar
Oddometer: 2,418
Hit the switch
Just to clarify there is no switch in the kit? Buyer works out his own switch optioins? I do like the on/off dimmer switch.
My screen name is kind of long. I am the "ME" part, my name is Cory.
Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..."
Hotmamaandme is offline   Reply With Quote
Old 08-24-2010, 11:47 AM   #73
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,663
Correct
Old 08-24-2010, 04:04 PM   #74
Geek
oot & aboot
Geek's Avatar
Oddometer: 25,818
I don't think LEDs can work that way.. they are usually on or off.
Or can these LED actually handle variable voltage for variable output? (though I'm hard pressed to think of a reason you'd want less light )
www.motogeek.com
Old 08-24-2010, 04:29 PM   #75
Hotmamaandme
Oddometer: 2,418
Yeah these will work on a dimmer switch. Read the thread a bit and its confirmed. With lower light during daylight you can run them dim but still acting as look at me lights.
Times are GMT -7.   It's 12:27 PM.
