Old 05-23-2011, 08:31 AM   #1321
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 2,028
Originally Posted by htmon View Post
Hi Guys,
Sorry to ask this question but I really need this cleared up for me.
I have a 30 and 44 coming and want to wire up to my F800GS.
All of the wiring diagrams on this thread show either a dimmer set up, relay or both.
Can some one please post a diagram of how I can wire these up so they only come on with my High Beam but can be switched of with a simple on off switch also. No relay and no dimmer.(I seem to remember that these lights do not need either) please correct me if I am wrong.
All I am after is a simple diagram showing me how this is done.
Any help would be appreciated guys and I am sorry if this has already been posted but I could not find it.
Cheers
I know it would work with the dimmer as I played with that setting, of off and then full on with high beams... Not sure how to hard wire...
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 05-23-2011, 09:03 AM   #1322
Ricky Chuck
Red Green Rulz!
Ricky Chuck's Avatar
Oddometer: 460
Well, on my bike, the white wire going to the headlight is the high beam, so the dimmer has the high beam override hooked to it. High beam comes on, leds come on. Considering the low draw of the leds you could just wire an on/off switch between the white wire and the leds, however I am unsure about the ramifications. This is what a relay does...removes uncertainty. If you have the highbeam wired in as the signal in a relay, it would then provide ample power to the on/off switch and then the leds. Not difficult to do, especially if you get a relay plug and wire, then plug into the relay.
Ricky Chuck is offline   Reply With Quote
Old 05-23-2011, 10:25 AM   #1323
NomadS
Oddometer: 63
can someone post some pics (or better yet a video) simulating what an approaching cager sees if you are coming at them? ie.. have someone with a camera in the driver seat of a car while the bike is approaching in the other lane. One with the oem lights only and one with these and the oem lights.
NomadS is offline   Reply With Quote
Old 05-23-2011, 10:28 AM   #1324
Crazy Canadian
Oddometer: 2,028
My pics a couple pages back might give you an idea... A friend who I passed the other day with them on full (knew it was him and did it on purpose) said it was like driving into the sun...
Old 05-23-2011, 02:14 PM   #1325
Ricky Chuck
Red Green Rulz!
Oddometer: 460
LOL, driving into the sun . That and all the other comments about causing small animals to burst into flame make me anxious to get this puppy on the road and causing grassfires :)
Old 05-24-2011, 05:48 AM   #1326
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,078
Strange Electrical Behavior
I received my pair of 44s in two days (thanks for the prompt service!), and they light up the terrrain downrange very nicely . . . .
However, the aftermarket volmeter (Kuryakn) on my 07 Tiger registers higher than normal voltage when I turn on the lights (plain old swtiched off and on) . . . .
I guessed that the black wire is ground, the white wire is hot, and I don't THINK there's an alternate ground path running through the light mounts . . . .
anyone got any ideas?
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 05-24-2011, 05:56 AM   #1327
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Please be more specific "higher than normal" ?
What is normal on your bike? What does it read when lights on?
Where do you have the vm wired?
Is this a led bar graph type vm or an actual number display?
Old 05-24-2011, 06:01 AM   #1328
Ricky Chuck
Red Green Rulz!
Oddometer: 460
Bomber, assuming you are watching your voltage while the engine is running, what does it show with lights off, and then with lights on? Figuring it should show about 13.5-14.5 with engine running? You are correct, white is hot, black is ground.
Oops, what Sanjoh said, lol.
Old 05-24-2011, 06:02 AM   #1329
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Sanjoh,
You should have gone to the RDV again, man, it was a great time. I did meet one of your lovely technicians, although (and I'm embarrassed to admit it) I've forgotten her name. I'll blame the hooch (good lord I drank a lot on Friday night).
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 05-24-2011, 07:37 AM   #1330
OaklandStrom
Oddometer: 1,612
Hi Guys,
If your bike has a built in relay for the headlights, it's easy. If not, you'll need to use a relay. if it's canbus...
Assuming BMW uses a relay for the headlights:
Wire the black wire to ground on the bike.
Wire the white wire to the wire going to the high beam.
Between either one, place a switch.
Google for a wiring diagram so you know what color the high beam wire is.
On my DL650, it was the yellow one, so I spliced in and ran that to the relay trigger. Suzuki runs headlight power through the switch, so I didn't take power directly from the high beam - and used a relay.
OaklandStrom is offline   Reply With Quote
Old 05-24-2011, 07:44 AM   #1331
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Originally Posted by JDLuke View Post
Sanjoh,
I wanted to go, but someone has to work! Next year RDV is on the list. Doesn't take much of the springwater to get you loopy
Her name is Sharon.
Old 05-24-2011, 01:13 PM   #1332
Willy510
Master of none
Willy510's Avatar
Oddometer: 113
I ordered a set of lights early Saturday morning and they showed up, to the west coast, on Monday morning !!!!
Thanks Sanjoh !!
Willy510 screwed with this post 05-24-2011 at 01:19 PM
Willy510 is offline   Reply With Quote
Old 05-24-2011, 01:38 PM   #1333
Ricky Chuck
Red Green Rulz!
Oddometer: 460
I knew it! He DOES live in a Post Office! :)
Old 05-24-2011, 10:16 PM   #1334
Crazy Canadian
Oddometer: 2,028
The guy I bought a brake disc off of on Ebay needs to take lessons on shipping from you!
Old 05-25-2011, 07:04 AM   #1335
bomber60015
Oddometer: 14,078
K, I wanted to do some more research before I cluttered up the thread, or gave anyone the impression that the lights are making the electrical system act wonky . . . . .
Measurements taken at the battery with a DVM reveal all is acting as it should --
low-12/high-11 volts with the engine off, LED lights off, but ignition and stock lights on.
voltage drops when LED lights are activated (less than one volt)
Same same when the engine's running -- low 14 volts drops a couple of tenths then the LEDs are activated.
The Voltmeter I have, however, is waving it's hands in the air -- it is a series of small LEDs, that read 14 volts with the engine running, LED driving light off, but it reads 16/18 volts (maxed out) with the engine running, and the LED driving lights on.
The voltmeter is connected across the power leads to the small marker light that's on the front the the 07 tiger -- the meter reading matches DVM readings at the battery in all other circumstances.
Now that I know the electrical system is acting normally (I suspected it was, but was pleased to prove it), I'll take a look at alternate connections for the volt meter . . . . ..
Times are GMT -7.   It's 12:10 AM.
