Old 05-25-2011, 08:29 AM   #1336
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,924
Sounds normal with the exception of the led vm behavior. Perhaps you should hold off and install one of my vm.
Available on the website this week
Glass of water not included
40mm(1.6") wide x 22mm(,9") tall x 19mm(.75") deep
LCD (no back light required)
Waterproof
Old 05-25-2011, 11:08 AM   #1337
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Does it only work underwater?
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 05-25-2011, 01:50 PM   #1338
Ricky Chuck
Red Green Rulz!
Ricky Chuck's Avatar
Oddometer: 411
Son of a biscuit eater!!! Just bought another one, then realized it probably wasn't waterproof, lol. How much, Sanjoh?
Ricky Chuck is offline   Reply With Quote
Old 05-25-2011, 02:18 PM   #1339
BMWzenrider
The Road Scholar
BMWzenrider's Avatar
Oddometer: 1,089
Model 30 heat generation/disipation?
I have read this entire thread from start to finish with interest, particularly the teardown done on the first generation 27watt flood model.
The application that I am considering is the Model-30 Spot beam to replace the 35-watt H3 PIAA lamps currently installed in my Hannigan sidecar.
The question/issue for me is one of heat dissipation.
As you can see from this photo, the lamps are set inside of non-vented molded wells in the body of the sidecar.
Of course, I am not worried about heat when running in the winter, but I also have been known to ride across Nevada in June/July...
The light wells are 3.0" in diameter, so there would be some free space around the LED lamps, but I just wonder if it would be enough.
(I have no illusions about the Model-44 lamps working in that space, and I think the spot beam might be better for full-time use anyway.)
The outer lamp is wired to be ON full-time with the motorcycle's low beam, and the inner lamp is wired to come on with the high beam.
Thoughts?
Observations?
Data???
TIA!
Karl Kugler
www.theroadscholar.net
2005 BMW R1200RT w/Hannigan-LT sidecar
2002 BMW R1150RA
In Memoriam: Harley, 1993-2010 You will be missed.
BMWzenrider is offline   Reply With Quote
Old 05-25-2011, 05:51 PM   #1340
FL Pepper
OMGWTFFTW
FL Pepper's Avatar
Oddometer: 1,496
Works well next to water also.
Hi JD nice meeting you this weekend.
2008 Yamaha WR250R
2001 Westfield Celebration
New ADVmonster Website
Central Sandbox Tag-O-Rama Maps
FL Pepper is offline   Reply With Quote
Old 05-26-2011, 04:09 AM   #1341
JDLuke
JDLuke's Avatar
Oddometer: 8,644
Old 05-26-2011, 08:40 PM   #1342
DNTOUCH
Need more time to ride.
DNTOUCH's Avatar
Oddometer: 785
Thumb
OK guys/gals i ordered a single model44 for my brother (just one) I have been running the VisionX Solstice euro beam for the last 1.5 seasons. I have nothing but good things to say about those lights and compliments to boot. I never figured i would ever need any more light.
Well i just came in from the garage and to say i am stunned by the output of these lights (ADVMonster) is an understatement. I did a quick comparo of my (2) leds mounted to the front of the Vstrom and the (1) ADVMonster model 44.. With both of my lights on this one model 44 just drowns them out,, and i mean comepletely out. With my headlights in addition to my VisionX on (and on high beam) the one model 44 is about the same light output.
If i knew more about how long these model 44 lights will last i would pull the trigger like right now. They seem to be extremely well built, but,,, i want to mount them lower onto my forks. Obviously quite a bit more vibration on the forks so i'm just a bit more concerned.
So all in all, very impressed..
'08 DL1000 (with some stuff
DNTOUCH is offline   Reply With Quote
Old 05-26-2011, 08:43 PM   #1343
DNTOUCH
DNTOUCH's Avatar
Oddometer: 785
Originally Posted by sanjoh View Post
You will forget you have high beams once you turn on a pair of 44s.
A friend stopped by with his new vstrom which has some of the best stock lights. I was shocked that the 44s he just installed smoked the stock lights.
Heck one model44 will drown them out.. I just did it..
Old 05-29-2011, 06:01 AM   #1344
Peregrine40
Tiercel
Oddometer: 67
Originally Posted by DNTOUCH View Post
... They seem to be extremely well built, but,,, i want to mount them lower onto my forks. Obviously quite a bit more vibration on the forks so i'm just a bit more concerned.
I would strongly advise against mounting them on forks with the stock mounts. The mount are thin and fragile. I've seen several crack and break with vibration - including mine.
P
Peregrine40 is offline   Reply With Quote
Old 05-29-2011, 01:57 PM   #1345
DNTOUCH
DNTOUCH's Avatar
Oddometer: 785
P
Thanks for the heads up. Were these the on the 44's?
Old 05-29-2011, 05:16 PM   #1346
Crazy Canadian
All who wander r not lost
Crazy Canadian's Avatar
Oddometer: 2,028
I may be wrong but I believe they have mounts specific for mounting on the forks.
I've learned to give "impossible" the finger as I pass it by.
The only way to get through life is to laugh your way through it!
Day by day, nothing seems to change. But pretty soon, everything is different.
Crazy Canadian is offline   Reply With Quote
Old 05-30-2011, 01:06 PM   #1347
DNTOUCH
DNTOUCH's Avatar
Oddometer: 785
No, the dimmer has a memory so it stores the last setting.
The dimmer can handle four of the model 44 lights. The lights can be dimmed to almost off. The lights go to full power when the high beam bypass is activated.
So the model 44's got thier name how? I'm curious because if the dimmer handles 96 watts that to me would mean the lights only use 24 watts (ish) a piece or less?
I just dont see the wattage info on the website where you sell them.?
I've already ordered one from you i'm just doing some comparing..Thanks.
Old 05-30-2011, 02:27 PM   #1348
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,374
Do LED lights require DC power like HID lights, or can I use them with AC power?
jesusgatos is offline   Reply With Quote
Old 05-30-2011, 04:39 PM   #1349
univibe88
Slidell4Life
univibe88's Avatar
Oddometer: 2,263
I don't think it's from the watts drawn.
List of my old bikes that no one cares about
Current bikes go here to make others jealous
"I like my ride plans like my women...loosely put together with a chance of getting wet."
univibe88 is offline   Reply With Quote
Old 05-30-2011, 08:23 PM   #1350
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,924
Here it is.
DC needed
Times are GMT -7.   It's 03:32 AM.
