05-30-2011, 07:40 PM
#1351 | |
Need more time to ride.
Oddometer: 785
So i am to guess then that i should take the 1.8 amps and figure it out.? Which equals 21.6 watts..
'08 DL1000 (with some stuff |
05-30-2011, 10:59 PM
#1352 | |
ED RN Adventurer
Tracy E / Photos4Aidan.com / dacrazyrn.dpcprints.com / Can you SPOT me? “When you do things RIGHT, people won’t be sure you’ve done anything at all.” God in Godfellas-Futurama Life is Risk Management '09 BMW F800GS-Fate Honeyed GSabelle |
05-31-2011, 05:50 AM
#1353 |
Oddometer: 785
#1354 |
Ravening for delight
Oddometer: 8,645
Why did I drink all of the ingredients for vomit? "Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar "you cannot reason a person out of something they were not reasoned into." - Jonathan Swift |
05-31-2011, 06:25 AM
#1355 |
Oddometer: 785
Ok ,,, so i'm not good at math i never tried to be, but by looking online i found that you take amps x voltage (AC or DC) = wattage.
So are you saying that to get the model name thats what was done,,,, or i did the math wrong and by taking the 1.8 amps he has listed on the site i am coming up with the wrong wattage.? ![]() I just rolled out of bed so hopefully that makes sense.
05-31-2011, 06:55 AM
#1356 |
Oddometer: 8,645
You're overanalyzing this.
You got the right calculation and you performed it correctly. At 1.8 amps these lamps by rights will burn 1.8(Amps) * 12(Volts) to get you 21.6 Watts per lamp. You received a mildly snarky response suggesting that if you double it and round up you'll get to the model number (21.6 * 2 = 43.2, round up and you get 44) . There's not much more to it than that. I have no idea if the model numbers are related to power consumption in real life, or if it's just an amusing coincidence.
05-31-2011, 09:05 AM
#1357 |
Slidell4Life
Oddometer: 1,552
Because they are meant to be used in pairs. That's why doubling the numbers gets you to the model # 44.
Karl...in a constant internal battle between uptight German and rebel redneck 2007 BMW K1200GT "I like my ride plans like my women...loosely put together with a chance of getting wet." |
05-31-2011, 09:34 AM
#1358 |
All who wander r not lost
Oddometer: 1,982
Why does it matter what the model number means? Most model numbers mean little if nothing anyhow. They are awesome lights and I am sure to be ordering a few more sets for my other bikes shortly.
I've learned to give "impossible" the finger as I pass it by. The only way to get through life is to laugh your way through it! Day by day, nothing seems to change. But pretty soon, everything is different. |
05-31-2011, 10:16 AM
#1359 |
Roaming ADV Gnome
Oddometer: 1,395
John
I gave the Spring promotion code to a friend and when they tried to order this morning, your site said the code was expired or invalid. I thought it was good through the end of May
05-31-2011, 12:07 PM
#1360 |
Smile 4 Miles
Oddometer: 1,376
I'd like to see a bit larger diameter LED light with on-road beam pattern (fog and driving light) and proper cut-off, similar to BMW/Hella 14W accessory LED's but more powerful.
I'd mount both driving and fog light, the '44' is bright but beam is so focused. I think ~100lumens/Watt is state of the art right now. |
05-31-2011, 04:27 PM
#1361 |
Oddometer: 7
Can you use one dimmer for two different lights (ie a 30 and 44) or will that cause one to be much brighter than the other?
What type of LED are they - semiled or CREE? |
05-31-2011, 05:01 PM
#1362 | ||
Purveyor of Light
Oddometer: 3,708
Can someone with a model 30 and a 44 post a pic? Cree
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
06-01-2011, 08:13 AM
#1363 | |
Wheelies R Bad
Oddometer: 302
06-01-2011, 08:23 AM
#1364 |
Typical KLR owner
Oddometer: 135
Those are really bright lights. Would you have a pic with both the LED's and the turn signals on? They aren't being washed out by the LED's are they?
97 KLR650 No longer talk at all about what a good man ought to be; be such. Marcus Aurelius |
06-01-2011, 08:43 AM
#1365 |
Wheelies R Bad
Oddometer: 302
Good question, and it has been debated here. I have moved them down to the lower forks since this pic was taken...that was an opportunistic mount location since there were some matching holes in the shield I put on. My opinion is like yours, it would wash out the turn signals if they were on when you needed to signal, which is why I moved them, even though I liked them being high. I have some leds above the turn signals that flash counter to the turn signals, so there are more things going on, but still going with the lower mount area. Can get a pic if no one else posts one.
