Old 06-21-2011, 11:55 AM   #1411
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
The heavy duty mount will be offered as an upgrade.
Old 06-21-2011, 12:49 PM   #1412
univibe88
Slidell4Life
univibe88's Avatar
Oddometer: 1,540
I'm looking forward to the upgraded mount and will gladly pay for the upgrade.
Karl...in a constant internal battle between uptight German and rebel redneck
2007 BMW K1200GT
"I like my ride plans like my women...loosely put together with a chance of getting wet."
univibe88 is offline   Reply With Quote
Old 06-21-2011, 02:41 PM   #1413
gsstampeder
gsstampeder's Avatar
Oddometer: 835
the light weight brackets might work fine for street riding....but the vibrations and jarring that occur off road have mine failing as well.
But i guess I have no options other then PAY the money for the 'upgrade'.
5 weeks in Baja
gsstampeder is offline   Reply With Quote
Old 06-22-2011, 12:32 PM   #1414
Switchblade315
Switchblade315's Avatar
Oddometer: 3,245
ok i have a question that has never cam up on here. i just read every post. My eyes hurt now.
Anyway i have a 82 XL500R and the stock stator isn't big at all. this are perfect but here's my question. i've alread up graded teh headlight and I'm pushing the max watts that side of the stator can handle. now the other side that runs the battery, tale, brake light and the turn signals has some left. it can easily run these. But here's the question.
on the dimmer with high beam bypass does it pull the bypass power from the headlight circuit or does it just turn the dimmer off and let the full power come from the same power supply as it uses when it is dimming the lights?
When i die bury me upside down so the whole world can kiss my ass.
Switchblade315 is offline   Reply With Quote
Old 06-22-2011, 01:04 PM   #1415
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
It pulls power off the dimmer power supply. The high beam only provides a signal to the relay.
We need some pics of your XL
Old 06-22-2011, 02:56 PM   #1416
Switchblade315
Oddometer: 3,245
this is her when I started
and this is her now.
and with in the month i will be up grading the front end to that of a 98 XR400R and possibly the rear suspension as well.
I'm having back surgery with in a few weeks and was thinking about adding the lights after i get back to work.
Old 06-23-2011, 01:16 PM   #1417
GHO100
Crazy George
GHO100's Avatar
Oddometer: 780
Send a message via AIM to GHO100 Send a message via Yahoo to GHO100
Did I miss the answer to this? Usually Sanjoh seems right on the ball, but this has been asked at least twice now, and I didn't see any response.
If someone got a response in PM from Sanjoh, please share with the forum, thanks!
Originally Posted by elmontanero View Post
Do you have a recommended Wiring set up? I've read about a problem stated here about HID and wondered if you could give us the WORD from you.
Brooklyn, NY
2006 VStrom 1000 "Felaróf"
1980 GS850G (project)
1997 Triumph Daytona 955i For Sale: http://advrider.com/forums/showthread.php?t=883574
www.TeslaLEDS.com
GHO100 is offline   Reply With Quote
Old 06-23-2011, 07:35 PM   #1418
Optimus Prime
Oddometer: 152
Well here's an interesting issue.
I bought 24W 3-way lights last November. Went to install them for a trip and one blinked out. Sent it back in and a new one was sent when the next batch arrived, no problem.
Well, by then I didn't have time to mount the lights before my trip and they sat in the box until tonight. I got all my gear and started building the wiring kit, tested both lights and they work great. The momentary switch flips between brightness levels no problem... except that they rotate in opposite orders.
One light goes High>>Med>>Low
One light goes High>>Low>>Med
I did notice that the wire colors are different as well, one has red and black, the other white and black. This just makes me think they were from different batches.
Anyways, what the heck do I do now? I'll send Sanjoh a PM, but it's late so maybe there's a fix I'm not coming up with.
Optimus Prime is offline   Reply With Quote
Old 06-24-2011, 05:41 AM   #1419
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
We are working on installation instructions to be posted on the website www.advmonster.com
PM sent
Old 06-24-2011, 07:39 AM   #1420
PhysioWorks
PhysioWorks's Avatar
Oddometer: 53
Hey John
you have a pm. Loukas
PhysioWorks is offline   Reply With Quote
Old 07-07-2011, 08:32 AM   #1421
cccbarkbuster
cccbarkbuster's Avatar
Oddometer: 214
heavy duty mounts
Taking my Buell up nort to da U.P. for da 6 days of Mi. 7/23 to ride when my tired self can`t ride the dirt bike any chance I can get a pair before I leave. Its dark up der at night and critters are lurking in da weeds eh? I want to see em!!
The older I get the faster I was
surviving over 40yrs adventures on 2 wheels
08 Kawasaki klx450r
08 Buell Uly XB12xt
78 BMW R100rs (sold 3/13/11)
04 KTM200exc 09 Kawasaki Versys(daughters)
cccbarkbuster is offline   Reply With Quote
Old 07-07-2011, 04:30 PM   #1422
CrashDBad
Big man, little bike
CrashDBad's Avatar
Oddometer: 2,036
I've had both 24w lights fail with a few thousand miles on them. I assumed they had failed due to vibration. The original diagnosis from Sanjoh was possible RF interference from using with a converted HID headlight. When the 2nd light failed it was suggested the power from the HID was bleeding through and caused a voltage spike.
Both lights were replaced quickly by John. I've since put a few thousand miles on the new set without issue (still have HID as well) . He did say they do not warranty them when used in conjunction with HID lights, but I was unaware of the issue when I purchased them.
CrashDBad is offline   Reply With Quote
Old 07-07-2011, 04:59 PM   #1423
blown7.3lps
Brian
blown7.3lps's Avatar
Oddometer: 641
Send a message via AIM to blown7.3lps Send a message via MSN to blown7.3lps Send a message via Yahoo to blown7.3lps Send a message via Skype™ to blown7.3lps
were is everyone mounting the dimmer? it was much bigger then i thought it was. have not installed it yet.
2004 GS1150A SOLD/ pics, = http://entertainment.webshots.com/ph...=entertainment
2001 CBR600F4i SOLD/ pics, = http://good-times.webshots.com/album...ost=good-times
1975 Kawasaki 90cc trail bike.
blown7.3lps is offline   Reply With Quote
Old 07-07-2011, 07:36 PM   #1424
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,667
Not likely to have the brackets by then as the tooling is still being finished as of today.
Send an email to dave@advmonster.com we may have a some stock brackets available.
Old 07-07-2011, 08:22 PM   #1425
fishEH
Oddometer: 1
Hey guys, new guy here. I actually don't ride, I joined the forum just so I could comment i this thread.
I own a 98 Land Rover Discovery and I offroad it. Right now I run Hella 4000s(100W bulbs). 2 Euro beams and 2 Fog beams, in addition to the headlights.
Does anybody else run these LED's on their trucks for off road use?
How do they compare to Hella 4000's in the amount of light thrown?
fishEH is offline   Reply With Quote
Times are GMT -7.   It's 10:26 AM.
