Old 08-26-2010, 09:08 AM   #61
dunesnstars OP
Oddometer: 160
Originally Posted by dhillr
How many stitches did it take?
Lots!
Keep in mind the picture had to be maginified 1000X to be able to see the extent of the damages!
Passed MSF class... 03/28/10.
Bought my first bike... 03/30/10.
Dropped my first bike... 04/03/10.
The rush from riding on two wheels... priceless.
dunesnstars is offline   Reply With Quote
Old 08-26-2010, 09:23 AM   #62
dunesnstars OP
Oddometer: 160
Originally Posted by sanjoh
You are a fabricating fool.
What did you mount the front of your gravel guard to? Looks like the exhaust?
Yes the front is mounted to the exhaust. I welded a small stainless steel tab to the header. This is another reason I'm a huge proponent of bolting, since aluminum and steel cannot be welded together.
So then I was able to bolt the front of the guard to that tab. The rear of the pan is bolted to brackets I made which is then bolted to the original bolt holes where the oil pan brackets used to be. The brackets I made are actually bent in case I smack something hard enough, the brackets should bend and still protect the exhaust. At least in theory, that's how it should work. Hope this answers your question.
dunesnstars screwed with this post 08-26-2010 at 09:29 AM
Old 08-26-2010, 09:25 AM   #63
dunesnstars OP
Oddometer: 160
Originally Posted by RAGBrian
Been kicking around again about getting a Versys and making it a dual sport. Sheesh, should also have considered the Ninja as well. You build is giving me ideas! Watching with wonderment and taking notes.
You can get Ninjas pretty cheap and you will end up with your very own unique bike. I'm too short for any of the dual sports out there, so I didn't really have a choice but the build has been a lot of fun. But you gotta enjoy this kinda stuff for it to work out well.
Go for it!
Old 08-26-2010, 09:43 AM   #64
Laughingdawg
Oddometer: 385
That can't be true, because every Aegis cruiser is an aluminum superstructure welded to a steel hull. It may be ridiculously expensive in comparison to the value of the bike. But it's definitely possible.
Laughingdawg is offline   Reply With Quote
Old 08-26-2010, 10:25 AM   #65
mpowers
mpowers's Avatar
Oddometer: 738
fwiw
I did a quick search on the cruiser, but my guess would be they used explosion welding to fuse a alum and steel pieces (thus making clad steel), then welded the alum deck structure to the alum side of the fused plate. This is considered cold fusion, where welding stick, mig, tig, shor arc, etc is hot fusion.
Other than that, there are a few solders out in the market that more or less glue the two together-not truley fused and have no real mechanical strenght. These are inexpensive, but would have failed with the first hit from a rock.
mpowers is offline   Reply With Quote
Old 08-26-2010, 02:54 PM   #66
dunesnstars OP
Oddometer: 160
Originally Posted by mpowers
fwiw
Yeah, what he said!
Old 08-26-2010, 07:12 PM   #67
gvthnks
gvthnks's Avatar
Oddometer: 536
fwiw
yup, that's it.
09 Kawi KLR 650
05 Road Kind Custom
01 Suzuki DRZ-250
96 Honda Shadow
93 Honda XR 80
87 Honda XR250r
83 Honda XR350r
73 Honda XL350
73 CB750
73 Yamaha DT-1
wife calls it a sickness. I'm running a M/C rescue
gvthnks is online now   Reply With Quote
Old 08-28-2010, 12:08 PM   #68
dunesnstars OP
Oddometer: 160
Wow! New tires are mounted, racks and side cases are installed! Looking really good!!!
Old 08-28-2010, 01:20 PM   #69
dawgwhat
No Earthy Idea
dawgwhat's Avatar
Oddometer: 569
need pic's or it didn't happen
I got a booger, want some?
dawgwhat is offline   Reply With Quote
Old 08-28-2010, 04:09 PM   #70
dunesnstars OP
Oddometer: 160
Why you don't trust me? I can't believe how good it looks. It's really looking like it should have always been a dual sport!
Old 08-28-2010, 04:19 PM   #71
dawgwhat
No Earthy Idea
dawgwhat's Avatar
Oddometer: 569
I do trust ya...
but you have 2 put up some pic's or it didn't happen
Old 08-28-2010, 09:03 PM   #72
dunesnstars OP
Oddometer: 160
On Thursday, the fittings came in for the coolant tank as well as another set of turn signals and the Givi sidecases.
Yesterday, the Givi racks (thank you Grainbelt!) and tires came in. Within a few hours, the new Avon distanzias were mounted and balanced. This morning, the wheels were installed. And they look pretty damn good!
Still not finished but here's a quick preview of ENja now...
Tomorrow is paint day! Everything gets taken apart, sanded, primered and painted. While waiting for the paint to dry, I need to mess around with the wiring a little and ENja should be almost ready to ride!
Can't wait!
dunesnstars screwed with this post 08-29-2010 at 12:37 PM
Old 08-29-2010, 01:16 AM   #73
Funkydevil
Oddometer: 106
Lookin' pretty darn effin' sweet. I would ask about paint, but I'll just wait and see. Good Job!!!
Funkydevil is offline   Reply With Quote
Old 08-29-2010, 08:15 AM   #74
dawgwhat
No Earthy Idea
dawgwhat's Avatar
Oddometer: 569
Lookin good gf
almost there
Old 08-29-2010, 06:30 PM   #75
dhillr
dhillr's Avatar
Oddometer: 1,604
Looks real nice
Now let's hit some gravel & break that puppy in!!!
dhillr is offline   Reply With Quote
Times are GMT -7.   It's 08:52 PM.
