Old 11-28-2004, 07:03 AM   #1
jtwind OP
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,477
IMO computer on r80g/s
I'm installing a IMO 100r computer on my bmw g/s. The problem at present is with the tach. It registers and reads fine at idle but when the revs are increased the display loses contrast and darkens. Any ideas. A second questions is does anyone know what the rev adaption number for a bmw twin is for this computer. Thanks.
jtwind is offline   Reply With Quote
Old 11-29-2004, 12:53 AM   #2
MiGSel
GaStronaut
MiGSel's Avatar
Oddometer: 395
I've got an IMO on my 1150, and I'm thinking about putting one on my R80G/S as well. Or moving it from the 1150 to the 80 As far as I can remember it's 1. Should show quite easily if the bike is running on idle, has to be around 1000-1100 rpm.
The displayed value gets divided by the factor you put in. So if you get 500 rpm at idle, put in 0.5, if it's 2000rpm > 2.
Your other problem might have something to do with the voltage the alternator delivers at idle being lower. But that's just a guess. I would post the question on the TT support forum. They are very helpfull and they don't mind if you post in English.
Could you post some pics of your setup on the R80G/S?
Cheers,
Michel
On a steel horse I ride...
Accessories are at www.migsel.com
MiGSel is offline   Reply With Quote
Old 12-01-2004, 12:04 AM   #3
kermit
Oddometer: 5
I just installed an IMO 100R300 on my '86 R80G/S. Had no problems with the whole setup. Only needed to adjust the little REV adaptor thingy after the RPM display was a bit funky after the first adjustment. I'd suggest to first disconnect the tach wire and see if you see the problems with the display. If not but they show up when the tach wire is connected make sure you have not adjusted the REV thingy too far to the right hand side.
The REV adaption number is 1 for the airheads.
Good luck!
kermit is offline   Reply With Quote
Old 12-01-2004, 12:09 AM   #4
MiGSel
GaStronaut
MiGSel's Avatar
Oddometer: 395
Hi Kermit,
Any chance of some pics?
If they are not too big (< 1Mb total) you can send 'em to GSrijder@hotmail.com. Otherwise send me a note there and I'll give you another mail address of a big mailbox.
Thanks in advance,
Michel
Old 12-01-2004, 12:25 AM   #5
kermit
Oddometer: 5
Pics
I don't have any pictures yet, but will take some tomorrow and put them up here. I have the Acerbis font light and used the q-tech cockpit bracket. Have a look at this link, my cockpit is pretty much identical to this:
Q-Tech cockpit (number 780)
Old 12-01-2004, 05:05 AM   #6
RoyB
Dartmouth, Massacusetts
Oddometer: 1,578
I installed one on my MZ Bagira and had some initial set-up problems. The folks at Touratech were VERY helpful. Unit works great now and it's a real hoot to play with...........Highly recommended if you are a Gadget Geek
Roy B
Dartmouth, MA www.rvbprecision.com
2007 BMW K1200R Sport abs,2007 DL650 V Strom abs
2004 Honda VFR abs,2001 Moto Guzzi Rosso Mandello
1971 Honda Trail CT90
RoyB is offline   Reply With Quote
Old 12-01-2004, 07:17 AM   #7
Snowdog
Ruminative confabulator
Snowdog's Avatar
Oddometer: 110
Probably an input voltage problem. Recheck the requirement of the unit against what your bike is putting out. The bike may have a voltage regulation issue.
Paul
70 R75/5
96 R1100GS
05 R1200ST
Homer Simpson "Alcohol, the cause of and solution to all life's problems."
Snowdog is offline   Reply With Quote
Old 12-03-2004, 06:51 AM   #8
jtwind OP
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,477
Update
Still haven't figured this out. Tom at Tourtech in Seattle has been helpful. I now know it isn't the tach input. It does have something to do with the voltage. The voltage is only about 13.4 volts when the unit starts to black out, so I doubt if it's too much. The only suggestion is that there is a AC component in the voltage, but I have no idea why or what to do about that. Thanks for the ideas. JT
Old 12-03-2004, 06:56 AM   #9
MiGSel
GaStronaut
MiGSel's Avatar
Oddometer: 395
Have you tried the TT support forum?
Herbert (the boss) is the IMO guru, if anybody knows he does. And he's usually quick to respond.
Cheers,
Michel
Old 12-03-2004, 12:45 PM   #10
jtwind OP
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,477
Thanks Michel
I've been in contact with Tourtech distributor in Seattle at least 10 times. They've been in contact with Tourtech Germany 3-4 times, so far without luck. I believe they're going to send me a replacement unit. It's worth a try but I'm not convinced the computer is the problem. JT
Times are GMT -7.   It's 02:16 AM.
