Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 08-14-2010, 06:50 AM   #1
gmanski OP
gmanski's Avatar
Oddometer: 113
Which memory card for the Garmin GPSmap 60CSX
Hi mates,
which memory card for the Garmin GPSmap 60CSX would you recommend?
On the garmin webpage is mentioned that the garmin GPSmap60CSX just runs with max. 2GB microSD cards, and that the SanDisk Ultra II cards do not work with the device..
On the other hand the Garmin-support told me the GPSmap 60CSX works also with 4GB cards...that leads to a new question: There are only "SDHC-cards" with 4GB...
Has anyone made some experience with 4GB cards in combination with the Garmin GPSmap 60CSX?
Thanks a lot.
Honda XR650R
Kreidler Mustang
gmanski screwed with this post 08-14-2010 at 09:06 AM
gmanski is offline   Reply With Quote
Old 08-15-2010, 10:14 AM   #2
fratermus
Oddometer: 188
I'd stick with a vanilla 2gb card for max compatibility with everything. Speed is not particularly important (Class 2, Class 6, etc).
All conforming SD cards above 2gb are SDHC, per the group that maintains the specs. Before the >2gb spec was finalized there were some SD manufacturers that made cards in the 4gb range. Using those cards (or using them in a device that does not know about SDHC) can result in unpredictable results. Might not work at all, might only see 2gb, might block chunks all over your data.
fratermus is offline   Reply With Quote
Old 08-17-2010, 04:47 PM   #3
CHIA
Ya, right
CHIA's Avatar
Oddometer: 59
I have a standard Kingston 8gb SDHC card in mine, and it works perfectly.
CHIA is offline   Reply With Quote
Old 08-18-2010, 02:22 PM   #4
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,795
$11 for a 4GB card at King Soopers/Kroger... works for me.
Do need to have firmware > v4.x to use the 4GB cards. 3.x takes up to 2GB. Use the "WebUpdater" utility to bring the firmware up to date.
Spewer of the poignant non sequitur
#155 | Mule's Photos | BackCountryRebels | ThumperTalk | Tekrider | TylersBA
SnowMule is online now   Reply With Quote
Old 08-21-2010, 07:06 AM   #5
gmanski OP
gmanski's Avatar
Oddometer: 113
Thanks mates, these are the answers Id expect from the Garmin service...
The firmware = 4.2 Ill go for the 4G card then.
Honda XR650R
Kreidler Mustang
Old 08-21-2010, 07:10 AM   #6
NEVERLOST
NEVERLOST's Avatar
Oddometer: 949
Question
I am thinking of getting a new computer. Will I have issues installing my Garmin NT maps on a new computer?
NEVERLOST is offline   Reply With Quote
Old 08-21-2010, 10:12 AM   #7
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,795
Shouldn't.
Maps are locked to the receiver, not the computer.
Old 08-21-2010, 12:19 PM   #8
gmanski OP
gmanski's Avatar
Oddometer: 113
You will just have trouble when your computer doesnt have the "minimum system requirements" for the software.
But I am pretty sure your new computer will be strong enough ;-)
Honda XR650R
Kreidler Mustang
Old 03-01-2011, 10:44 AM   #9
gmanski OP
gmanski's Avatar
Oddometer: 113
I bought a 4G Sony SDHC-card and it works well with the 60CSX.
Did a lot of testing and there wasnt a single issue with the device.
Thanks for your help mates.
Honda XR650R
Kreidler Mustang
Old 03-02-2011, 03:49 PM   #10
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,281
get the fastest(highest class) card also.
it's the number with the circle around it. higher is better.
maps draw faster.
http://en.wikipedia.org/wiki/Secure_...d_Class_Rating
reality is much over 4gb is mostly useless for most (unless you have an unreal amount of logged .gpx files saved to the card?) you run into the 2025 tile limit way before the card fills and so all that is left to fill on the card is .gpx files.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 03-02-2011, 03:50 PM   #11
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,281
you can go above 4gb though.
Alaska
Old 03-02-2011, 04:29 PM   #12
Countdown
Oddometer: 5,777
Why? I ride at least once a week and have several years (20,000 mi) of tracks on a 2 G.
Jerry Counts
Countdown is offline   Reply With Quote
Old 03-05-2011, 02:41 AM   #13
gmanski OP
gmanski's Avatar
Oddometer: 113
The more space the better it is, no doubt about it, its the same to cylinder capacity
But i am not sure about the 8G card, "CHIA" said 8G work fine.
For my use I think 4GB is way enough, the *.gpx-files are tiny and the Topo Australia V2 just uses 2,3GB of the cars space.
There will be plenty of space left for tracks, routes and POIs.
Honda XR650R
Kreidler Mustang
Old 03-31-2011, 12:29 PM   #14
omeier
omeier's Avatar
Oddometer: 365
I'm using V4.0 I believe and and can't get the unit to read my 8gb card.
am I missing something? Its reads the 2 gb just fine, but when I move the same files onto the 8 gb card it doesn't read it? Any tips?
(I'm using the 8GB as its a spare one I'm not using...)
omeier is offline   Reply With Quote
Old 03-31-2011, 01:18 PM   #15
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,795
- Make sure you're using the latest firmware on teh receiver
- Might try partitioning the card into a 4GB drive...
Times are GMT -7.   It's 02:17 PM.
