Old 02-25-2012, 03:27 PM   #406
K2m
....58....
K2m's Avatar
Oddometer: 2,239
Originally Posted by Pete640 View Post
17 lt in mine so Tony should b getting the same or very close to as well.
That's more like what you would expect. Very good
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 02-25-2012, 03:42 PM   #407
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
Bravo Pete! And congrats to the fortunate first owners!
Ohhhh, rally-replicas are so freakin' sweeeeeeeeet...
viola-tor is offline   Reply With Quote
Old 02-26-2012, 02:08 PM   #408
MrSandman818
INaVANdownBYtheRIVER
MrSandman818's Avatar
Oddometer: 849
Niiiiiice
Originally Posted by ciedema View Post
It is the standard HB one drilled to suit the KTM mounts. I had it on the bike before mounting the tanks so the standard one should fit also. And yes still hook the Gobis up.
I am here: http://maps.google.com/maps?ll=-27.604865,152.924848
Snet from ym iPohne using Tapatalk
You could do some James Bond shit and connect the seat latch cable to the shock adjuster. Everytime you lift the adjuster to dial in the rear suspension the seat opens up!
Originally Posted by Deadly99 View Post
I was thinking of putting a longer wire on and attaching it to a lever mounted near the shock resorvoir (sorta like the SE has).
-Chrome don't getcha home, but carbon fiber sure is fancy
2005 KTM 950 Adventure - back from the dead, Was totaled.
2005 Yamaha YZ250F - low compression, because race bike
1989 Yamaha TW200 - clapped out from a tweaker
1978 Batavus 48 - back from the dead. Parked since 83'
MrSandman818 is offline   Reply With Quote
Old 03-03-2012, 05:07 AM   #409
Frgich
Frgich's Avatar
Oddometer: 875
Amazing fabrication and finish
www.lobagola.com motorcycle and bicycle friendly bed & breakfast in http://goo.gl/GvQiNs, Zagreb, Croatia
Frgich is offline   Reply With Quote
Old 03-07-2012, 03:38 AM   #410
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Sorry no decent pictures yet. A week of Gastro and some shake down issues have kept me busy.
But here are some with the plumbing complete and Gobi's mounted.
Extra Petcock for rear tanks. The beauty of this is that you can drain either front or rear tanks.
The fuel level is really easy to see.
Gobi's still fit up okay.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 03-07-2012, 04:29 AM   #411
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,787
Ur not running the rear exh bung? Must b westing ear plugs ...
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 03-07-2012, 04:43 AM   #412
MrSandman818
Oddometer: 849
Hey dude, did you have to make your rear racks wider to accommodate the aux tanks? It's kinda hard to see onnmy iPhone but are the gobis going to rub the tanks?
Old 03-07-2012, 05:10 AM   #413
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
No and no. All that was done was to modify the mounting position. About a 10mm gap between the tanks and panniers.
I am here: http://tapatalk.com/map.php?gj2wwu
Old 03-07-2012, 05:13 AM   #414
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Wheezes like an old lady climbing stairs with it in. Have to find a compromise maybe cut it down. It not much louder than with the Wings just a little higher pitch.
I am here: http://tapatalk.com/map.php?oaj3jk
Old 03-07-2012, 08:14 AM   #415
Pete640 OP
I hate sand.......
Pete640's Avatar
Oddometer: 1,787
I cut about 40mm off the end of mine. Seems to work pretty well but I'm not running any cone baffle after the header tho!
Pete
Old 03-07-2012, 01:01 PM   #416
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
I don't have the cone in either. I like the idea of a cut down baffle though
Old 03-09-2012, 01:01 AM   #417
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
Okay so review finally.
So I said I would do a review of the tanks and fitting them.
I should start of with my purpose for wanting the tanks: My wife and I are doing a multi year trip through western and eastern Europe, Russia, the 'Stans, Mongolia, Asia and Africa. The tanks are there to give me a range of about 550ks.
For this the tanks need to last over some pretty uneven ground, but no worse than what we would encounter travelling in Australia.
So:
The tanks: They feel very solid and the finish is excellent. I do wonder about the mounts not be being rubber based, but time well tell and Pete's seem to be just fine. The sub frame has foam tape at all the contact points so this does act a damper for movement. Fuel fittings are all Banjo type fittings and the female ends are well mounted into the tank. The parts supplied make mounting easy and pretty much came with everything I needed.
Fitting:
There is *a lot* of cutting to do to fit the tanks and once done you wont be able to fit the side panels again without buying the rear fender (P/N 600 08 013 000) I found a hacksaw blade and side cutters worked the best.
Once the cutting is done a couple of threaded holes will need to be drilled on the sub frame where the exhaust mounts current bolt to, this not mission critical as you could just put normal bolts there if you wanted to revert.
The tanks bolt up very easily, there is a flange on each tank that mounts the bottom of the tank behind the footpeg, these need to be marked and drilled, on the left side you will need some longer counter sunk bolts to remount the foot peg. On the right side the one that come with the GPR exhaust are just fine.
The fuel hoses took a bit mucking about until I was happy with there locations, it tees into the fuel pump suction on the bottom side of the voltage reg an alternate would be to tee into the connecting tube for the main tanks. On the other end they run as per the about pictures. Pete has run his slightly differently, but I worried about hitting the swing arm if was on the inside of the subframe. The connecting tube for the rear tanks runs along the cross brace at the back of the main frame, this makes it little higher than bottom of the right tank, but I think this should suit. A warning - I runed the washers on the banjo bolt a tightening it and then loosening it reposition the bayonet. I had a nice steady drip of fuel onto a nice hot exhaust.
With the GPR all I had to change was the postion the of rear mounting bracket. I used the exhaust bracket from the other-side and mounted it back about 2".
All in all they are great product and I am very happy with them.
Some last photos.
Old 03-09-2012, 02:42 AM   #418
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,021
I'm getting ready to mount mine and have been contemplating where to run the fuel lines. Have you found out how much fuel doesn't drain from the tanks yet (due to the way you routed the lines high)? I was thinking of routing them in a similar fashion
May I also ask where you route the wires (rear lights) after you removed the plastics that run along the sides of the subframe?
Cheers, your bike looks great
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 03-09-2012, 03:08 AM   #419
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
It looks like it drains most if not all of the fuel routed this way.
Heres how I routed the light wires.
I am here: http://tapatalk.com/map.php?k35zhy
Old 03-09-2012, 04:47 AM   #420
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,021
Thanks, I have an aluminum tool box under my seat so I'll have to figure something out.
Good to hear about the fuel draining, I was a bit hesitant to have an increase in height. Thanks for "testing"
Roaming Rally 2015
Times are GMT -7.   It's 04:11 PM.
