Old 09-02-2010, 11:21 PM   #16
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 3,061
a simple tec from 100 years ago that is mostly forgotten is the fact that they used paper over a wood body to make boat, carts. They varnished with 4 or 5 coats which made it water proof and stable. Simple to repair if damaged. Got the info out of popular mechanic mags when someone build a small boat using the method. It would make a interesting light way to cover a slip streamed body. Anyway just an old strange way of building things. They used a heavy brown butcher type paper.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Old 09-03-2010, 11:40 AM   #17
mac66
Quasi Adventurer
mac66's Avatar
Oddometer: 240
Seems like that would be heavy. The other issue that Craig Vetter addressed is cross wind. A full length fairing is a lot of area that is susceptible to cross wind which is why he and others leave a space between front and back sections.
S/E Michigan
'02 DRZ400s-SOLD
'75 XL175
3/CT90s
Honda Spree
mac66 is offline   Reply With Quote
Old 09-04-2010, 01:49 AM   #18
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,716
In the mid-seventies I built a chopper based on a Honda XL-350. The frame was cut down to a drop-centre form which, combined with a lengthened swingarm suspended with shorter shocks, made for a radically lower riding position. Of course the rear mudguard (fender) had to be moved up higher in the frame.
A small tombstone windscreen was attached to the handlebars and performed good duty in protecting the rider from the airstream.
Road rubber went on the wheels and the gearing was changed by a factor of increasing the number of teeth on the drive sprocket. Engine speed was far lower than a stock XL, and the fuel consumption was in the region of 80-85 m.p.g. Imperial (66-71 m.p.g. US).
This machine is shown in the middle of this line-up:
Its difficult to pick-out the rider's seat (the rider's back-rest is visible) but its not much higher than the kickstart pedal & carburetor. When footing the machine stationary; the rider's legs were bent sharply. You could almost place a fullface helmet on the seat and still straddle that! The front forks remained standard Honda and the steering worked well at speed, but tended to flop at slower paces.
If that had been fitted with a full dustbin fairing it would have needed higher gearing and 90+mpg Imp may have resulted. The 350cc single is one of the most fuel efficient displacements when balancing speed and usability. 125-200 cc sizes may achieve better but speed during hill-climbing would be sacrificed.
'08 Suzuki AN650A Burgman (and trailer)
vortexau is offline   Reply With Quote
Old 09-09-2010, 12:37 AM   #19
OregonGreenBud
Oddometer: 8
Aren't you a dead man pretty much the first time a semi blows by you at speed or at the first good unexpected gust at the wrong time if you use two wheels? On race tracks or salt flats it's one thing, but when just a few feet the wrong direction could put you into something solid, or worse something going the other direction...
I jumped in actually because I had thought of this before but then decided a safer route, more usable machine all around would be to take a gy6 150cc scooter I have and hacking the motor and rear wheel out of and make what would look like a typical velocycle recument trike, two wheels in the front, one in rear like this:
Except at speed front steering a trike, I don't know, could be really scary if not well laid out.
You'd have to add a wheel, basic frame, and a little more work, but you could still use that scooter to start.
A 3 wheel trike is road legal as a motorcycle, same laws, you would need to maintain the VIN part of the frame somehow in it though, just fyi, but it's no different than a person making a chopper bike into a trike you still register and insure it as the original bike, it's just faired.
http://www.velomobiling.com/gallery2...c89b46bb78aa5e
I would want a long low bullet shape myself for high speed/long distance but there are all kinds of cool designs out there, just look on google images or whatever for velomobiles.
Many of those are human powered only, that's why there's gatorade in this next pic, but you get the idea.
OregonGreenBud screwed with this post 09-09-2010 at 01:44 AM
OregonGreenBud is offline   Reply With Quote
Old 09-09-2010, 07:22 AM   #20
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,344
I'd think a trike would be worse, no ability to dynamicly lean against the side wind or gust, much heavier construction. Trikes ( barring the MP3 design which can lean..) are notoriously unstable no matter what the configuration. You might as well admit you can't ride two wheels.
As one who has ridden semi faired in recumbent (zipper bubble fairing on a LWB recumbent) in traffic, they're no worse than riding an upright commuter bike.
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 09-09-2010, 09:13 PM   #21
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,716
Good looking trikes. Consider this 'though; is it wise to spend $15,000 to build a road machine with severe limitations (including being able to carry just one small-ish rider) just to save some gas?
Of all 250cc stock motor scooters sold in the US, the Morphous should have delivered the highest mileage figures. If the Suzuki Gemma had been imported, that may have been the only 250cc to challenge that.
Old 09-09-2010, 09:30 PM   #22
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,716
THAT remains the rub! You spend a lot of money to get a vehicle with low-running costs, but blow your budget in the process.
http://www.flytheroad.com/
"Carver tilting technology (the same technology licensed by Persu Mobility) makes three-wheel vehicles commercially viable for the first time ever by solving the stability issue inherent in non-tilting three wheel vehicles. The advantage of three-wheel vehicles is that they are lighter weight, use less materials and smaller batteries, and are more aerodynamic."
"The Persu Hybrid parallel hybrid will include an internal combustion engine, an electric motor and a CVT (Continuously Variable Transmission)".
If this Persu Hybrid parallel hybrid costs as much as four 250cc maxis, who's going be the buying market for it?
Old 09-10-2010, 02:08 AM   #23
OregonGreenBud
Oddometer: 8
Yes I would miss being able to lean also, two wheels is just too much fun and certainly lighter and better in the corners, only for sidewind like a semi blasting you off the road did I think I'd want 3 wheels.
I guess they already exist in s couple forms so it must be safe, here's some I just found:
http://www.youtube.com/watch?v=VbdkZ...1&feature=fvwp
http://www.youtube.com/watch?v=7Dogk...eature=related
http://www.youtube.com/watch?v=vF_HNwzGARw
http://www.youtube.com/watch?v=vETsb...eature=related
I had no idea, then I found one vid and it led me to the rest.
Very interesting, I really want to try one of those out now that I've watched those in action. It looks like a blast.
OregonGreenBud screwed with this post 09-10-2010 at 02:49 AM
Old 09-10-2010, 05:31 PM   #24
OregonGreenBud
Oddometer: 8
I don't know about the op but I was thinking more garage built under 1k total using used/scrap parts most of which I already have.
I don't see a need for an electronic stabilizer system or a/c or anything fancy to start with, down the road maybe. If I were able to afford a project like this the most I would want to do is invest a little extra money in the shell and make it out of rivited aluminum panels to look like a vintage streamliner salt flat racer. I don't think I'd paint it though, just polish it.
http://www.rbracing-rsr.com/bullett_2010.html
I think the op was looking for more like this though right?
OregonGreenBud screwed with this post 09-10-2010 at 06:30 PM
Old 09-10-2010, 08:21 PM   #25
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
This is so cool!
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius screwed with this post 09-10-2010 at 08:30 PM
EvilGenius is offline   Reply With Quote
Old 09-10-2010, 08:38 PM   #26
OregonGreenBud
Oddometer: 8
Check this out: 150mph with 50cc's.
http://www.youtube.com/watch?v=mYINr...next=1&index=4
Just for a better look at the outside of that one:
http://www.youtube.com/watch?v=1U4bO...eature=related
And inside:
http://www.youtube.com/watch?v=Df8XV...eature=related
Anyone have a spare aluminum canoe laying around?
You can see a couple of those and hear results of them and everything else in this video below. Nice for comparison to see what they're capable of. Speaking of comparison Shinyo Kamura's harley powered needle bike only reaches 100 in this.
http://www.youtube.com/watch?v=HwMxf...eature=channel
125cc
http://www.youtube.com/watch?v=Vz_r_...eature=related
And here's just a modded standard open bike with recumbant seating, note he's actually reclining I love it. :)
http://www.youtube.com/watch?v=C4mUQ...eature=related
http://www.youtube.com/watch?v=8YrK6...eature=related
And while not a scooter, this looked cool:
http://www.youtube.com/watch?v=KjNa6...eature=related
more info on that one:
http://web1.acabion.ibone.ch/acabion.../3-media-show/#
And you might like the look of this:
http://www.youtube.com/watch?v=Hs4GX...eature=related
This isn't the same thing really but looks so f'n cool:
OregonGreenBud screwed with this post 09-11-2010 at 04:47 AM
Old 09-11-2010, 10:56 AM   #27
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Originally Posted by mac66
Thread is really interesting. I looked at the Vetter site and he seems to be behind the curve compared to the feet forward crowd.
I then read some of the other threads including several about the Ruckus. It hit me like a bolt out of the blue. (I just read one of the about responses about using a Ruckus) Those guys who lower and stretch the Ruckus have got a perfect platform for a feet forward/recumbent streamlined scooter. Throw a bigger GY6 engine in it and you would have a pretty cool aerodynamic cruiser.
They make full GY6 swaps that extend the wheel base too.
Not cheap, but they're there.
Old 09-11-2010, 02:12 PM   #28
OregonGreenBud
Oddometer: 8
Frame:
Shell base
150cc gy6 with reverse from a buggy
OregonGreenBud screwed with this post 09-11-2010 at 04:13 PM
Old 09-11-2010, 08:28 PM   #29
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Originally Posted by OregonGreenBud
Frame:
There's a guy around here I've seen a couple of times who took a bomb like that except he extended it a little and put a WWII style fighter cockpit on top and would ride around in it.
Looked cool going down the road, but was a little too long.
Old 09-12-2010, 02:04 AM   #30
OregonGreenBud
Oddometer: 8
I'd like to see that one...
Here's an amphibious trike with a 110 yamaha mio scooter motor, someone else thinks like me. ~300lbs total for the whole car (which is less than my 150cc scooter stock) and it says it does 70mph easily on the freeway.
http://www.youtube.com/watch?v=6LSEF...layer_embedded#!
http://www.spira4u.com/
http://www.gizmag.com/foam-bodied-sp...n-roads/11817/
See how light and strong an all alumunum chassis can be? Shape and then rivet that ladder into the bottom of the canoe and sheet over the top of that for a smooth floor, then fill the whole floor with expanded foam and it would be plenty strong and light, and the thing could never sink even if it weren't water tight.
I've sorta gone off track op, sorry. Maybe I should start another thread about my land speed looking floating canoe cruiser water battling scooter idea, I'm sure it's not at all what you had in mind.
Excuse me while I try to imagine how the motor would retract up inside to friction drive a prop. http://www.youtube.com/watch?v=lbDT0...eature=related
Or a jet ski propulsion system take off?
http://www.youtube.com/watch?v=O562VTz7YnU&feature=fvw
You can tell I have too much free time.
http://www.youtube.com/watch?v=wObfl...eature=related
http://www.youtube.com/watch?v=usKFo...eature=related
http://www.youtube.com/watch?v=LcFX5...eature=related
http://theselvedgeyard.files.wordpre...pg?w=600&h=439
http://t3.gstatic.com/images?q=tbn:R.../EV-X7.jpg&t=1
http://farm1.static.flickr.com/106/3...bb3021.jpg?v=0
I think that's enough...
Nope, can't resist, you gotta love this with the feet out:
OregonGreenBud screwed with this post 09-12-2010 at 09:24 PM
Times are GMT -7.   It's 01:34 PM.
