Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 11-21-2010, 11:11 AM   #181
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,358
No, Picture?
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 11-21-2010, 11:22 AM   #182
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Originally Posted by BMWRSNUT
No, Picture?
They're no good on the DR rear as it can't get past the safety bead.
NordieBoy is offline   Reply With Quote
Old 11-21-2010, 10:27 PM   #183
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,358
U-joint wear
The symptoms were a vibration from the driveshaft at full throttle.
I've now pulled the driveshaft, and the top U-joint is starting to feel wear.
Turning the u-joint to the extent of its travel one way & slowly rotating across to the opposite side you can feel resistance, then a portion where the u-joint moves somewhat more freely then resistance. I assume the freer movement is where the u-joint most frequently rotates. There is no discernable play, nor any roughness in the bearings.
I'm going to talk to Mike Dobson tommorrow re the possibility of repair / replacement, and how long he thinks I can run this driveshaft 'as is' (I assume that i'll take 2 or so weeks to get a replacement here - but I want to ride it in the interim).
Originally Posted by Mark S
The lies we tell our wives so we can buy the toys we want. What a load of bollocks. Anyway the 'lets do something exciting' gene disappears from the average female mind the moment the first offspring arrives. Bike looks really good though - except for the seat
No, she's been hanging out for me to complete it. Katherine's almost old enough to leave 'home alone', so we're keen to get out together again. She travelled 3 yrs round Europe & the UK with me 20 yrs ago. We've been talking about travelling again, & this will be the bike that we do it on.
On another topic, Fran I'd imagine that your 'snow shovel' would also require a FBH, so likely not a tool to carry on the trail then....
Box'a'bits screwed with this post 11-21-2010 at 11:49 PM
Old 11-21-2010, 11:01 PM   #184
igormortis
igormortis's Avatar
Oddometer: 1,380
Let me know if you decide on an aftermarket option - I need to do mine as preventative maintenance and would split shipping with you.
igormortis is offline   Reply With Quote
Old 11-21-2010, 11:15 PM   #185
Old Kiwi#99
Oddometer: 287
Originally Posted by Eddieb
Tie the lever in against the grip as much as you can and leave it overnight. The next morning you will have all the pressure you need.
Not recommended. All this does is cause any air in the system to dissolve into the fluid. The air WILL separate out again, leaving you with spongy brakes (probably at a time when you really, really NEED good brakes.)
Old Kiwi#99 is offline   Reply With Quote
Old 11-21-2010, 11:40 PM   #186
Padmei
enamoured
Oddometer: 3,735
i thought it made the air rise to the reservior & release there. I did it when I did my brakes & was ok however the levers do need feathering now & then when riding along without using them for a while as they feel spongy.
On a knarly ride the brakes work best when being used all the time.
Padmei is online now   Reply With Quote
Old 11-21-2010, 11:54 PM   #187
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,358
Originally Posted by Padmei
I thought it made the air rise to the reservoir & release there.
I guess to an extent. But I think that this solution masks (rather than fixes) the situation. The air is generally in the caliper, not the lines near the mastercylinder. I tend to agree with Old Kiwi#99. The air doesn't disappear.
However the levers do need feathering now & then when riding along without using them for a while as they feel spongy.
That would imply that you are getting air into the lines from somewhere. Not good.
BTW, not being competitive or anything, but I've finally exceeded your threads hit count....
Box'a'bits screwed with this post 11-22-2010 at 12:11 AM
Old 11-22-2010, 12:32 AM   #188
junkmanjoe
junkmanjoe's Avatar
Oddometer: 508
Originally Posted by Mark_S
I'm getting itchy feet to have lunch here
So hurry up and get that thing done....
quite keen to get back there my self.....
steve.. thats a beastly tank mate.........you looking to ride the length of nz in one go.......
have to come down to wellys and catch up one sunday....
JMJ
I FEEL THE NEED THE NEED FOR SPEED.
CAN VIEW MY RIDE PICS HERE.
http://picasaweb.google.com/sueycarter
junkmanjoe is offline   Reply With Quote
Old 11-22-2010, 12:35 AM   #189
guzzitony
Guzton
guzzitony's Avatar
Oddometer: 170
LOOKING GOOD!
re; the indicators, just get a cheap flasher unit for the 10w bulbs. cheap and piece of piss. i think it'll plug strait in but i'd better check that first. Heaps better than trying to F A with resistors.....
SHEDSAM- objects given/collected and stored in a
shed/mancave. esp car/bike parts.
guzzitony is offline   Reply With Quote
Old 11-22-2010, 01:11 AM   #190
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,358
Originally Posted by guzzitony
LOOKING GOOD! Re: the indicators, just get a cheap flasher unit for the 10w bulbs. cheap and piece of piss. I think it'll plug strait in but I'd better check that first. Heaps better than trying to F A with resistors.....
The flasher is the 'K' bike unit. The resistor thing is mainly cause thats a $2.00 spend rather than $80+. I look on the FAF'ing as a $78 investment.. Not that I'm likely to get that sorted yet anyway. Who care's if the blinkers flash too fast???
Originally Posted by Junkmanjoe
Quite keen to get back there my self.....
Mark S & I were thinking about doing the 42nd / Fishers/Old Whanga this w/e....But I need confidence that the driveshaft will make it...If not we'll defer 2 weeks...
Nothing to report just trying to beat Steve's thread hit count. Man I'm pathetic...
I knew that would stir you into action!!
Old 11-22-2010, 12:24 PM   #191
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Or a rock/branch etc...
Old 11-22-2010, 03:26 PM   #192
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,358
42nd / Fishers / Old Whanga Rd
So talked with Mike at Motorad this am, & he's confident the driveshaft is okay to go back in the bike. The downside is I haven't identified where the vibration is coming from.
The ride this weekend with Mark S is all go.
We're intending to meet at the Waikanae coffee cart at 8.00 Saturday (27th Nov). Ride to meet Bart at Shannon or Ashhurst (he's just going for a day trip), perhaps take in Takapari Rd, backroads to Taihape, ride the station before Gentle Annie etc. .
Then Mark S & I will do 42nd Traverse & we'll stay in Taumaranui, & we'll use that as a base to do Fishers & Old Whanga Rd & a few other worthy road / tracks. Home Monday.
Basically make it up as we go along.
Let me know if you want to come along.
Old 11-22-2010, 04:48 PM   #193
igormortis
igormortis's Avatar
Oddometer: 1,380
How do I convince Penny that we need to take the bike to her brother's 21st in the King Country this weekend?
Old 11-22-2010, 08:53 PM   #194
Box'a'bits OP
In need of repair
Box'a'bits's Avatar
Oddometer: 2,358
If you can't convince her that it's a nice weekend for a ride, you could always borrow my trailer.... ...
Or better - tell her you'll meet her there!
Box'a'bits screwed with this post 11-22-2010 at 09:49 PM
Old 11-23-2010, 01:54 AM   #195
Mileater
Mileater's Avatar
Oddometer: 379
Talking
Enjoying the thread and the banter but your tyre beading problems has prompted me a little... try a 50/50 mix of Sunlight (or other) dishwash liquid and water brushed onto the tyre/rim. It will not hurt the "rubber" and when it dries out... well let us say that there shouldn't be any inadvertent tyre rotation problems When it comes time to remove the tyre, I have never had any problems once the bead is broken and brushing on some more "bead lube" will aid removal too. Cheap and cheerful R us
Cheers,
Allan
"Enough Robert Pirsig-esque philosophizing. My bike didn’t need maintanenece and my Zen was around the next corner. Time to ride." Sly-on-2
Mileater is offline   Reply With Quote
Times are GMT -7.   It's 08:39 AM.
