Old 08-22-2010, 08:02 AM   #1
vdv2020 OP
Luxembiker
vdv2020's Avatar
Oddometer: 163
France and Belgium - near Lamorteau
On the border of Belgium and France there is a forest. There is an old road leading to Pont Camus. First it's a hard gravel road with ruts made by water. Then it changes to a dirt road partially overgrown with grass. It was rainy for the last week so I had to negotiate muddy road where sun has no access. I have reached dry dirt road and arrived on tarmac by a cross put up in memory of the people killed during French Revolution.
Arriving at Lamorteau:
Then turned sharp left and went on the other side of the valley with a view towards Virton:
This way I have came from:
From there I tried to go along the valley, but the road was closed. So I took the one going up hill. It was tough, rocky with boulders and all wet. As long as I have pressed on allowing the bike to dance around I was doing progress. But when I was forced to stop I had problem to start again. Back wheel was spinning on a wet rock. Some swinging and pushing helped, but it was not without a slowmo drop in the process.
Surely you can't see the incline on the photos.
Finally, sweating, I have made it to the normal road in the fields.
The cross was made in the 16th century and has been even sold at some point!
From there once again I took a road that was closed after some 500m. So I took another one and ended up in a field. The map was showing a road. Confused I went on a muddy road leading into the woods. It was real muddy. Checking the GPS I have realized that it will lead me nowhere. So I turned to reach the field I have seen before. Once there I just followed tracks on the harvested field and finally reached bumpy dirt road.
Here is the track from that day:
Lamorteau
Plan your trips with EveryTrail iPhone Travel Guides
Best regards,
VdV
_________
Transalp XL700VA 2009 yello
vdv2020 is offline   Reply With Quote
Old 08-22-2010, 09:45 AM   #2
Richzrx12
Richzrx12's Avatar
Oddometer: 68
VDV - nice trip, and good effort on the Transalp. Makes me want to head North and try some of those trails.
Expecting life to be fair to you because you're a good person is like expecting a bull not to charge because you're a vegetarian.
Richzrx12 is offline   Reply With Quote
Old 08-22-2010, 10:53 AM   #3
AZ_ADV_RIDER
Demons In My Helmet
AZ_ADV_RIDER's Avatar
Oddometer: 816
beautiful countryside - even the mud looks friendly!
- Mark
The road to enlightenment is not paved.
AZ_ADV_RIDER is offline   Reply With Quote
Old 08-22-2010, 12:10 PM   #4
vdv2020 OP
Luxembiker
vdv2020's Avatar
Oddometer: 163
Thanks, TA is must be good for such a heavy bike, because I am just a noob ;)
The not-so-friendly mud I was handling, not photographing
Best regards,
VdV
_________
Times are GMT -7.   It's 04:57 AM.
