Old 05-20-2005, 09:12 AM   #136
rockhopper
rockhopper's Avatar
Oddometer: 196
Originally Posted by meat popsicle
More ideas and transfers from the other thread:
speaking to the local Peli guy today, says they are bringing out a third "cube case" around 17-18" square in september, maybe good for bike mounting, also has anyone come across explorer cases, as they do a case [part number 5833 ] , which may be good as a pannier
Cheers
Chris
rockhopper is offline   Reply With Quote
Old 05-20-2005, 09:54 AM   #137
Gusgus
Gusgus's Avatar
Oddometer: 5,308
Here are the specs
A= 580mm or 22 13/16"
B= 44mm or 17 5/16"
C= 330mm or 13"
D= 60mm or 2 3/8 "
E= 270mm or 10 5/8"
Sounds a bit thick on C, the bags I have been looking at, the 1550's are much thinner.
Looking at the other explorer bags the 5822 looks pretty good!
Gusgus screwed with this post 05-20-2005 at 10:02 AM
Gusgus is offline   Reply With Quote
Old 05-20-2005, 09:58 AM   #138
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,236
Price: £999.00
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is online now   Reply With Quote
Old 03-07-2006, 02:48 PM   #139
meat popsicle
Ignostic
Oddometer: 14,236
Bump, cause I miss Ricardo! best of luck Senior Suave.
And a note for you DIY folks: I read in another thread that Pelican might be coming out with a larger version of their top loading 1430 that's the one everyone wants for panniers. Fingers crossed!
And how about a link to some nice accessories for the 1430:
http://www.pelicanproducts.ca/Cases/1430_case.htm
I like #1439 - Lid Organizer - looks handy
Old 04-29-2006, 08:12 PM   #140
KTM640Dakar
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,089
Has anyone used these brackets for the 1430 to rig a rack?
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 05-20-2006, 08:04 AM   #141
TexasShadow
Where's the escape hatch?
TexasShadow's Avatar
Oddometer: 610
Pelican topcase for DL650
Anyone added/mounted a Pelican top case on a DL650 (Wee-strom)?
TexasShadow is offline   Reply With Quote
Old 05-20-2006, 11:00 AM   #142
CA_Strom
Cunning Linguist
CA_Strom's Avatar
Oddometer: 2,228
Pelican top case on Wee Strom
Here's my Pelican 1500 top case on my DL650. Perfect size to hold my soft side brief case containing a IBM Stinkpad, portfolio, pda, etc... The briefcase fills the entire case. Very simple to install, get longer bolts for the two rear rack bolts. I also used a third near the back through an existing rack hole. Remove the rack, bolt on the back bolt/nut and then replace the rack. Ignore the plastic plugs on the case, the first time I installed it , the case was too far forward and you could not remove the seat.
CA_Strom is offline   Reply With Quote
Old 05-20-2006, 05:44 PM   #143
TexasShadow
Oddometer: 610
Excellent. Can your mount be modified to be quick release? (aka take off bike to carry into tent/motel/house and put on again to depart)
Old 05-20-2006, 09:16 PM   #144
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Is a wing nut quick enough?
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 05-21-2006, 08:10 AM   #145
TexasShadow
Oddometer: 610
The only problem with that is the contents must be removed to access the wingnuts in the bottom of the case; unless they are on the outside of the case.
Old 05-22-2006, 09:24 AM   #146
CA_Strom
Cunning Linguist
CA_Strom's Avatar
Oddometer: 2,228
To make the top case quick release, you'd need to engineer some type of base plate with a QR lock and then bolt the case to that top plate. Should be pretty easy with some patio door locks and a bit of sturdy plastic or metal.
Old 05-22-2006, 12:05 PM   #147
fire_strom
fire_strom's Avatar
Oddometer: 1,256
Officially motor free
9 cycles with pedals
fire_strom is offline   Reply With Quote
Old 05-27-2006, 02:54 PM   #148
PeteC
Old Rider
Oddometer: 39
Pelican 1550 Case & top box on DR650
Here is the set up I just made for Pelican 1550 side cases & a top box for
my '06 DR650 Suzuki. I designed the case racks so the cases can be
slide on & off in seconds, with the cases locked in place with padlocks.
The cases attach to the racks by brackets on the cases. The bottom
bracket is U shaped & slides onto the lower rail of the racks. The upper
brackets have 3/8" X 1 1/4" pins that slide into place on the upper part of
the racks, the front one into the top rail tube & the rear one into a short tube
welded on top of the upper rail. The lower rack rail is covered with a piece
of 3/4" ID auto heater hose & the pins are covered with 3/8" ID fuel hose
which makes the cases rubber mounted, thus no rattles. The front hose is
about twice as long as the pin, which allows the front pin to start first
making it easier to align the rear pin to slide the case into place. The racks
are very strong & are lighter than they look. The case racks together weigh
about 8.5 lbs. & the tail rack is 4.5 lbs.
Here are some pics of the bike with the cases on & off & a set of 4 pics
showing how the cases slide onto the racks.
PeteC
PeteC screwed with this post 05-27-2006 at 03:01 PM
PeteC is offline   Reply With Quote
Old 05-27-2006, 03:41 PM   #149
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Sane work man! Pretty darn good mounting design
Looks strong as...well really strong!
Surly
Where is Surly?
Old 05-27-2006, 09:46 PM   #150
firerigger
Trauma waiting to happen
firerigger's Avatar
Oddometer: 810
Best way to mount Pelicans
Check out this thread: http://www.advrider.com/forums/showthread.php?t=102759
Totally bombproof, very easy to use, lockable and removeable.
firerigger is offline   Reply With Quote
Times are GMT -7.   It's 12:10 PM.
