Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Old 03-28-2010, 03:56 PM   #811
RiDR
The Himalayan what?
RiDR's Avatar
Oddometer: 592
Route to Waypoints
I have a Nuvi 550 and am trying to convert a route to a series of waypoints to load into my buddies Nuvi 255W which according to specs is capable of 1000 waypoints, only problem is when doing this in mapsource and loading to his GPS, each waypoint shows up as a seperate listing under his favorites ... any way around this?
RiDR is offline   Reply With Quote
Old 03-28-2010, 04:44 PM   #812
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,766
Nope. Waypoint = favorite.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 03-31-2010, 02:35 PM   #813
Trickie Dick
Oddometer: 33
Scala G4 -Nuvi 765T
I paired the G4 with my 765T few weeks ago and it worked fine. However, recently when I tried to pair a 2nd G4(I have the powerset), it would not pair. The Nuvi would recognize the G4 but would not link to it. After many tries I cleared the original G4 headset off the nuvi to see if that would help. Now neither headset will pair with the Nuvi. I emailed Cardo Scala but thought I would try here in the real world.
Trickie Dick is offline   Reply With Quote
Old 03-31-2010, 10:51 PM   #814
DavNadZ
DavNadZ's Avatar
Oddometer: 11
Originally Posted by tellicotom
I talked to a salesman at Amazon.com that said that the vibration on a bike would kill the Nuvi. Is that true or is he just trying to sell the Zumo for 5X the cost?
Thanks...
He's half right... I'm using a Nuvi 500 (refurb for $150) in place of a Zumo 220 ($600 retail). It is the same hardware, except no bluetooth module. The other Nuvi's are weak, but the Nuvi 500 and 550 are ruggedized enough for a bike. -Nadz
https://buy.garmin.com/shop/compare....eProduct=65210
DavNadZ is offline   Reply With Quote
Old 04-01-2010, 03:14 PM   #815
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,325
Nuvi torture testing
Its still too soon to tell, but I have been using my Nuvi 550 on my KTM 640 Adventure for the past few months.
3 months of vibes on an KTM 640 is like 3 years on just about any other bike
Ogre_fl is offline   Reply With Quote
Old 04-02-2010, 08:53 AM   #816
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 11,375
If I have my Nuvi 500, 350 and 200 registered with Garmin and all updates complete can I consider their maps ok or do I need more?
If I purchase detailed topo maps for offroading on the 500 will it apply to all units or just the 500?
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Old 04-08-2010, 01:50 PM   #817
nvdlboy
nvdlboy's Avatar
Location: North Vancouver, BC (right beside the forest)
Oddometer: 991
Originally Posted by Ogre_fl
Do you need the old versions of the maps?
If not I wonder if you could delete/remove your current Mapsource program & maps from the computer and try the 2010.4 download again.
It should treat it as a new install and what ever is keeping that/those regions from being loaded should go away.
I would call Garmin tech support and suggest this and ask them if they can set it up for you to try another download.
Update - well, here's what happened... my PC died a couple of weeks ago, bought a new one and when I reinstalled from my 2010.4 disk that I got last year when I bought the 550, lo and behold all the detail that would not load before from the disk is there. Hallelujeuh!! So yes, your suggestion would also have fixed it, but the gremlins in my PC beat me to the punch. (BTW my download never did work due to the conflicts between my anti-virus and the file size).
Current - Wee strom K7
Previous - DRZ400SK4
nvdlboy is offline   Reply With Quote
Old 04-27-2010, 08:55 PM   #818
bigtallguy
Sasquatch Jr.
bigtallguy's Avatar
Oddometer: 254
I have a nuvi 205 and am trying to figure out a way to plan a route on the computer and then get it to show up on the gps. Is there any way to do that?
So far I can only get it to save a favorite, then I have to go in and add each waypoint to get it to give me the route I have in mind, but hopefully there is a better way...
bigtallguy is offline   Reply With Quote
Old 04-28-2010, 04:24 AM   #819
Skurj
Oddometer: 52
Not possible on any of the 200 series...
Skurj is offline   Reply With Quote
Old 04-28-2010, 04:25 AM   #820
Skurj
Oddometer: 52
I believe the maps are tied to the unit, 2 different units, you need to buy 2 maps...
Old 04-28-2010, 05:01 AM   #821
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,847
Depends on the map - I don't have any US Topos but my Canada Topo V4 allows me to add maps to any or all of my gps units.
Old 04-28-2010, 09:14 AM   #822
Off the grid
Chaotic Good
Oddometer: 11,375
Thanks fellas! Just put my RAM 3" mount on my KTM with the beefy cradle so I can swap between bikes now.
It says the battery life is 8hrs....that's a farce but is it enough to last 4-6? I want to avoid hard-wiring it to the KTM if I have a choice.
Old 04-28-2010, 09:23 AM   #823
RoughRider
elderly windbreaker
RoughRider's Avatar
Oddometer: 122
It'll never make it. I couldn't get more than 2.5 hours out of mine when using it out in the woods. Finally put on a $5 12v power plug kit from Wallyworld and that solved the problem.
RoughRider is offline   Reply With Quote
Old 04-28-2010, 09:26 AM   #824
Ogre_fl
Ogre_fl's Avatar
Oddometer: 2,325
Assuming we are talking about the 500/550, 8 hrs is not a farce.
I have run on battery ALL day.
I do turn the screen down to 20% most of the time and turn the unit off when taking a break.
Still have not needed to hard wire my KTM yet
The Nuvi lasts longer than I do
Ogre_fl screwed with this post 04-28-2010 at 09:33 AM
Old 04-28-2010, 09:48 AM   #825
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,847
Isn't that taking this whole "Off the Grid" thing a bit too far?
Times are GMT -7.   It's 08:24 PM.
