Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 08-26-2012, 10:22 AM   #1126
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 446
nuvi 550 routing question
Hi,
Once I missed a viapoint (I took a detour) and then turned around to head back to the next viapoint on the route. I didn't go over the original viapoint I missed, so the nuvi got fixated on that one missed viapoint.
It didnt know that I was back on the route. Kind of weird? It kept recalculating to get me back to the missed viapoint. Let it go!! :)
Has anyone seen this and how do I prevent it? I think the obvious thing is to stop the route and restart it, but still.....
thorinoakenshield is offline   Reply With Quote
Old 12-02-2012, 06:21 PM   #1127
brecchi
Oddometer: 370
Garmin Nuvi 255wt questions
Hey guys. Have a Nuvi 255wt, my car unit Im using on a dirt bike I rented down here in Nicaragua. I plan to ride a new dirt road going to the Carribean and would like to record the track into the GPS if possible. Anyone know if this model is capable?
Also, I never quite learned how to imput latitude/longitude on this model, if anyone can help with that.
RR to follow....
brecchi is offline   Reply With Quote
Old 12-03-2012, 12:58 PM   #1128
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,256
Originally Posted by brecchi View Post
Hey guys. Have a Nuvi 255wt, my car unit Im using on a dirt bike I rented down here in Nicaragua. I plan to ride a new dirt road going to the Carribean and would like to record the track into the GPS if possible. Anyone know if this model is capable?Also, I never quite learned how to imput latitude/longitude on this model, if anyone can help with that. .
if it's like all the other nuvis you can't import a track that will show on the screen. the quick way to find out is send a track from mapsource to the nuvi then see if it shows up. i did see a thread somewhere where a guy suggested converting the track to a route which would work...
if you have the same menu as the typical nuvi, entering coordinates is just clicking on "where to" then "coordinates".
talking of nuvis, gotta say i've been impressed with the old 1450t that's shown routes and recorded the tracklog for 7000 miles of adventure and dirt rides and even some mx tracks. the only recent issue (i mentioned months back) was the power supply has been intermittent over rough terrain as the slot in the back of the garmin has got a bit loose.
but fixed it by just using a rubberband to hold the power cord firmly against the back of the garmin. it's worked fine, and probably should have been doing that from the start instead of letting the cord flap around in the gnarly stuff.
free enduro training vids for gumbies here
B1 screwed with this post 12-03-2012 at 01:18 PM
B1 is offline   Reply With Quote
Old 12-03-2012, 01:31 PM   #1129
brecchi
Oddometer: 370
Cool - the coordinates sound simple enough, thanks for that.
I've used a GPS for a few years now, but only using the most basic functions, so I am relly kind of a noob. I may not be asking my first question properly - Basically, this is a new dirt road I will be riding and Im sure it is not really on any online map yet. I was wondering if it was possible to record the track into the Nuvi in real time, maybe by using a series of coordinates every couple of miles or something like that?
Thanks for any advice.
Old 12-03-2012, 02:06 PM   #1130
B1
B1's Avatar
Oddometer: 3,256
record it in real time? if you mean just ride out there and try it, here is how to get your gps recording a tracklog you can download to your computer later (assuming your menu is the same as the 1490t and you have the same functionality).
start your nuvi
click on 'view map'
click on 'speed' in the lower right corner (brings up the speedo which is handy if not following route)
press on the speedo dial for a few seconds
click on 'diagnostic logging'
click on 'start recording'
click on 'gpx'
click on 'size' and bump the memory for the track log up to maximum size
then backtrack to the normal menu.
if you want your tracklog to be visible as a light blue line on the garmin while you are riding:
click on 'tools' then 'settings' then 'map' then 'trip log' and choose show.
when you want to transfer the recorded tracklog to your computer, get mapsource running on your pc and connect the gps. when transferring data to your pc, just select tracklog then save the resulting file to your pc.
if you plan on doing a lot of adventure and dirt riding, then getting the garmin topo maps for your region will help a lot as they usually show major dirt roads and hopefully some of the older tracks too.
even if you just stick with the road maps for the time being, a handy way to explore new areas is using bike route toaster.
if you choose the hybrid view, you can use existing road maps as well as satellite images to plot out routes in very remote areas by just following visible tracks (at least until the tree cover gets too thick). often the detail is good enough to spot the shadow of fences and gates so can see possible points where you might hit a locked gate etc. probably not great resolution in nicaragua though.
plan your route in bike route toaster then save it as a gpx file to your pc. open it in mapsource and transfer it to your garmin. then go 'tools', 'my data' and 'import routes'.
select the routes you want to use then go 'import'.
backtrack then go 'tools' and 'routes' and choose the route you want. scroll down to 'recalculate' and choose 'offroad' then press 'okay' and 'save'. press 'go' and off you go.... this process ensures your garmin will just follow the route you planned and not try to auto calculate using its road maps.
steep learning curve, but this is all you need to explore your heart out, have fun.
the bad news? it looks like the 255 won't allow you load routes though. if you find your model on the garmin site and go to the specs page, under "routes" it shows zero, whereas the nuvi models that will load preplanned routes usually show "10" there, like the 1450t and the 1490t i've been using.
you can store up to a thousand waypoints but only as a single point. bummer if that's the case.
Old 12-03-2012, 06:41 PM   #1131
brecchi
Oddometer: 370
Wow B1...that is exactly the kind of tutorial I needed, thanks for that.
So my main objective as far as the GPS is to do what you first wrote, which is to record the track as I am riding along, as per your instructions.
Although it seems as though the 255 wont accept the bike route program, will I still be able to record the track into the GPS as Im riding, and then download it into Mapsource for others to see? Or is that what is considered loading a route ( meaning no-can-do on this model)?
Old 12-03-2012, 11:48 PM   #1132
B1
B1's Avatar
Oddometer: 3,256
i don't know as i've never used a 255 before, i'd suggest just following all the steps above and then see if it works. recording a tracklog (and downloading it via mapsource) is a completely different thing to creating a route on your pc with mapsource (or bike toaster) and uploading it to your gps. the tracklog just shows as a thin light blue line where you have been when the gps is turned on. the actual route (which your model doesn't seem to be allowed to upload) shows up as a thick pink line.
if you don't have mapsource already, go here for the cheapest version.
Old 12-04-2012, 04:34 PM   #1133
brecchi
Oddometer: 370
Ok B1 - Ill follow the above steps as best as I can and let you know how it works out.
Old 12-06-2012, 07:50 AM   #1134
AZ TOM
Oddometer: 3,864
Some well placed duct tape made mine solid no matter how rugged the terrain.
AZ TOM is offline   Reply With Quote
Old 12-06-2012, 11:29 AM   #1135
victor441
victor441's Avatar
Oddometer: 896
free dashboard disc from Garmin....
one can be ordered from Garmin if your Nuvi is registered, works well in my car as it positions the unit better plus windshield mounts are illegal where I live...
https://my.garmin.com/mygarmin/marketing/dashboardDisc.htm
victor441 is offline   Reply With Quote
Old 04-25-2013, 10:43 PM   #1136
dirtspaz
dirtspaz's Avatar
Oddometer: 27
Pissed custom route GPX data into a Garmin
I have a GarminNuvi 2595 and I can't figure out how to get a custom route GPX data file into the 2595. I have tried to do it via Tyre, tried it by directly placing the GPX file into the GPX folder, and then tried opening the GPX file into Gramins Base Camp software and then uploading it into the 2595. I don't think any of these have worked. I can't find the custom route in the 2595. where are these files located in the 2595 and how do you find them when using the 2595? I assumed they would be in the "trip planning" area but none of them show up. it shouldn't be this difficult.
thanks for the help
dirtspaz is offline   Reply With Quote
Old 04-26-2013, 02:24 AM   #1137
advNZer?
advNZer?'s Avatar
Oddometer: 2,829
i think there are some older nuvis that will do it,but i have found exactly the same problem with a recently aquired 2350.I though i would be allright as the garmin specs say 100 routes.The only upside i have found is you can send as may way points from google maps straight to the gps,(via little garmin plug in)it shows up in favourites.Maybe that would be a way to then plot a route on the gps itself with the trip planner.I beleive the Nuvi 1490 does allow routes to be uploaded.You can get the tracks ofthe 2350(where you have been.They are numbered by date and time)
aka BMWST?
advNZer? is offline   Reply With Quote
Old 04-26-2013, 05:00 AM   #1138
advNZer?
advNZer?'s Avatar
Oddometer: 2,829
Has anyone tried sending a route to the sd card instead of the "internal memory'?I havent got a suitable card here to try.
aka BMWST?
Old 04-26-2013, 03:46 PM   #1139
advNZer?
advNZer?'s Avatar
Oddometer: 2,829
i am searchin for info on our nuvi issues and i came across this article!
scroll down a wee bit there is an artivcel about track logs and a nuvi 255w
aka BMWST?
advNZer? screwed with this post 04-26-2013 at 04:00 PM
Old 04-27-2013, 02:03 PM   #1140
MadM
Dreamer
MadM's Avatar
Oddometer: 244
Nuvi 2455 info
Hey!
Does anyone have experiences with Garmin Nuvi 2455 GPS? I have found one on sale I am thinking of getting it. We already have a 2460LT at home but at the high cost, I don't want to use it on my motorcycle. Any other possibly cheap options I should look at? ride both on and off road (mostly fire roads) and would like to be able to make a route in Google earth and transfer it to GPS. I also looked at Nuvi 40, but I found out it doesn't support pre-made routs.
'08 Honda XL125V Varadero
'05 Kawasaki KLE 500
'03 KTM LC4 640 Enduro
My Blog
MadM is online now   Reply With Quote
Times are GMT -7.   It's 11:38 AM.
