11-20-2007, 06:45 AM
#226 |
Broken Hearted
Oddometer: 9,543
tHErEV -
your bike is awesome. Soooo awesome. How much is stock and how much is diy? Kawidad - I've got one somewhere. I'm not totally sure I want to give it up, I like the idea of being able to put it back to stock and selling the acerbis seperate when I decide to part ways with it. I'll think on it and let you know. |
11-20-2007, 07:17 AM
#227 | |
Teach me this knowledge
Oddometer: 541
and is that thing a dakar variety? Looks sweet man! -S |
11-20-2007, 10:58 AM
#228 | |
tEAM iDIOT
Oddometer: 5,509
I had a KLX sitting around and I just thought I'd see if I could make it fit, and surprisingly it did. The KLX had a good front wheel and it already had a vapor digital speedo installed. The bike is a fairly standard DR650rs the only modifications I made is I built a new screen for it and put CBR250 head lights in it. I'll get around to finishing the nose onday..... I hope. But for comparison porpoises this is what it looked like when I got it.
tEAM iDIOT... tHE oRIGINAL. Hard Core Dirt Touring. |
11-20-2007, 11:15 AM
#229 |
Broken Hearted
Oddometer: 9,543
Very nice!
11-20-2007, 03:35 PM
#230 | |
Oddometer: 3,804
"Deeply flawed people make deeply flawed decisions." |
11-22-2007, 10:43 AM
#231 |
flush em out
Oddometer: 22
fuel cock rebuild
So it seems like I may need to rebuild the fuel cock on my 92 DR because of leakage. Are there kits to do this sort of thing?
OR any suggestions for an aftermarket fuelcock? |
11-22-2007, 11:39 PM
#232 |
Oddometer: 3,804
I don't believe there are any kits, but I've heard of people taking them apart and replacing the seals and o-rings with good results.
11-23-2007, 01:15 PM
#233 | |
Oddometer: 541
)A new petcock did it for me on that one, but a replacement rubber disc would have been just as easy. Disassemble it if you can, and see what rubber parts you can replace. |
11-25-2007, 12:12 PM
#234 |
I don't need a title
Oddometer: 365
Steve, choke/ bashplate
Hey Steve, sorry I didnt post earlier, but for some reason AdvRider isn't letting me know about replies to the thread...
Anyway, I believee th 90-91 came with that bashplate. The 92-95 have a similar one that was smaller and thinned but the same design. I ad one of each when I was selling mine and now have the White Bros. one. It should fit yours as the frames are the same I believe. Nice smooth aluminum. Runs for $75.00 or so I think. Also, the choke on carb was stock on 90-91 I believe. I bought the DR350 choke from Jesse and it is so short. I then loked at online parts fische (try Ron Ayers.com) and saw that the 90-91 had a choke on carb set-up that looked longer so I dropped $25.00 at Hollink and it is the exact same as the DR350 but with a longer stem so it clears the cables better. If you have no prob getting at the choke plunger knob then it is stock. ALso, the clutch side handlebar controls would have an area next to the lever mount that would be "empty plastic" from where the choke lever wouldve gone. Shoulda bought mine! LOL Just kidding, Im actually really glad I kept it and put more miles on it this year than my ZRX1100. Hope that that helps, Jason |
11-25-2007, 07:04 PM
#235 |
Sober
Oddometer: 4,808
Soft Bags...
Can someone recommend a good set of frame supported soft bags??
Mine is a '95 and I'm not finding anything, maybe my search-fu is weak. I have some ideas for making some myself, might be a good winter project if nothing else pops up.
SOBER I was pwned by a liberal, ask me how. Or just click:http://www.advrider.com/forums/showthread.php?t=838351 |
11-26-2007, 06:14 AM
#236 | |
Oddometer: 541
Then you wouldn't have had that great experience making a video and be famous the world over for starting your DR650 on a camera phone! ![]() And besides, as soon as I get the brakes in from CycleStop then I'll be street legal and we can go ridin'!
11-26-2007, 12:48 PM
#237 |
flush em out
Oddometer: 22
Will Cycra ProBend triple clamp front mount handguards fit on my 1992 DR650? I'm not sure how that triple clamp mount fits on. Thanks
Swag |
11-28-2007, 08:17 AM
#238 | |
kinda slow
Oddometer: 20,351
Positive update!!
I changed the oil today after about 400 miles and saw nothing abnormal I have, however, changed the old drain plug out for a magnetic one. found it here ![]() http://www.kevinscycleracing.com/performance.htm My local dealer said he couldn't get one for the "older" model ![]() At 1st I wasn't sure if they had sent the right one as it used a 14mm socket and my stock plug uses a 21mm....but the threads and all matched. ![]() p.s. the main respondant in my "garage" thread, ValveCrusher, rode my bike a few weeks ago and thinks He's pretty sure it's a bent shift fork rubbing the gear stack.
knybanjo screwed with this post 11-28-2007 at 08:23 AM |
11-28-2007, 09:29 AM
#239 | |
Oddometer: 541
![]() And ewwww, good luck with that bent shifter fork. Hey - when you got a new oil filter, did it come with new O-rings too? Mine didn't...
11-28-2007, 09:06 PM
#240 | |
kinda slow
Oddometer: 20,351
![]() (I talked to the guy on the phone when I ordered) Thanks....try to not step on the gear shift while under power. ![]() (awesome set of dirt ess turns...foot out and sliding..left...right..repeat!!) No....filters do not come with new O-rings. ![]() (they are re-usable and do last a long time though)
