Old 09-28-2010, 11:54 PM   #16
twistedkeys
Utahrd
twistedkeys's Avatar
Oddometer: 161
Haha! nice job! love to see that thing come to life! if you have any questions on where things go i would be happy to help! by the way, would you by any chance not be needing those tires? i could really use them for the ice i could probably pay $5-$10 for shipping
Originally Posted by TXspeedDemon
sorry its been a while since i updated
yes its a honda cb 125 gas tank.
also heres some updates.
i cleaned up the wiring harness and added clip ons and new headlight brackets.
this is my little sister on it as it sits now.
i plan on making a carbon fiber tail for it.
also i do wanna find a new pipe but i cant seem to find one. anyone have a link?
future plans are as follows
chop the sub frame
carbon fiber tail
some good slick tires
and some performance mods.
i made a solo gauge out of the stock one by putting it into a drink bottle
VF700C - Cruisin'
SR250 - Lika bous
CR250
- Sold
KE100 - Sold
twistedkeys is offline   Reply With Quote
Old 09-29-2010, 12:02 AM   #17
TXspeedDemon OP
TXspeedDemon's Avatar
Oddometer: 53
i would say sure but man those are some NASTY old rubbers.
i rode that bike for about 2 years then it hit a shed for 5.
it had those tires on it for 6 years now.
also i dont know when im going to put new ones on because i need them on till i get this entire project done and thats in the soonest 2 months.
TXspeedDemon is offline   Reply With Quote
Old 09-29-2010, 11:48 AM   #18
twistedkeys
Utahrd
Oddometer: 161
I was thinkin' about putting spikes on there. and just using them in the winter time. Although if they're to cracked up (lol) then i don't know if they'd hold up to what i plan on doing with them.
VF700C - Cruisin'
SR250 - Lika bous
CR250
- Sold
KE100 - Sold
Old 09-29-2010, 01:45 PM   #19
TXspeedDemon OP
Oddometer: 53
if anyone wants a more detailed thread heres a link to my home forum,
well home forum as in i post on it the most. im not really a net junky s the 500 post i have on there is an acheivment XD
http://www.customfighters.com/forums...ad.php?t=36364
TXspeedDemon screwed with this post 09-29-2010 at 02:07 PM
Old 10-07-2010, 03:43 AM   #20
boingk
boingk's Avatar
Oddometer: 339
Lookin good there, TX. Thought you could use some of the 'Kawasaki Speed Tuning' advice I found in the back of an old service manual:
Fit a stage colder plug and machine 1mm off the cylinder head to bump compression up to 7.8 from the current 7.0. Reprofile the combustion chamber afterwards. After that, remove the disc valve and adjust the intaker timing 20 degrees either way to end up with intake starting at 140' BTDC and ending at 70' ATDC. Fit a Mikuni VM24 and adjust the ignition to fire at 2.58mm BTDC instead of the stock 1.96mm BTDC. Porting can be undertaken to open the expose the ports at 87' BTDC instead of the stock 95.5' BTDC. Premix oil into the fuel at 20:1.
Thats from my build here: Link
Cheers - boingk
'00 VTR1000F, '97 XR600R, '80 GS850G
boingk is offline   Reply With Quote
Old 05-12-2011, 03:11 AM   #21
TXspeedDemon OP
Oddometer: 53
well i dont post on here much so im sure no one here knows who i am
but i've had alot on my plate for the past several months and only recently got back around to this little toy
so here's an update on the work done now.
\stripped it down again. this time everything but the engine and suspension and now that the frame is done being modified that will be done soon.
in this picture i had just finished chopping down the kick stand 2 inches. yes the drop in the forks really did make that a have to mod instead of a want to
you may be able to tell in that picture but i chopped the subframe up.
i rewelded the curve in because it matches the tail i made
redneck pipe bender to get the curve right
home made fiverglass tail tested to see how well it matched the new chopped subframe. about 5 inches cut out by the way.
chopped up the tank. soon to weld back in some plate to fill the cut.
reversing the cuts wont work on the little cb125 tank. its too small.
homemade oil tank for the 2 smoke oil
KafE logo.. get it KE100 KafE ok ok thats a lame pun but oh well
wieing harness got cut down.
before
after
the mess that got cut out
that's it for now.
i've only been working on it again for about 2 weeks. dont you hate it when life gets in the way of having fun
Old 05-12-2011, 05:14 AM   #22
twistedkeys
Utahrd
Oddometer: 161
Looking good! But I don't know why you didn't clean up the engine / bottom of the frame, it would look much cleaner with it repainted. Might as well do it while it's in pieces eh?
VF700C - Cruisin'
SR250 - Lika bous
CR250
- Sold
KE100 - Sold
Old 05-12-2011, 05:19 AM   #23
TXspeedDemon OP
Oddometer: 53
im not even close to done buddy
im repainting the engine polishing the side covers for contrast against the black engine and the skid plate is being removed for a cleaner look on the frame.
the frame is going to be painted metal flake green.
i only painted the welds so they wouldn't rust.
after i mock up everything its time to pull it apart 100% and get to painting and polishing.
and not a nut or bolt is going to be left alone. every single piece will either be polished or painted
TXspeedDemon screwed with this post 05-12-2011 at 05:25 AM
Old 05-12-2011, 05:51 AM   #24
twistedkeys
Utahrd
Oddometer: 161
OH YES!
VF700C - Cruisin'
SR250 - Lika bous
CR250
- Sold
KE100 - Sold
Old 05-12-2011, 10:48 AM   #25
supershaft
because I can
Oddometer: 9,116
KE100!?! The bike that I recommend people learn how to wrench on! They made them by the millions! It's no great loss ruining one IF that is what happens. It's a shame so many people are instead learning on rare and expensive stuff.
Old 05-12-2011, 12:09 PM   #26
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,330
I taught my stupid sister to ride on a KE100. She did incredibly well, never thought that would happen! Weirdly enough, she was riding like she had been riding for a year at the end of a half day! Also weird is she never rode another motorcycle again to this day and that was in 1975.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X screwed with this post 05-12-2011 at 12:40 PM
Sniper X is offline   Reply With Quote
Old 05-12-2011, 12:13 PM   #27
twistedkeys
Utahrd
Oddometer: 161
Originally Posted by Sniper X View Post
I taught my stupid sister to ride on a KE100. She did incredibly well, never thought at would happen! Weirdly enough, she was riding like she had been riding for a year at the end of a half day! Also weird is she never rode another motorcycle again to this day and that was in 1975.
girls..
VF700C - Cruisin'
SR250 - Lika bous
CR250
- Sold
KE100 - Sold
Old 05-12-2011, 03:51 PM   #28
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,475
girls..
Would you like your ass kicked now............or later?
Lookin' good, TX! keep snapping pics for us.
Old 05-12-2011, 06:28 PM   #29
TXspeedDemon OP
Oddometer: 53
ok i think this deserves a little explanation.
this isn't my only bike
i also have a 1978 cb400t
2007 hysoung gv650
and i've owned a gpz750 turbo and a cbr600 f4i
what it is is my very first bike.
i got that bike for my 13th birthday.
i rode it untill i was 15 and got the honda.
well i looked at it one day and decided i wanted to ride it again. but i wanted it to be cooler than it was. so i got to cutting chopping and modding.
the reason why my build looks kinda rookie is i work at random i have no issues taking too long to do a project or doing it in a weird order because ALL i care about is the final product.
however i would recommend a ke100 to anyone thats learning to ride OR build. great little bikes
they ride at 50 all day and are just fun.
the only issue with them is the battery. that little 6v system gets annoying and the battery is unreliable.
you can fix that issue with a capacitor but if you hit the brakes,turn signals, and high beams at the same time then the blinkers stop blinking
i got around this by just choppin the turn signals off and calling it a day.
just some nerdy kid with a bunch of bikes
Old 05-12-2011, 08:26 PM   #30
twistedkeys
Utahrd
Oddometer: 161
LOL sorry didn't know there'd be any girls looking at KE100 cafe restoration... you have to be pretty in to motorcycles to love this stuff!
VF700C - Cruisin'
SR250 - Lika bous
CR250
- Sold
KE100 - Sold
Times are GMT -7.   It's 06:10 PM.
