Old 03-30-2012, 11:29 PM   #46
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
Originally Posted by TXspeedDemon View Post
haha the point has muddled.
it has transformed from the final idea being a cafe to the final idea being almost a brat style.
the front end was just a good deal i stumbled upon for cheap and i thought it would add a lot of personality
at this point im just bolting on cool bits and bobs and seeing where it takes me.
at the time i cut off all the tabs i was still aiming at hardcore cafe racer.
so how is this bike going to turn out now?
i guess well just have to see. i may still go cafe style but it may end up something all together different just kind of winging it but thats how all my best projects get done.
Aaaah. A kind of suck it and see approach eh. Still an interesting build.
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME.
Hunsta is offline   Reply With Quote
Old 04-01-2012, 02:50 PM   #47
TXspeedDemon OP
TXspeedDemon's Avatar
Oddometer: 53
well actually got around to test fitting the sachs forks.
so close its scary
all its gonna take is milling out the bearing race a little
and shaving the perimeter of this to apply pressure to said bearing race.
ill probably have to cut some knotches and make a special tool to tighten it but no biggie.
then just a small spacer to cover up the 1-2 mm worth of thread that will be exposed.
the bottom bearing race and sachs steering stem all fit perfect.
just some nerdy kid with a bunch of bikes
TXspeedDemon is offline   Reply With Quote
Old 04-02-2012, 07:46 PM   #48
TXspeedDemon OP
Oddometer: 53
5 3/4 headlight
http://www.ebay.com/itm/BLACK-BATES-...f030a6&vxp=mtr
or 4.5 ?
http://www.ebay.com/itm/EMGO-4-5-UNI...b76827&vxp=mtr
Old 04-03-2012, 01:37 AM   #49
Hunsta
Have guns will hunt
Hunsta's Avatar
Oddometer: 5,458
I`d go the EMGO light. looks better. Not sure if its the same brand but I have EMGO pipes on my R65 Cafe. Good products.
Old 04-03-2012, 08:35 PM   #50
TXspeedDemon OP
Oddometer: 53
ok so i just decided on a paint job.
i go to a lot of conventions and everyone has always been awesome about autographs and just generally cool people.
my wallet was actually coated in autogrphs from cons.
well thats going to be my paint job. im priming it white and taking a sharpie with me to my next few conventions.
check this out
adam west
patrick stwerart
STAN THE MAN LEE
http://www.scifiexpo.com/DCC/dcc.html
Old 04-07-2012, 03:59 PM   #51
TXspeedDemon OP
Oddometer: 53
new tank came in today.
i dont know if i mentioned this but this is officially no longer a cafe. its a weird custom brat build now where im throwing together bits that look cool.
Old 04-09-2012, 03:21 PM   #52
TXspeedDemon OP
Oddometer: 53
got in some new shocks today.
ill be ordering another set buy i wanted to make sure everything cleared and lined up before i spent the money for 2 sets.
yeah they are just shitty little chinese shocks but on a bike that weighs all of 130lbs wet i figured it would be fine.
Old 04-10-2012, 11:04 PM   #53
assquatch20
Hoss Cat
assquatch20's Avatar
Oddometer: 1,107
That is looking just terribly impressive and weird.
Some things shouldn't be left like you found them.
assquatch20 is offline   Reply With Quote
Old 04-11-2012, 07:45 AM   #54
gloud
Oddometer: 158
call it the pushmi-pullyu LOL I keep watching the thread, you arn't afraid to think outside the box, and that can be good or bad lol..
gloud is offline   Reply With Quote
Old 04-11-2012, 09:27 AM   #55
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,082
I love it! Go man go!
FloridaSteve is offline   Reply With Quote
Old 04-15-2012, 06:13 AM   #56
Euromad
Oddometer: 307
Very entertaining. I like the thought process or lack thereof
It looks cool!
Euromad is offline   Reply With Quote
Old 04-15-2012, 10:40 PM   #57
TXspeedDemon OP
Oddometer: 53
i sat down and tried to figure out an end look with the parts i have now.
the drawing isn't amazing but it gives you an idea.
also me and a friend where just chatting and he brought up a good point.
that swing arm stand out against the everything else being so tubular.
so i ordered an early ke100 swing arm and am under-bracing it to match the beefy tube everything look the bike is developing.
plus they run like $20 delivered so why the hell not right?
going for a look like this.
Old 04-16-2012, 01:51 PM   #58
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,574
I can't wait to see how this thing turns out.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 04-17-2012, 06:27 PM   #59
TXspeedDemon OP
Oddometer: 53
swing arm came in today.
so how hard will it be to swap it in?
well that was easy!
bracing on the swing arm made of pvc and duct tape.....im sure it will hold
ok so its just a super quick and dirty mock up to see how it will look. ill be designing the final one tonight.
maybe even an upper and a lower brace.
EDIT: also yes that was a direct bolt on. its about an inch shorter than stock but everything still lines up.
Old 04-18-2012, 03:38 AM   #60
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,574
That might actually work better. If the shock mounts on the swingarm are closer to the pivot vs the stock ones it might raise the rear end a little, and your front end seemed to be a little taller then stock, so it might even out.
Times are GMT -7.   It's 08:31 PM.
