09-03-2010, 02:45 PM
#1 |
GPoET&P
Oddometer: 3,760
Ethanol-proofing a gas tank
I recently bought a Scorpa trials bike. It's a great bike but it was made in 2001, back before most gas had ethanol added to it. The tank was made of some sort of plastic or fiberglass that was dissolved by the ethanol and would gum up the carburetor. I was warned by the PO about this, and was told that if I ran regular gas I would need to drain the tank every time I used it. Annoying, but tolerable. After riding it a while, I discovered that the problem was worse than that- the carb would gum up before I could even finish a tank of gas.
My options were: Buy race gas. At $65 for 5 gallons, not going to happen. Buy non-ethanol gas. I don't want to drive around to marinas to find gas, and the last place I went to that sold non-eth was 150 miles away and wanted an extra $1 per gallon. No thanks. Fix the tank. This is what I did. After a bit of on-line research, I ordered this kit from Caswell Plating. http://www.caswellplating.com/aids/epoxygas.htm It was about $50 with shipping. A bit spendy for a tub of glue, but it's about the difference in price between 5 gallons of race gas and regular gas, or the cost of two trips to a marina. In other words, it's a bargain. I had no proof that the epoxy would stick to the plastic of the tank but I figured that since paint stuck to the outside it would work. Here's the start: ![]() I also used electrical tape and plastic food wrap. I did not use the scale. I would not recommend using the foam brushes- use a paint stirrer instead. The instructions are good. Read them. Repeatedly. ![]() First get the old gas out using acetone, I used the whole pint. It's a really good idea to wear gloves. Latex is impervious to acetone, not all rubber gloves are. ![]() Then wash the tank out with detergent and hot water and let it dry. ![]() Next wrap the tank in plastic and electrical tape to keep the epoxy off the outside. ![]() ![]() The idea is that you're going to fill the tank with epoxy, seal up the openings, rotate the tank to get the epoxy on all the surfaces, then open the top and drain out the excess. After the epoxy starts to cure it'll get rubbery. Uncover the petcock hole and cut the excess epoxy away with a knife so that the petcock will fit in. If you fold some of the tape back on itself to make a tab, it's easier to remove. ![]() I don't have a picture of how I covered the top of the tank, but it's pretty easy. Just use a rubber band and some plastic. I didn't have a rubber band, so I cut the wrist of one of the latex gloves. Mix the epoxy. If you're doing several tanks at once or one big one, just dump it all in. I mixed half of each container. If you do mix half, it's important to get the ratio correct, or the epoxy won't cure properly. Unfortunately, I have no idea how close the ratio has to be. I was a bit busy to take pictures of the next part. After mixing the epoxy, pour it in the tank, cover the top, and shake it around, rotating the tank in every direction you can for a few minutes. Then take the cover off the filler cap and set the tank so the epoxy will drain out. ![]() Hot tip: figure out how you're going to set the tank to drain before you start messing around with the epoxy, not after. After about an hour, remove the tape that's over the petcock hole and trim up the excess epoxy. Let the epoxy cure for a few days. After it's done, clean up the filler neck. This is how it looked before cleaning it up. ![]() Finally, assemble and ride! ![]() I did this about a month ago, and it's worked really well. I have used regular E10 gas, never drained the tank, and have had no carb troubles at all. |
09-03-2010, 03:09 PM
#2 |
Wandering between rooms
Oddometer: 1,261
I'm very intrigued by this. I was talking to someone about the Safari/Aqualine tanks, and the fact that for the 950/990, they tend to 'shapeshift' which makes putting them back on challenging. He mentioned that the CA ethanol gas may contribute to that. If this product works and solves the deformation issue, there may be a set of those tanks in my future!!
G
I just twist and my eyes glaze over, "uh....errr huh huh, weeeeoooooh---doo dat agin, doo dat agin..." -morriswf I like my women like I like my instant oatmeal- quick, easy, and covered in facts about dinosaurs. |
09-03-2010, 03:22 PM
#3 | |
GPoET&P
Oddometer: 3,760
Since Aqualine is still in business (unlike Scorpa) I'd ask them what their tanks are made out of, then ask Caswell if their epoxy will stick to it. The Aqualine tanks I've seen seemed more like HDPE, which nearly nothing sticks to. |
09-29-2010, 07:31 PM
#4 |
Professional Idiot
Oddometer: 927
Please keep us updated over time. I was/am/maybe considering this, but got scared by a couple of articles I read where the epoxy didn't hold up in the long run. It'd be nice to be able to buy fuel at the corner station for reasonable money.
09-30-2010, 09:47 AM
#5 |
not waiting anymore
Oddometer: 1,653
Could this work with Sherco tanks?
I've noticed that older Sherco tanks (think '02, '03) seem to develop crazing around the petcock area that eventually weeps fuel. I wonder is ethanol blends cause this? And I wonder if this epoxy product will work on whatever plastic the Sherco tanks are made from?
09-30-2010, 11:43 AM
#6 |
ca vaut le detour !!
Oddometer: 573
hi Luke,
great write up i have a scorpa 2006. not sure what the tank is made of... could you comment on the symptoms you had before doing the mod. I wonder if that is the reason mine doesn't want to start or when it does run, going downhill seem to kill the engine( it just dies...)?? I'm in Portland thanks
04 GS 1150 93 Africa twin RD07 |
10-01-2010, 12:47 AM
#7 | |||
GPoET&P
Oddometer: 3,760
Will do. I put the liner in a couple of months ago, and it actually sat all September with gas in it; I only ran the float bowl dry before putting it away. It ran fine today. So I consider it a great success- for now. Do you remember where the articles were or what their problems were? I'd like to know what to keep an eye on. Quote:
It isn't necessarily this tank problem causing it. Any other gunk in the carb will cause the same problem. When I opened the carb up to clean it out there was a bunch of white powdery residue in the throat and the float bowl, and the pilot had clear goo in it. I don't know if the '06 has the same tank as the '01, but the '01 tank really felt bad. I could feel a gooyness when I rubbed my fingernail on the inside of the tank. Not like any other kind gas tank or can at all. I'm in Beaverton; I'd be up for taking a look at your bike (I also want to see how the gas tank attaches on your bike. Mine's missing a few bolts) |
10-01-2010, 08:03 AM
#8 |
Oddometer: 573
thanks for the info Luke,
Im in west linn, I'll PM you my cell number d'be happy to meet you
10-01-2010, 08:14 AM
#9 |
black cloud wandering
Oddometer: 717
i used caswell on my tank and its held up great. im pretty sure you could make a paper tank and line it with the stuff and it would hold gas just fine.
tip- try to do this in a warm enviroment, i did it in a cold shop and it kept the stuff from getting liquid enough, i used some soft heat on the tank to get it flowing again. tip- next time i do this im going to use some modeling clay or something around the filler hole to get the edge the way i want it- it took a bit of work to get the gas cap working right.
motorcycles are dangerous. |
10-22-2010, 11:34 AM
#10 | |
Professional Idiot
Oddometer: 927
http://www.egyptian.net/~raymacke/Cbnskif17.htm motojunky screwed with this post 10-22-2010 at 11:49 AM |
10-22-2010, 06:08 PM
#11 | |
Motor Sickle Addict
Oddometer: 1,079
I tried it last time i used Caswell and it worked, stuff flows much better. |
10-25-2010, 10:16 AM
#12 |
Oddometer: 576
this may help also, depending on what state youre in. easier than finding a marina or buying epoxies for your tank...
http://pure-gas.org/
avatar pic: tathum gap, trail of tears, nc my goal is to see how many gallons of dead dinosaurs i can send through my bike. 2008 Kawasaki Concours 14 Concours Owners Group #8904 2008 Yamaha FZ6-Black Iron Butt Association #30337 |
10-26-2010, 05:41 PM
#13 |
Cunning Linguist
Oddometer: 112
I run a marina / boatyard / non-ethanol gas dock, so my two cents:
Ethanol has created big problems in the marine environment too. First, it was with the old polyester-based fiberglass fuel tanks. The ethanol (an alcohol) would degrade the poly resin and cause just the same problem you experienced... an nasty, gummy substance in the carbs. Second, it binds to water more readily than fuel, and a small amount of water in the tank (~2%) would cause the ethanol to separate out of the gas. Again, a nasty gummy substance. I sell more non-ethanol to folks with five-gallon cans filling up their lawnmowers than I do to boats lately.
2006 Yamaha FJR1300A 2002 Yamaha TT-R 225 Sold: 2002 Yamaha RS Warrior 1700, 1998 Ducati ST2 944 Projects: 1988 Yamaha YX600, 1977 Honda CB750, 1974 Honda CL450, 1972 Honda CL360 |
10-27-2010, 08:11 AM
#14 | |
Professional Idiot
Oddometer: 927
I have a dragstrip and a VP dealer relatively close by, so getting fuel isn't really a problem, I'd just rather not pay $9/gal for it. That said, I don't go through all that much fuel on my Scorpa, so it's not really an issue. I ride it 99.9% of the time in my backyard, so I'm not burning fuel in the truck getting to a riding area either. |
10-28-2010, 12:19 PM
#15 | ||
GPoET&P
Oddometer: 3,760
Thanks for the info. It looks like he was using the same stuff, and it completely separated from the original gas tank. Now I know what to look for with this stuff. Quote:
