Thread Tools Search this Thread Rating: Thread Rating: 47 votes, 5.00 average. Display Modes
Old 05-26-2011, 02:13 PM   #211
Rubber Jonny
n0b
Oddometer: 37
I got my 62st mounted today, half DIY / half RAM mount.
Rubber Jonny is offline   Reply With Quote
Old 05-26-2011, 02:50 PM   #212
250senuf
250senuf's Avatar
Oddometer: 2,331
Seems as though the "quit" and "enter" buttons could be awkward to access.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 05-26-2011, 02:54 PM   #213
Rubber Jonny
n0b
Oddometer: 37
If you had thick lether road bike gloves on then they will be awkward, with off road gloves i doubt it will be a problem.
I really dont see this mount being that good for proper off road use. It would be loads better if the top section of the mount above where it says "GPSmap 62ST" on the gps was one solid peice rather than having a gap. Its too flexi in that area.
Old 05-26-2011, 09:57 PM   #214
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
They are. That's my main complaint with it.
Old 06-03-2011, 08:00 PM   #215
chromenomad
chromenomad's Avatar
Oddometer: 117
Does anybody know if it's possible to change the color of a track being followed on the 62st?
I've changed the color of the track in the Track Manager (to white), but if I access the track via the Find menu (to follow it with guidance) it turns pink again. I've gone through every setting I can find to change the pink to something else, but haven't found anything.
Note, I'm not trying to change the color of the track I'm leaving, but one that I'm following. Track, not route.
'09 R1200RT
'07 G650 Xmoto
chromenomad is offline   Reply With Quote
Old 06-03-2011, 08:18 PM   #216
Countdown
Oddometer: 5,455
I've changed the color of the track in the Track Manager (to white), but if I access the track via the Find menu (to follow it with guidance) it turns pink again. ?
Yes you can change the track color, you said you changed it white! Is that track turned on? The 62/78 turns off all tracks and changes their color when they are downloaded.
If they are "on" pan the map to where the track is and it should be there in White. (I use Dark Green.)
Sounds like you are using Trackback and the 62 treats a atrack you are navagating like a Route on 60/76 and highlights the track in Pink.
Just follow the track without navagation and you can see it in any color you want.
Jerry Counts
Countdown screwed with this post 06-03-2011 at 09:42 PM
Countdown is offline   Reply With Quote
Old 06-04-2011, 08:39 AM   #217
chromenomad
Oddometer: 117
Yeah, that has been my workaround so far. Was trying to find a way to change the color when navigating. Can that be done?
'09 R1200RT
'07 G650 Xmoto
Old 06-06-2011, 04:45 AM   #218
Rubber Jonny
n0b
Oddometer: 37
Why would you choose to follow it as trackback rather than just following it on the screen? I dont see any extra benefits?
Old 06-06-2011, 05:13 AM   #219
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
New Models in the 62 Range - Now Include Camera:
http://sites.garmin.com/gpsmap62/info/
"Document Your Journey - A 5 megapixel autofocus camera is now available on GPSMAP 62sc and 62stc. Photos are automatically geotagged so you can easily navigate back to your favorite spots in the future."
Old 06-06-2011, 11:08 AM   #220
Countdown
Oddometer: 5,455
There are some fgood eatures, but few people use them. With Trackback you can display data items on the map. I have mine set up to display "Miles to Dest" and "ETA at Dest". I have only used it a few times.
Jerry Counts
Old 06-06-2011, 02:15 PM   #221
Dazed Productions
Oddometer: 188
Has anyone tried out the new version 3.00 firmware? I am nervous of anything .00!
www.dazedproductions.co.uk
Dazed Productions is offline   Reply With Quote
Old 06-06-2011, 02:34 PM   #222
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
I have; works just fine.
Old 06-06-2011, 02:40 PM   #223
Dazed Productions
Oddometer: 188
OK ta, have yet to have a bad Garmin update but thought I would check first!
Old 06-06-2011, 02:54 PM   #224
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
I usually check the Groundspeak forums before applying updates. If there's anything unusual with it, there's sure to be whining on a topic about it.
Old 06-06-2011, 02:59 PM   #225
Dazed Productions
Oddometer: 188
Thanks for the tip. Loaded it now and all seems well. To me map navigation seems to be faster. Not sure if its just my imagination!?
HTML code is Off
Times are GMT -7.   It's 10:51 PM.
