05-19-2012, 04:40 AM
#271 |
Procrastinators
Oddometer: 5,804
GPSMAP 62/78 software version 4.03 Beta
as of May 18, 2012 Download (4.48 MB) View installation instructions and system requirements Notes: Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk. Change History Changes made from version 3.90 to 4.03: Added new route activity types Added support for Kenwood NMEA Waypoint Sentence Improved GPS response at low speeds Fixed issue with preserving routes imported from Basecamp (identical maps required) Fixed Spell Search in German Problems with this beta software may be reported to 62-78Beta@garmin.com Yeehaw! This feature is especially important: "Fixed issue with preserving routes imported from Basecamp (identical maps required)". Now when you painstakingly create routes in Basecamp, they aren't discarded and recalculated by the gps when you try to navigate them.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
05-24-2012, 03:18 AM
#272 |
Oddometer: 99
Guys,
Just bought a gpsmap 62, the base model. I use the free shonky maps for my other garmin gps(nuvi500), but how would i install the shonky map onto my gps62? It has no sd card, so im assuming you would copy/paste the shonky maps file folder to the garmins folder somewhere? so its in the internall memory? obviously the gps connected via usb. Reason i ask, i made a track on mapsource(tried basecamp as well) using full shonky map topo and sent the track file to my gps62, it transfered fine and when i went into the 62's file i found the track, clicked view it on map and all that showed up was the track but on the very base map that came with the unit, i dont see the shonky map details on the unit or when viewing the track i made. Please help |
05-24-2012, 05:34 AM
#273 | |
Procrastinators
Oddometer: 5,804
If you already have an img file of the Shonkymaps on another device, you could likely just copy that through the computer to the 62.
05-24-2012, 06:28 AM
#274 |
Oddometer: 99
Cheers for the help, i figured it out.
What i did was... in mapsource, i clicked the shonky map full topo to show on the map, i then used a map tool to highlight the whole of Australia then clicked send to device, click the tab "map" and press ok. It then sent about 300mb+ worth of maps to the gps unit. Checked it on my gps unit and its all there, now when i view my track i made i can see the shonky mapping as well, woohoo :) Getting the hang of it, love the tracking feature that my nuvi500 couldnt do, no cluttering of flags etc... cheers again. |
05-27-2012, 05:16 AM
#275 |
Procrastinators
Oddometer: 5,804
Another Beta release for the 62/78 Series as of May 25:
Changes made from version 3.90 to 4.10: Added new route activity types and improved BaseCamp compatibility. See TrailTech (http://garmin.blogs.com/softwareupda...th-garmin.html) for more information. Added support for Kenwood NMEA Waypoint Sentence Improved GPS response at low speeds Fixed Spell Search in German Problems with this software may be reported to 62-78Beta@garmin.com Go here to find it:
06-14-2012, 05:44 PM
#276 |
Procrastinators
Oddometer: 5,804
New Software for the 62/78 Series:
Changes from version 3.90 to version 4.20: Added new route activity types and improved BaseCamp compatibility. See TrailTech (http://garmin.blogs.com/softwareupda...th-garmin.html) for more information. Added ability to sort waypoints alphabetically < I don't think this works - at least I can't find it on my 62 which is now at version 4.20 Added support for Kenwood NMEA Waypoint Sentence Improved GPS response at low speeds Fixed issue with preserving routes imported from BaseCamp (identical maps required) Fixed issue where the map would sometimes not refresh when using the active route page Fixed issue with the Glide Ratio data field Fixed Spell Search in German Fixed possible issue with Where To? > Address searching Use Garmin's WebUpdater or http://Garmin.com/mydashboard to get the update.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 06-14-2012 at 05:53 PM |
06-20-2012, 04:01 AM
#277 |
Procrastinators
Oddometer: 5,804
* Added ability to sort waypoints alphabetically There's a new version out yesterday, 4.30, and this now allows you to sort waypoints Use WebUpdater to get the new software.
06-20-2012, 07:39 AM
#278 |
Oddometer: 335
GPSmap78s
Just received my 3rd one from Garmin. Hope this one last's more than a year.
06-20-2012, 07:40 AM
#279 |
Procrastinators
Oddometer: 5,804
What's happening to it? Most likely the usb connector, but wondering anyway...
06-22-2012, 03:07 PM
#280 | ||
Oddometer: 41
So this seems to mostly ease my concern I also had about the auto-recalc. I read this entire thread and I'm surprised no one addressed this issue even though it was asked a few times. I borrowed a friends 76 last week for a dual sport ride and I had some routes loaded to it. The auto-recalc drove me INSANE! If I spent the time making the route I don't want the GPS thinking for me. I found out after the ride that you can disable it. All I want is it to display a route with my location. If I make a wrong turn I don't want it to change the route for me automatically! So, on the 78 if you are navigating to say a single waypoint is there a way to turn off auto-recalc as well?? I really wish the Oregon had a 4-pin I'd probably get that over the 78. And I find it hard to justify the price of the Montana. Going to REI today to play with them all though but I am thinking of going with the base model 78 |
06-22-2012, 03:10 PM
#281 |
Oddometer: 41
And can you view street names from any zoom level? That was also annoying on the 76 you had to zoom way in for it to display road names.
In cities this makes total sense the screen would be nothing but words, but out in the country it would nice to be able to force it to display road names at any zoom level. I was constantly zooming in and out and in and out....
07-29-2012, 06:55 AM
#282 |
Oddometer: 1,089
Hey, just got my 78s from the discount cave at cabela's, $278 OTD after taxes.
I'm getting ready to order all of the goodies for it, want to make sure I'm ordering what I need and not wasting money here: Cigarette lighter power cord. Going to run bike power on Harley, FJR, and truck. Batteries on Ninja, ATV, and XRR. City Nav North America map Should I get the topo? 100K good enough? Using it for riding on the dual sport and the street bike, with occasional hiking and Kayaking use Ram mount for the GPS, with the short arm and enough bike mounts for everything I own. Harley, Ninja, FJR, ATV, and XRR. Also getting a Ram mount of some sort for my truck and the GF's car. Anything else? Thanks. |
07-29-2012, 11:47 AM
#283 | |
Oddometer: 3,992
Yes, get topo for PC but most people don't use in 62 even if loaded. Buy DVD not chip. All I have is 100K, but I also have 24,000 Nat Geo to export pictures.
Jerry Counts |
07-29-2012, 01:15 PM
#284 | |
Oddometer: 1,089
The ATV will be a pretty rare usage, but I could use the cigarette lighter if I need it. I've been meaning to put an outlet on it anyways for a few years now. XRR is AC only, no DC power on the bike. Maybe someday I'll switch it over, but as of now I don't see a need to. So the 100K topo is good enough, and most people don't use it anyways? Why is that? It seems useful to me, but I'm assuming that roads are labeled and you are still able to navigate them if desired. I could very well be wrong about that though. |
07-30-2012, 11:21 AM
#285 |
Oddometer: 1,203
I find navigating on the fly (from the unit) using 100k Topos almost impossible over any distance larger than a few miles.
It is okay if there are only a few roads in your immediate area. And you can pick one and follow it to some better known place. But it gets hopelessly confusing for me if I zoom out and start panning around and there are a lot of roads. In City Nav you can pick a point you want to get to and hit Enter and then navigate to it. But sometimes I have to do this in small chunks, because CN will compute some horrible routes over long distances. But I use 100k Topos a lot for planning trips on the computer. I have just gotten my hands on the 24k Topos. I was really surprised that many minor roads and trails that show up in 100k Topos do not show up in the 24k version. The opposite is also true, but that was what I expected. |
