09-14-2010, 05:54 PM
#16 | |
Procrastinators
Oddometer: 5,800
And there's no shortage of 60 and 76 topics, so can we keep this a 62/78 forum?
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
09-14-2010, 06:13 PM
#17 |
Procrastinators
Oddometer: 5,800
A Big Advantage to the New Generation of GPSr
As mentioned in the Oregon/Dakota/Colorado forums already, the new Garmins allow you to have mapsets on the units with different names, and they can be enabled or disabled as needed.
Just an example of when this might be useful - my 62 has 1.7 gig of storage built in so I can load maps to that, and the Micro SD as well. I have a Garmin MicroSD card with North America City Navigator on it, and there are times when I want to use this, but the card is only 2 gig and practically full with only the Garmin map, so I can't add anything substantial to that card. Now my normal MicroSD card is 8 gig and includes all of a number of other Garmin products like Topo Canada V4 and Metroguide Canada, as well as others. So what I've done is load a smaller set of my standard Topo V4 to the onboard memory of the 62, and named it Topo V4 (GPS - Small) and the large Topo map on the MicroSD card Topo V4 (SD - Full). This way I can leave both in the gps and choose the one I want based on what kind of search I'm doing, and if I need to switch the MicroSD card for the City Navigator, I still have some Topos to use as well. It may be that choosing to enable the smaller Topo mapset might make the unit search faster too. Maybe I'll do some tests on that later.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 09-15-2010 at 07:26 PM |
09-14-2010, 07:02 PM
#18 | |
AltRoute
Oddometer: 263
I might just get another 60csx if the price is right. |
09-15-2010, 01:32 AM
#19 |
Oddometer: 23
The 78 and 62 have identical menu and features. Only difference is form factor and the round powerplug is on 78 (ok.. and patch vs quad antenna).
I'm happy with my 78 for bike use. Others may prefer the 62 formfactor.. or price of an older model. |
09-15-2010, 07:07 AM
#20 | |
Kool Aid poisoner
Oddometer: 4,829
09-15-2010, 07:44 AM
#21 |
Oddometer: 23
Sorry. Helix vs patch.
Still think that the form factor vs powerplug will be the deciding factors for most people. ps. nice review of both here: http://gpsinformation.info/penrod/62S/62-78.html |
09-15-2010, 09:22 AM
#22 | |
Oddometer: 16,043
Yea; the lack of the 4-pin on the 62 disappoints me. Glad the 78's still have it.... serial/NMEA output makes connecting the GPS to a radio or datalogger miuch easier.
Spewer of the poignant non sequitur |
09-15-2010, 07:24 PM
#23 | |
Oddometer: 3,985
Jerry Counts |
09-16-2010, 07:00 AM
#24 | |
Kool Aid poisoner
Oddometer: 4,829
09-16-2010, 03:17 PM
#25 | |
Oddometer: 3,985
Jerry Counts |
09-17-2010, 04:13 AM
#26 |
Procrastinators
Oddometer: 5,800
Garmin Blog
More information on how maps work in the 62/78 units:
http://garmin.blogs.com/.m/softwareu...rovements.html Map Selection Improvements In the 62 and 78 series we have improved the way maps are enabled/disabled. Multiple supplemental map files can now be loaded to a device and to fully take advantage of that we have changed map selection to allow the greatest amount of configurability. This may result in some people needing to change how they configure and load maps. In the past, only a single map file with multiple map sets was possible and accommodating different combinations on the unit was more difficult. Now, desired map set combinations can be built into multiple files prior to loading on the device and each of those files can then be independently enabled/disabled on the device. This allows a maximum amount of configurability while simplifying the setup needed on the device. Our free utility, BaseCamp, supports multiple map files on a device. Build up any desired map sets that you would want to enable/disable independently and then transfer as before. Now, change the name of the new map file on the device from “gmapsupp.img” to a name that makes sense for the usage (e.g. “topo and roads for hiking trip.img”). This custom file name will show up in the map selection list on the device (Setup > Map > Map Information). If more configurability is desired on the device, split previously combined map sets into multiple map files (e.g. “topo for hiking trip.img” and “roads for hiking trip.img”). Utilizing profiles further enhances this option as multiple files can be enabled/disabled at the same time with a simple profile change.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 09-17-2010 at 04:25 AM Reason: Removed reference to Oregon/Dakota/Colorado Models - not sure this applies to them. |
09-17-2010, 06:33 AM
#27 | |
Kool Aid poisoner
Oddometer: 4,829
I understand the reasoning behind Garmin putting a patch antenna in the 78. After all, it is a marine unit and lets face it, when you're sitting out on a lake or ocean, there isn't much that's going to block reception. Now riding around on a motorcycle in dense wooded area's and along the side of mountains is a different story. Like I said, the more sensitive antenna is more important to me especially since I just use battery power. I'm betting I'm not the only one who feels this way. |
09-17-2010, 08:22 AM
#28 | |
AltRoute
Oddometer: 263
09-17-2010, 06:17 PM
#29 | |
Procrastinators
Oddometer: 5,800
09-18-2010, 05:45 PM
#30 | |
AltRoute
Oddometer: 263
