Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 5.00 average. Display Modes
Old 11-08-2010, 11:36 PM   #91
Countdown
Oddometer: 5,323
Got my hands on first 78 (assume 62 works the same) this weekend and have some quesitons:
1) We could not find menu to set response to loss of external power?
2) When I downloaded 10 tracks with all colors set and on/off status of each set, it changed the settings to some default preference. Another case of Garmin is much smarter than the user?
3) Could not find the "setup" for on/off recording Active Log on data card.
Number 2 is a show stopper for me and I hope my customers. Most of them are not capable of fixing all the tracks after I download them to their 78 after it screws them up.
Jerry Counts
Countdown screwed with this post 11-10-2010 at 09:24 PM
Countdown is offline   Reply With Quote
Old 11-11-2010, 02:21 PM   #92
bike_pilot
bike_pilot's Avatar
Oddometer: 132
78s on the way!
Well, my last gps was a Garmin Rino 530 that was sacraficed to the forest god's last weekend. I purchased it without reading up and found it useful although the 2-way radio was garbage and the joy stick was sucky with a gloved hand. I used it around 3 or 4 years and it started to feel the woe's of vibration (weather radio would switch on by itself & calcs were freaking out). Then my Husky decided I needed a new unit so it politley ejected it from its ram mount while I wasn't looking. I had my mind made up a couple years ago that I would follow Mark Sampson's 'never be without a 276c rule'. Of course now that Garmin discont'd those I haven't been able to find one and it turns out that my rewards card had more than enough points to pick up a 78s with a power cable. Looks like all my routing and tracking fits into what you all say it's capable of. It's leaps and bounds past the Rino anyway!
So now for the questions.
1. Will the Ram mount (RAM-HOL-GA40U) allow the power cable to be plugged in? If not I may have to go with Stovebolts clamshell (take that Husky).
2. I chose the cig lighter power cable since the power/data cable was not available to reward points members. Wondering if the data side of the later has any usability in the dualsport world?
06 Husqvarna TE250, '08 Yamaha WR250r
"I suppose that's the great romantic lure of the motorcycle; it's a key to adventure" - Steve McQueen
bike_pilot is offline   Reply With Quote
Old 11-11-2010, 04:16 PM   #93
TAPnTX
Oddometer: 399
Welcome to Garmin, How may we help you .....
Todd
02 Suzuki DR650SE
00 DRZ400e Plated
09 Kawasaki Versys
TAPnTX is offline   Reply With Quote
Old 11-11-2010, 04:44 PM   #94
mcnut
Oddometer: 1,365
As to #1 you are the first on the block but I would hope so, their 76 mount did.
and
#2 Not really, used to interface with other equipment like radar, depth sounders and computers. I hope you got the big heavy duty connector. I think the cig lighter ones use heaver gage wires.
Be sure a post up when you get it up and running!
Bruce
mcnut screwed with this post 11-11-2010 at 10:03 PM
mcnut is offline   Reply With Quote
Old 11-11-2010, 06:24 PM   #95
Countdown
Oddometer: 5,323
Come on there are several of these out there. Doesn't anyone have any answers?
Jerry Counts
Old 11-11-2010, 06:36 PM   #96
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,518
Originally Posted by mcnut
#2 Not really, used to interface with other equipment like radar, depth sounders and computers. I hope you got the big heavy duty connector. I think the cig lighter ones use heaver gage wires, but I would snip off the cig lighter, add a fuse and eye terminals or plug for a more robust setup.
Noooooo! Don't snip off the cig lighter! It's got the voltage reduction circuitry in it.
The Power/Data cable has the circuitry built in too, but it's much closer to the actual gps so you can shorten the cable a lot, and retain the right voltage.
And just because it has data, doesn't mean you have to use those wires. I made up three power data cables connected to the battery with a fuse in line, and just clipped the data wires short as I had no plans to use them.
Old 11-11-2010, 07:50 PM   #97
Countdown
Oddometer: 5,323
Originally Posted by Emmbeedee
Noooooo! Don't snip off the cig lighter! It's got the voltage reduction circuitry in it. .
I think he bought a 78 which I think has been accurately reported to run on Auto 12V power.
Jerry Counts
Old 11-11-2010, 07:58 PM   #98
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,734
He is getting a 78S so I would assume that it can take 12v direct if using the round 4-pin Garmin connector for power, NOT the mini USB. Not sure though.
If you look at the "accessories" listed for the 78S there's 2 different "vehicle power cables" shown, one is the round plug and the other is mini USB.
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 11-11-2010, 08:01 PM   #99
Countdown
Oddometer: 5,323
Obvioiusly it is for people who go either way!
Jerry Counts
Old 11-11-2010, 08:14 PM   #100
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,518
I forgot the 78 still has that power option. Thanks for the clarification.
Old 11-11-2010, 10:02 PM   #101
mcnut
Oddometer: 1,365
My Bad.
You guys are right I assumed the big plug cable. Good catch, I will edit my post.
Do not cut off the cig lighter if mini USB!
Bruce
Old 11-12-2010, 01:53 AM   #102
Muddler
Muddler's Avatar
Oddometer: 751
KMZ maps
ls the 62 supposed to be able to read KMZ background maps like the Oregon and Dakota? I am wondering as the unit has a "custom maps" folder. However, when I drop a file in, the unit doesnt seem to recognise it.
Muddler is offline   Reply With Quote
Old 11-12-2010, 11:15 AM   #103
bike_pilot
bike_pilot's Avatar
Oddometer: 132
Bruce
No USB! Wasn't planning on it. I did get the automotive power with the 4 pin. That was a major decision point for me in model choice. With the Rino it used usb and I modified the cig plug for its circuitry sake. I'm looking forward to a solid power connection.
Old 11-12-2010, 01:12 PM   #104
mcnut
Oddometer: 1,365
With my oversight I'm now a little concerned about safe voltages. I would do some research, maybe call Garmin before connecting.
In the old unit the big round 4 pin was good for a wide voltage range but things could have changed.
Bruce
Old 11-12-2010, 01:22 PM   #105
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,428
It'd be a bad move on their part to change the spec on that plug without changing the connector itself.
Think back to the "low-voltage" models with the safety pin in the middle of the round connector, vs. the current flavor that doesn't have the pin in the middle.
Spewer of the poignant non sequitur
SnowMule is online now   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 07:52 PM.
