Old Yesterday, 12:19 AM   #1
Rockfox OP
Rockfox
Oddometer: 6
Amagaeza Rally Bike Build
Firstly the Amageza Rally is a navigational cross country rally spanning 7 days and 2500 miles in and around South Africa and Botswana. it is modeled on the Dakar and other similar events.
Ok,
now we have gone completely mad. This picture is the (incomplete) prototype frame for our Rally bike.
The geometry etc etc are designed with enduro suspension geometry and checked with Solidworks. We opted for a semi stressed engine to reduce frame complexity with required frame rigidity. We then built a 'concept frame' to evaluate the spring rates in real life. (Static loading only.)
Next step will be to make the changes to the design as some engine/frame clearances were too tight or non existent once the wiring harness will be plugged in.
Just a few of the design criteria.
1. Centre of Gravity as low as possible.
2. Access to plugs etc within 2 minutes if bike drowned.
3. Access to valve adjustment within 2 minutes (tappet cover removal)
4. Larger water radiator.
5. Oil cooler with extra oil capacity. (It is a dry sump motor)
6. Air filter access within 1 minute.
7. Balanced fuel load between front and rear tanks.
8. Hydraulic clutch actuation (Still under investigation)
9. All fuel tanks and body panels from high impact flexible epoxy resin.
10. 300mm suspension travel, 350mm ground clearance,
11. Less than 145kg dry weight in full rallye kit. 65F/75R weight balance.
12. 30l fuel split in 18 rear 2x6 front.
13. Aluminium rear subframe.
14. Custom exhaust pipe and muffler.
bla.. bla .. bla.
The next build phase will be to manufacture the 'real' frame and then complete the basic running gear as a 'Plastic' so it can be tested at Dirt and Dust and Zone7 or Quarry for sand. The rear shock angle will be adjustable during shakedown tests to test the 'linear' spring rate during compression with a standard spring. We might need to go 'progressive' to simulate the effect of a link suspension design to achieve the 'winding up' of the suspension over the last 100mm of wheel travel.
NOTE: all the braces etc not welded in as this phase was to evaluate the suspension geometry.
Mike
www.rockfox.co.za
Rockfox is offline   Reply With Quote
Old Yesterday, 01:38 AM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,989
very nice!
One comment if I may...If you fit a progressive spring then you will need a progressive dampening shock too. One without the other will probably yield an iffy behaviour. I would go with a linear spring and simulate a linked suspension by playing just with the shock angle. Otherwise, why not borrowing a linkage system off an other bike? Something like a drz for example.
edit. Just realised that you have already chosen a swingarm, so the last suggestion is not aplicable.
Old Yesterday, 03:26 AM   #3
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 278
This is not just a rally bike build, but first a bike build! Looking forward to your progress.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old Yesterday, 05:01 PM   #4
TobyG
be happy :)
TobyG's Avatar
Oddometer: 592
Looking great, I'll sure be following this one!
My 650GS is still hella heavy compared to what you want to achieve!
(~ 165kg without fuel and once the aluminium swingarm is mounted, of course the Rally tanks and nav gear would easily add another 10 to 15kg to that)
But I guess you won't use much more than the swingarm and the engine from the 650GS?
One important note when you're using this swingarm as-is: Replace the nuts on the chain tensioner bolts with nyloc nuts!
This is mine, by the way, the bike was already completely modified when I bought it,
I just put in a lot more work to make it the perfect travel/enduro hybrid for my needs.
Still using the BMW main frame, engine (with slight modifications, now power mods, though) and currently the swingarm,
everything else is either custom or aftermarket parts.
I did recently start outfitting all the fairing with 1/4 turn fasteners, so I can access the valve cover and all other essential parts (electrics,
injection unit, ECU, battery etc.) real quick, too.
http://i.imgur.com/x0wZxC2m.jpg
And this is the swingarm that will go on it, soon:
http://i.imgur.com/EyRQza1.jpg
[click the links for higher resolution]
Really looking forward to your progress on this build!
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG screwed with this post Yesterday at 05:17 PM
TobyG is online now   Reply With Quote
Old Yesterday, 11:01 PM   #5
Rockfox OP
Rockfox
Oddometer: 6
Toby G Swing arms
hi Toby,
Thant 650 really looks like it means business.
Quick question what swingarm arm is that. from which bike and is it fully aluminium?
Old Today, 07:52 AM   #6
TobyG
be happy :)
TobyG's Avatar
Oddometer: 592
It is fully aluminium, cast aluminium front with 2 profiles welded to it.
Unfortunately, though, they are rare as hens teeth.
They were made by Touratech for the F650GS, to allow for better fitment of an 18" wheel and mounting a longer shock (+30mm suspension travel at the wheel), but only a handful (less than 10 are known to still be in use today) were ever sold.
Took me 2 years and a good portion of luck to find one to purchase.
Just remembered there was another extreme 650 conversion by an italian BMW motorcycle dealer,
they also modified or replaced pretty much everything other the main frame and swingarm (carbon underseat tank and the bike has been equipped with a carburetor, afaik).
TobyG screwed with this post Today at 08:01 AM
Old Today, 10:12 AM   #7
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,152
Twofer, and I'm in on the ground floor.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is online now   Reply With Quote
Times are GMT -7.   It's 10:50 AM.
