09-13-2010, 07:34 PM
#46 | |
Oddometer: 198
Rebuilder screwed with this post 09-13-2010 at 09:07 PM |
09-13-2010, 07:35 PM
#47 |
Oddometer: 4,134
Great project!
I think you'll be more than pleased with the power you can get from the 500 Yamaha. It will likely cause the rider to back off far before it's done. Here's a shot of the Flying Merkel that's in the Cannonball run, from the Maggie Valley stopover.
RR's Catnip Hill to Peoria ___Loopin' Seattle to WestFest It started with some beers __1500 miles to the Dentist Skeedaddle to Seattle______ A 30 year old on a Three Flags Run |
09-13-2010, 07:53 PM
#48 |
Oddometer: 198
On to something I've always wanted to make.... a reverse clutch lever. I know the original Merkel didn't have one but mine is going to. I figure the throttle cable runs through the bars so the clutch cable should too.
I started with CNC routing the rough shape out of 1/2" aluminum. And then went to work shaping it. After doing a little testing I'm not sure I got the pivot point correct because it's pretty hard to pull. I'll change it later if I have to. |
09-13-2010, 09:02 PM
#49 |
Oddometer: 198
On to the tank. This is one of those parts that can make or break a good build. It's the most iconic part of the whole bike. Everyone will be looking at this thing....no pressure. The painter can fix it. Wait that's me.
Anyway, I picked up some pretty heavy gauge sheet metal (maybe 20 or gauge? can't recall). I was thinking it was too thick when I got it, but it turned out just right. Easy to weld, didn't warp, strong. Unfortunately, it was factory primed, not galvanized, but close. I didn't know it until the guy had it on the scale. I said I didn't want it because it cost more, he said he'd sell it for the lower price, turned out I ended up paying the higher price (realized on the way home). I wasn't happy. End of rant. Once the frame was welded I simply traced the opening to some paper and transferred it to the steel. The marker width from edge to point gave me just the right gap around the outside (around 3/16"). Plasma cutter on and Voila... sides. I had sheared some strips for the top, ends and bottom at work. I have a little break at home so I started bending it up. The tank was actually pretty difficult to figure out. Not to make but to make sure I had everything welded in it before welding it shut. I wanted to weld the filler necks in from the inside so I got to work on them. One for Gas and one for Oil. The bungs and caps came from... were else but Bung King... Really, look it up. Great site for the do it yourself-er. Again, Voila they're done. That's the oil tank section Painter can fix it. The bottom Fits. See that weld just above the highest point at the bottom of the tank? I put in a short divider that I hope will work as a little reserve. It'll fill when the tank is filled and the intent is there will still be some gas back there if I ever run out. I'll be running two petcocks. Upper brackets. Notice how I like to punish myself by using flat head screws. The bottom of the tank is held with pipe clamps from Mcmaster Carr. They have everything. These are nice stainless ones with rubber insulator bushings. Again flat head screws into welded in threaded blind bungs Welds are ugly but they'll soon be ground down and made pretty. Once I get the motor in I'll put in the oil and fuel bungs and then I can pressure test it and epoxy seal it to make sure oil and gas don't mix. 40 more pics until I'm caught up. Bars and home-made leather seat still to come. |
09-13-2010, 09:13 PM
#50 |
Oddometer: 178
I was going to post that I have just replaced the fork seals on my IT 175, but I think I'll hold off now.....
Much props and admiration on this project. |
09-13-2010, 09:19 PM
#51 |
What could go wrong?
Oddometer: 4,956
Your workmanship is awesome.
![]() As for the motor, I was considering recasting the bottom end to get that lovely round shape, but after researching.... it was going to be a boatload of work. Getting any period motor is going to cost an absolute fortune... I remember looking at an old compressor I had kicking around and thinking.... it almost looks the part, maybe with a bunch of work..... Good luck.
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
09-14-2010, 04:44 AM
#52 |
Bike Butcherer
Oddometer: 273
I have a question about the gas tank welding. Your tacks looked to be MIG welded. Did you MIG weld the entire tank? A friend/welder who does a lot of custom bike work told me once that MIG welds are too porous for gastanks and that they well weep fuel if you don't use a sealant inside. He TIG's gastanks with silicon-bronze rod (basically TIG-Brazing). Just curious if you've run into similar issues, or if you plan on sealing it when you're finished?
Awesome looking build BTW. |
09-14-2010, 07:02 AM
#53 | |
Oddometer: 198
A friend of mine is building a more bicycle scale motorbike and using what I think is a compressor motor or some sort of PTO motor. Really cool little single cylinder with the round case. Another guy built a Cyclone replica and used a Briggs V-Twin. That actually looks really cool. On the XT motor I know I'm going make my own stator cover and I may do something to the other side as well. |
09-14-2010, 07:05 AM
#54 | |
Oddometer: 198
09-14-2010, 07:32 AM
#55 | |
Wacky Bongo Boy
But, you should keep doing build threads. I like your work.
1974 BMW R75/6, 1974 BMW R90/6, 1969 BMW R60/2 hack, 1929 Ford Model A, Metal casting, Part 2/Part 1 among others.. |
09-14-2010, 07:34 AM
#56 |
Obsessive Lurker
Oddometer: 84
Don't know if this has been said, but SWEET Stroppe Bronco!
Fab work is inspiring. |
09-14-2010, 08:37 AM
#57 | |
De Oppresso Liber
Oddometer: 30,297
![]() I was thinking I acomplished something on my R100RS but don't dare post it here for the same reason!
"I claim to be frightened of horses but do so only to get out of attending parades. It's peculiar but ...it works. The Horses get it. RESISTANCE IS NOT FUTILE. IT'S VOLTAGE DIVIDED BY CURRENT |
09-14-2010, 09:07 AM
#58 | |
Oddometer: 198
09-14-2010, 01:20 PM
#59 |
Physycotic gecko
Oddometer: 1,313
That's some skill there
![]() What i'd give to have a decent shop, working out of a 8 x 10 shed has it's limitations
"Mad Science" means never stopping to ask "what's the worst thing that could happen? ![]() Smugmug photo site discount coupon X0gojbokG3nBM
09-14-2010, 03:03 PM
#60 | |
Call me Renzo
Oddometer: 10,838
![]() With apologies to the lads what wrote it
- Jinx ![]() "You remind me of the monkey with the jerk-off button, starving to death at the switch." - Chopperman "I didn't know how many assholes it was going to take to piss me off, but I knew how many they were going to use" - collaboratori |
