Old 09-15-2010, 08:03 PM   #76
danedg
Horizontally Opposed
Oddometer: 6,604
danedg is offline   Reply With Quote
Old 09-15-2010, 09:54 PM   #77
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,529
Originally Posted by isdt BMW
The rpm range of a Gravely motor would do well with a belt drive motor.
I remember those Gravely sickle bar mowers. They were a bitch to start with a leather belt that you wrapped around the starter pulley. Many a time I whipped myself with that belt trying to start that bitch. Backed into a few trees trying to man handle that beast when I was a kid.
Think I'd modify the OP's choice of motor to make it look kinda look old.
BTW, Irutt, you got the MBS real bad,bad.
Bar None is offline   Reply With Quote
Old 09-16-2010, 08:21 AM   #78
NJjeff
NJjeff's Avatar
Oddometer: 1,033
Rebulider
HELP! fix it.
Rebuilder your pictures are not coming through.
NJjeff is offline   Reply With Quote
Old 09-16-2010, 08:46 AM   #79
Rebuilder OP
Rebuilder's Avatar
Oddometer: 205
Originally Posted by NJjeff
HELP! fix it.
Crap. Should be back up soon.
Rebuilder is offline   Reply With Quote
Old 09-16-2010, 01:11 PM   #80
danedg
Oddometer: 6,604
...if I'm sending repeats... tough!
Old 09-16-2010, 02:54 PM   #81
fleshpiston
fleshpiston's Avatar
Oddometer: 598
Originally Posted by Rebuilder
I've thought about that but the original didn't have anything (visible anyway). I have notice during mock up that since there are no holes in the lower tubes, and it's such a precise fit, the trapped air sort of works as and air dampener. Add grease to further seal it and I may not need anything else. Or it may just not work at all.
Not sure where you're at with this but I have a bunch of Rock Shox (bicycle) fork springs laying around. OD on them is about 21-22mm ..... might work for a bottom out spring if nothing else? Let me know if you want them.
Excellent build
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 09-16-2010, 04:46 PM   #82
Rebuilder OP
Rebuilder's Avatar
Oddometer: 205
Excellent build
Thank you. I got the spring thing figured out, I just don't have anything for rebound dampening. I'll wait to see how it rides before worrying about it.
Rebuilder screwed with this post 09-16-2010 at 06:42 PM
Old 09-16-2010, 04:48 PM   #83
P B G
Oddometer: 10,001
Thank you. I got the spring thing figured out, I just don't have anything for rebound dampening. I'll wait to see how it ride before worrying about it.
Friction?
Old 09-16-2010, 05:04 PM   #84
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,529
Originally Posted by MZRider
Like anything old, you just have to know how they want to be started. With my '64 L, it's half throttle, full choke and one pull - starts right up.
I think our Gravely was probably a 1950's model.
Anyway this thread is about Rebuilder's build and not Gravelys.
Old 09-16-2010, 06:51 PM   #85
Rebuilder OP
Rebuilder's Avatar
Oddometer: 205
Originally Posted by P B G
Friction?
I'm hoping friction will work... Uh, I mean my calculations show that the friction produced will be sufficient.
Old 09-16-2010, 07:45 PM   #86
Rebuilder OP
Rebuilder's Avatar
Oddometer: 205
The last couple of nights I've been working on getting the motor mounted. Turned out to be quite a job.
First I had to notch the motor to fit around the frame. I wanted to set it as low as possible so the frame would curve tightly around the bottom.
Just like in the stock frame I had to make one side of the upper mounts removable so I can get the motor in and out.
I probably won't punish myself with flat heads here, but I'll use them for now.
The other side.
Now to set the motor and make the other mounts
This will be the pretty side of the bike (Only meaning the kickstand will be on the other side). I plan on making my own stator cover to look more the part of an old motor. It'll be hard to disguise this thing though. I'm hoping the bright orange paint and shiny things will be take the attention away from the motor.
This side looks really Japanese and will be harder to disguise.
The other mounts getting ready.
Front L side. Ugly weld so I ground it down. Guess I'll smooth them all now.
R side.
Gusset
Bottom rear.
Bottom front.
Best work stand ever. I used that to work on my BMX bikes when I was a kid.
Nice fit if I do say so myself.
I'm not sure what's next. It may be a few day before the next post. All the big stuff is done. Maybe I'll finish the wheels.
Old 09-16-2010, 08:19 PM   #87
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,624
Bloody brilliant. I love it.
crazydrummerdude is offline   Reply With Quote
Old 09-16-2010, 09:00 PM   #88
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,579
Thought you said you couldn't weld? Rear motor mount welds look good to me.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 09-16-2010, 11:22 PM   #89
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,732
looks great doode! i can hardly wait to see the finished bike.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 09-17-2010, 09:38 AM   #90
Mr. Vintage
Family Dude
Mr. Vintage's Avatar
Oddometer: 859
Further inspiration, in case you didn't see it. Blatently stolen from the Cannonball Run thread:
Originally Posted by dlrides
A board tracker replica, built by a guy in Raleigh NC
- Jeff (Mr. Vintage) -
Quota, SL350, MW250, MT250, CT90
Mr. Vintage is online now   Reply With Quote
Times are GMT -7.   It's 10:31 PM.
