Old 12-08-2004, 04:18 PM   #1
Alchemist OP
Alchemist's Avatar
Oddometer: 528
Matching Engine and Frame Numbers
How important do you guys think this is. On Brit bikes in particular they seem all over the place. Less so on European.
I have traced down a R69S but the engine was totally unusable apparently so its been replaced by another. I am checking engine and frame numbers and since I want to restore it and keep it for a long time I personally don't mind....but then again its a badge of authenticity
Do others have a view.
Alchemist is offline   Reply With Quote
Old 12-08-2004, 04:56 PM   #2
norton73
drinkin'
norton73's Avatar
Oddometer: 8,306
if you want to just have a rider, it's overrated, but use it as a bargaining tool to lower the price.
some folks will swear by matching numbers, but they're investors, not riders
Loose nut holding the handlebars
He’s one of those who knows that life is just a leap of faith. Spread your arms and hold your breath, always trust your cape. Guy Clark "The Cape"
norton73 is offline   Reply With Quote
Old 12-08-2004, 05:10 PM   #3
Rad
Just me
Rad's Avatar
Oddometer: 12,172
No idea what it is like down under but motorcycle theft and part'n them out has become enough of an issue in Calif that it is very difficult to register a bike without matching numbers. Yes; they inspect and check numbers on every used bike that is registered.
Rad is offline   Reply With Quote
Old 12-08-2004, 05:28 PM   #4
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
They do that 'ere too. One of the tricks is to import one stolen overseas - not on our data base. And export our stolen ones to ewes.
If the motor was "was totally unusable" it should still be sitting somewheres. Is it avalible together with the bike? If you get the matching numbers engine as well then if someone really cares they can waste their money gettin the thing fixed.
Regards Frank Warner
motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S
http://www.geocities.com/fwarner_au/
Frank Warner is offline   Reply With Quote
Old 12-08-2004, 06:36 PM   #5
Team Dennis
Certified Troublemaker
Team Dennis's Avatar
Oddometer: 4,538
72 Norton matching engine/trans/frame #'s
73 Ducati 350 (all orig) No matching #'s
1975 CB400f (all orig) engine/frame # off by one digit
Team Dennis is offline   Reply With Quote
Old 12-08-2004, 08:42 PM   #6
Alchemist OP
Alchemist's Avatar
Oddometer: 528
yes this question has been asked. Waiting for a reply. Seems to me that if the current engine works, I ride the bike while restoring said original engine...then replace into frame etc
sell "usuable" engine or keep for parts
nice comments on the stolen stuff I'll keep in mind. The bike is actually in the US so I will need to be careful and try and get a trusted soul to inspect.
Old 12-08-2004, 09:04 PM   #7
Frank Warner
Traveller
Oddometer: 6,593
No, keep ridin on the motor that is in there. You don't care. When it comes time to sell swap motors? Sell second motor then - possibly with bike depending on prices.
seeya sat, I'll probably bring the LT as I've just put a 'new' muffler on the K75G/S and have not tested it legal like. Don't need any extra hassels on the putty. The muffler is off a duck, nice note and sounds to me quiter than the one that was on the bike.. but that was a friggin loud muffler - not tested .. but way too loud.
Old 12-09-2004, 07:55 AM   #8
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Depends on your needs/desires and the laws. Some places will make it difficult if you have mismatched numbers. SO check that out. Some bikes dont have numbers stamped in the frame but on a data plate affixed to the frame. That can make things easy if you can match those. But other than that it is largely an issue for the flat cap concourse freaks. Because some stamping on older bikes is pretty crude, you can alter a motor of the correct vintage to match the frame and then destroy the original block. But that would be illegal and if botched could get sticky.
in wa state at least I ave found the DOL franchisers to be helpful if you explain the situation and ask what needs to be done.
dead
Chopperman is offline   Reply With Quote
Old 12-09-2004, 09:19 AM   #9
Ostrich
Jaded and Happy
Ostrich's Avatar
Oddometer: 8,731
If you go to a dealership not every bike from the factory has a matching engine and frame number. Usually they are registered together as belonging to that one particular bike. I had a bike with a salvaged title with different frame/engine number. The DMV wasn't concerned the least bit when I registered it.
Check with your local DMV or whatever they call it on your side of the pond. It should not be a problem.
If you use Geico watch out. The buyout for my car was way below any objective figure (KBB, NADA, etc.). Also, I could not get in touch with anyone on the first try during a claim resolution.
Just because it's a zoo out there doesn't mean you have to view it from a cage!
Don't be an impulse buyer... afterall you have time..
Ostrich is offline   Reply With Quote
Old 12-09-2004, 01:12 PM   #10
jdiaz
Oddometer: 32,222
I don't know if anyone has mentioned this, but late-model Beemers usually don't have matching engine/frame numbers. The title uses the frame number, but the engine is different. I don't know how old this practice is for them.
Jon
jdiaz is offline   Reply With Quote
Old 12-09-2004, 02:15 PM   #11
cpatstone
N00b, obviously.
cpatstone's Avatar
Oddometer: 347
Eek wha - wha - WHAT???
... the K75G/S ...
Pardon the diversion in the thread... but a K75G/S? Now there's a setup I'd like to see!
'88 BumbleBeemer
"Minds Awaken on roads less Taken" -- Magic Hat bottle cap inscription
cpatstone is offline   Reply With Quote
Old 12-09-2004, 04:39 PM   #12
Frank Warner
Traveller
Oddometer: 6,593
Yes - mism atched engine and frame numbers are fairly common. On the R75 during teh war they swaped bits to get as many working bikes going. So they are all over the place. And our rego people don't care about the missmatch - just as long as none of the relevant numbers are on the stollen list.
You can find some old photos of the K75G/S on my site. It has changed a bit since then - larger fuel tank, pelican panniers (and another rack) that I'm finishing off now. Other things are less noticable. http://www.geocities.com/fwarner_au/...abmwk75gs.html
Old 12-09-2004, 04:46 PM   #13
Alchemist OP
Alchemist's Avatar
Oddometer: 528
Yes - mismatched engine and frame numbers are fairly common. On the R75 during teh war they swaped bits to get as many working bikes going. So they are all over the place. And our rego people don't care about the missmatch - just as long as none of the relevant numbers are on the stolen list.
My understanding is the pre-70 boxers had matched numbers. At least my old R69S (which I sold ) had matching numbers.
Times are GMT -7.   It's 11:11 PM.
