09-14-2010, 06:31 PM
#1 |
Oddometer: 380
1970s Sears Free Spirit 8088 Moped NEED PARTS
I am trying to fix a 1970s Sears Free Spirit 8088 Moped and it is running and whatnot, but its bogging down on full throttle and not wanting to go good without the choke on, I am thinking about replacing the jets, but I dont knwo where to get them from. Any ideas? Would there be any other names this scooter would be sold under?
1992 Yamaha TDM 850 1980 Honda CX500 1977 Honda Goldwing GL 1000 |
09-14-2010, 08:03 PM
#2 |
250cc is 50cc too many
Oddometer: 917
Head over to moped army.
09-15-2010, 06:45 AM
#3 |
Puching adventurer
Oddometer: 753
What type of carb?
Probably a Bing? Mopedwarehouse. 1977mopeds. Any moped parts place.
Loud intakes save lives! |
09-16-2010, 04:53 PM
#4 |
Oddometer: 2,078
Probably just a clogged main jet. Clean out the carb. No need to replace the jets.
09-16-2010, 05:22 PM
#5 |
Oddometer: 380
Well I have cleaned out everything on it. Anything that contained gas now contains dust, but I have since cleaned everything out and replaced the fuel line and filter.
I kinda figured that was the only thing that may be an issue, maybe corrorision on the jet (which it has some) has caused it to allow less gas through.
09-16-2010, 05:41 PM
#6 |
Oddometer: 2,078
Needing the choke indicates a lean mixture. If the main jet is clean I'd suspect an air leak, possibly leaking main seals. Jets don't go bad and don't need to be replaced unless changes such as porting, exhaust, etc., are made to the engine.
09-16-2010, 06:18 PM
#7 |
Oddometer: 380
By main seals on this you mean the head? intake?
09-16-2010, 07:06 PM
#8 |
Oddometer: 2,078
The main seals are the ones that seal the crankshaft main bearings. Rubber seals eventually harden and allow air to be sucked into the crankcase leaning the mixture.
09-21-2010, 08:48 AM
#9 | |
Oddometer: 380
09-21-2010, 08:54 AM
#10 | |
Oddometer: 2,078
Yes, if you have the right tools. It involves plugging the intake and exhaust then pulling a vacuum to see if it holds. Sometimes it's just easier to replace the seals.
09-21-2010, 11:05 AM
#11 | |
Oddometer: 380
09-29-2010, 09:03 AM
#12 |
Oddometer: 380
Do you have a link to a thread on how to do this job or directions on how to?
Thanks again guys for all the help on this issue.
09-29-2010, 10:38 AM
#13 |
Ancient trailbike padwan
Oddometer: 4,115
One quick way to audibly check that your crankcase seals are working is to pull the spark plug out, open the throttle to full with the gas shut off at the tap, and have some one slowly crank the engine over while you listen at the spark plug hole.
The seals should be OK if, when it's turned over, at about 20~50 rpm, you hear a light, sharp, forceful "schplop!" sound from the transfer ports with each rotation of the crank. It should also blow a puff of air, or a light bit of fuel air mixture out of the sparkplug hole with each rotation. It will vary with different engines, but there should be a slight bit of resistance just before the transfer ports are uncovered by the piston and the noise happens.
____________________________________________ We're here because of a love most exestential. (toothy) |
09-29-2010, 05:42 PM
#14 |
Likes smoke an' lightnin'
Oddometer: 139
You can also test for leaks using brake cleaner or starter fluid while the motor is running, and spraying it at various suspect areas. Head, base of cylinder, case halves, intake, exhaust...
mpoed army treatland.tv 1977 mopeds
Our Bikes: '81Honda CB900F Super Sport, '90 Yamaha V-Max, '82 Honda MB5, '84 Honda NU50M, '09 Suzuki Boulevard M50 (Wife's) www.bluebirdfarmseattle.blogspot.com |
09-29-2010, 11:07 PM
#15 |
Let me take this duck off
Oddometer: 2,029
More then likely it''s a puch moped under the sears name. sear at one time sold everything from house kits to motorcycles. http://en.wikipedia.org/wiki/Puch#Puch_mopeds
I cut and paisted some info on sears bike for anyone that wants it. Motorcycles, Scooters and Mopeds Brief History of the Marque: Sears Allstate Puch two-strokes from Austria were sold by Sears-Roebuck of Chicago from the 1950s to at least 1979 under the Sears Allstate label. Sears sold scooters built by Vespa from 1952 to 1969, as there is one advertised in their Spring '67 catalog. They also sold Italian machines manufactured by Gilera. Sears Allstate by Troyce Walls VESPA ALLSTATE 125cc 788.100 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1951 788.101 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1952 788.102 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1952 788.103. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1953-54 788.104. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1954-55 788.94490. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1955-56 788.91191. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1956-57 788.94492. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1957-58 788.94493. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1958-59 788.94494. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1958-59 788.94495. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1960-62 788.94330 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1963 788.94331 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1964 788.94332 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1965 VESPA SEARS (125cc) 788.94370 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1966 VESPA SPRINT SEARS (150cc) 788.94360 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1966 Some of the information above from http://www.garnersclassicscooters.com/Vespa-ID.htm More Sears Models * Puch 250 Scrambler 1965 810.94201 * Puch 250 1958 810.94180 * Sears Allstate Puch 250 (round tank model) 810.94222 * 250 Late (square tanker `67-`69) 810.89571/2 * Compact scooter (early model w/steel front fender) 810.94380 * Puch scooter with pressed-metal frame c1960 810.94382 * Sport MoPed 810.94060/9 * MoPed 810.94020 * SR175 810.94211 * SR125 (radial head chrome-bore 2-stroke) 810.89581 * SR124 (Gilera) 808.895511 * 106SS (Gilera) 808.895403/13/23/33 * Sears Sabre Puch 50cc 810.89511 * Puch 1956 moped 810.940001 * Sears Sabre Puch 50cc 1968 810.895141, 810.895151 & 810.89512 * Sears Puch Compact Scooter 1960 (3 speed foot shift) 810.94390 * Sears Puch Cheyanne 810.89528
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE. Got to go places to be, people to kill and far to many woman. |
